Old Jul 05, 2012, 10:53 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Build Log
Britkit Build Off 2012 - Mercury Mars - Plans Published, see post #90
Well, I've rested long enough on the laurels of the Sportsters successful flying debut, time to start something else.
Henry J Nicholls Mercury kit concern produced some very fine kits, in 1956 they introduced a range of five beginners 18 inch rubber models under the banner "Starflite Series". At the time I was 15 and moving away towards bigger models, having acquired a couple of motors as presents, but I had enjoyed several of the similar sized Frog Senior series models and so decided to invest 4/9d of my hard earned paper round money in the biplane of the series, the Mars. This proved to provide a pleasant few days of building and flew very well, returning around 45 seconds of stable flight without too much effort. Also in the series were two shoulder wing models, a low winger and a pylon/parasol design.
The Mars is really almost a sesquiplane, with the bottom wing being significantly smaller than the top, and also having no dihedral. Having located a plan for the Mars at Derick Scott's website (he also has two of the others) I decided that it would be nice to do another two times scale up following on from the Tom Tit and Mamba (BTW the former was published in this month's Q&EFI as a full size plan, and the latter is scheduled to follow just as soon as I finsh drawing up the proper plan!). This would produce a convenient size 36 inch model, like the Tom Tit, ideal for my "private" flying site and a 120/140 watt motor. So, here are the original plans, first step is to draw up a twice size "building plan" (i.e. minimum detail) and then get cracking on what should be a fairly straightforward build, I hope.
Sundancer is offline Find More Posts by Sundancer
Old Jul 05, 2012, 11:44 AM
Gonnacrash is offline
Find More Posts by Gonnacrash
Havin FUN
Gonnacrash's Avatar
United States, KS, Basehor
Joined Sep 2001
Hi Sundancer,
We can take our plans to the local "Print / Copy" place and they will enlarge
them what ever % desired..........no re-drawing..........just a thought...
Don - Basehor,ks
Gonnacrash is offline Find More Posts by Gonnacrash
Old Jul 05, 2012, 12:00 PM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Now that is a good looking little airyoplane, George!!
Originally Posted by Gonnacrash View Post
We can take our plans to the local "Print / Copy" place and they will enlarge them what ever % desired..........no re-drawing..........just a thought...Don - Basehor,ks
I know George is in France, but in the UK, I found it to be far more difficult to find anywhere what would deal with anything bigger than A2 (paper, not glider!) size.... and they wanted a lot of money for the pleasure. I think the US is far better set up for this than the UK is......
[puts in large teeth and a curly wig]
"........unless you know different...???"
(showing my age a bit there!)
Colonel Blink is offline Find More Posts by Colonel Blink
Old Jul 05, 2012, 01:45 PM
Applehoney is online now
Find More Posts by Applehoney
Ajax, Ontario, Canada
Pro copyshop I use can enlarge to any requiired size - larger than anything we need - and has a $10.00 minimum charge, for which I can often get a half dozen or more prints dependent upon individual size
Applehoney is online now Find More Posts by Applehoney
Old Jul 05, 2012, 02:11 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Subscribed.
I always reckoned the Mars was a standard high wing cabin model that someone grafted in a smaller wing that was laying around, as an experiment. It's the sort of thing that I know I would do... don't even try to work out how my mind works..
sparks
sparks59 is offline Find More Posts by sparks59
Old Jul 05, 2012, 02:26 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Thanks for the suggestions Gonnacrash and Applehoney, but there are two problems for me with copy shop blowing up;
1. This is rural France; we are 45 minutes from Limoges, two hours from Poitiers and two and a half from Bordeaux. To the best of my knowledge there isn't a capable copy shop in Limoges, at least I can't find one in the Yellow Pages.
2. Blowing up the plan to double would result in very thick lines, I would just finish up tracing round the outlines.
3.... Sorry, there are THREE problems.... Apart from the fact that I shall not necessarily be scaling material sizes directly up to twice size, most of the structure - wing spars, built-up tail plane in lieu of all sheet, nose end for mounting motor, fuselage for battery and radio access etc. etc. will be entirely redesigned within accurate scaled up outlines. All the new fuselage formers etc. would still have to be lofted which takes much longer than drawing the scaled up outline.
4...No, no there are FOUR problems (no one expects the Spanish Inquisition - that's one for Monty Python fans)...the last and most important one being - I ENJOY drawing up plans and if, as is likely, the model eventually appears in a magazine, a completely redrawn plan will be needed anyway.
Anyway, being largely straight lines the Mars will be a much simpler scaling up job than my last three, the Tom Tit (loads of curves), the Mamba (swept surfaces) and the Sportster (loads of curves, funny shapes and an awkward 1.8 scale up factor). So having a twice size copy made would barely save any time and the cost, including the fuel for the necessary drive, would far outweigh the cost of doing it my way (a piece of lining paper, sharpen the pencils a couple of times and a few hours enjoyable work with calculator, drawing board, french curves, ruler and compasses)
I appreciate it may be a problem if you have never drawn a plan before, but as I have been drawing own designs and scaling up magazine plans for over fifty years now, it is second nature to me.
