Aug 22, 2012, 10:14 AM
South-west France
Joined Sep 2007
Well Sparks, we have been experiencing temperatures more appropriate to your neck of the woods for the last week, and I have to say, for the first time ever, I have been having quite a struggle with the covering and finishing stages of a model using mylar and tissue. First problem was that, with temperatures in the upper 30's C, the Balsaloc seemed to be reluctant to "set", in other words the ambient temperature must have been close to that which re-activates it. When things cooled down a bit in the evening it was OK, and the mylar then went on as normal. However, when we were up to 40 the next afternoon, it softened again and started to let go in odd places, resulting in slack mylar. With everything re-stuck down all was well, but then the tissue covering stage also provided problems as the tissue was drying VERY rapidly severely limiting the time for adjusting it prior to applying the thinners. The latter also dried as it left the brush and the whole job is proving quite a challenge, I have had to do several areas twice, and one three times to get an acceptable result.
I am getting there, but I have to say the covering stage of the build which I usually enjoy the most has been a  struggle this time and far from enjoyable, and I shall be careful never to attempt mylar/tissue finishing in these sorts of temperatures again. So for where you are, Sparks, I think you are wise to stick with heat shrink films - or do you have similar problems with some of these?