Old Jul 05, 2012, 02:47 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Originally Posted by sparks59 View Post
Subscribed.
sparks
See what you mean Sparks (my mind is probably as twisted as yours!) but I suspect not in this case, as Cyril Shaw and Ron Warring were responsible for the Starflite series and I suspect these two pretty talented designers probably worked from scratch. However, what you suggest was not unknown, there was a model called the "Phony Tony" which, I think held the British biplane rubber duration record at one time, which was, I am sure, created in just that way. Also I recall that when Ken Willard set out to break the Russian held radio control duration record with his "Breathless" design, in order to comply with wing loading regulations when the model was loaded with fuel for hours of flying, he added a bottom wing to the high wing monoplane. He then discovered that it wouldn't fly as the drag of the wing was greater than the lift it was contributing. So he worked out the minimum extra area required to comply with the loading rules and built a small wing, thus transforming the model into a sesquiplane, this worked and he broke the record (which, considering he was using rubber powered escapements giving rudder, elevator and motor control from just a single channel - one button - Tx, was a considerable feat I think).
Old Jul 05, 2012, 04:37 PM
Havin FUN
Gonnacrash's Avatar
Joined Sep 2001
Sundancer,
Off the subject... 1977 found house plans we wanted to build except flop it (reverse everything)..so I did the reversal drawing myself......staked it all out...excavator dug..foundation man laying out forms...wife/me standing there on big pile of dirt overlooking the operation...he yells to his forman while holding house plans...
"This Friggin house won't fit in this hole "... we nearly FAINTED... but all came out beautiful, no changes he had just mis read !!!
Don - Basehor, KS
Old Jul 06, 2012, 07:23 AM
RFJ is offline
RFJ
Find More Posts by RFJ
RFJ
RFJ's Avatar
Northern Ireland
Joined Dec 2004
Awful thing - a real rule stretcher At least in naming it the designer admitted what he was up to.
Our club used to run a competition for longest glide time from a set engine run. Obviously you want a fast climbing model with a good glide but all l had at the time was a Kwik Fli III ( good climb, poor glide) and a Super 60 ( poor climb, good glide)
Obvious, I thought - combine the two so I strapped the SS wing onto the flat top of the KF fuselage. The resulting very short flight was totally uncontrollable and put me off biplanes for years.
Ray
RFJ is offline Find More Posts by RFJ
Old Jul 06, 2012, 07:27 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Sundancer,
Don - Basehor, KS
Bit Scary Don - at least if I get one of my drawings wrong I will still have somewhere to live!
Old Jul 06, 2012, 07:35 AM
kkphantom is offline
Find More Posts by kkphantom
kkphantom's Avatar
Australia, WA, Perth
Joined Nov 2010
When I first glanced at the plan I thought the lower wing drawing was the tailplane! Whoops!
kkphantom is offline Find More Posts by kkphantom
Old Jul 06, 2012, 07:36 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Ray
Strewth Ray, even I wouldn't have tried that one. My maddest "bitsa" involved a TD.049 powered rudder/elevator Sharkface. This was pretty quick, but in the search for even more speed for our club pylon race I strapped the TD049 pod from my Soarcerer onto it. That worked, running on Super Nitrex (30% nitromethane) fuel it was now ballistic and the sound was epic (no silencers!) but the extra weight on top meant that unless the turns were flown with utmost delicacy it rolled inverted on rudder application. Made life interesting (and a bit frightening for the flagmen) at the pylons
Old Jul 06, 2012, 07:39 AM
rabidrue1 is offline
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
Or the copy shop folks might do bad math and you get a 3 meter.
rabidrue1 is offline Find More Posts by rabidrue1
Old Jul 06, 2012, 07:43 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Yep, forgot about that one Rab!!
Old Jul 17, 2012, 08:26 AM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
All quiet on the western front
Build Log Britkit Build Off May 2012-31/12/2012 - Keil Kraft Sportster x1.8 Sundancer Vintage & Old-Timer Designs 66 Aug 17, 2013 10:45 AM
Discussion "Britkit" Build Off April 2012 - 31/12/2012 Sundancer Vintage & Old-Timer Designs 303 Jan 01, 2013 03:47 PM
Build Log Britkit Build Off April 2012 - Veron Deacon cd_webb Vintage & Old-Timer Designs 66 Sep 22, 2012 06:54 AM
Build Log BritKit Build Off 2012 - Mercury Crusader RFJ Vintage & Old-Timer Designs 66 Jul 28, 2012 06:34 AM
Build Log "BritKit" Build Off 2012 - Veron Phoenix RFJ Vintage & Old-Timer Designs 37 Jun 08, 2012 05:28 AM
