Old Feb 02, 2013, 10:33 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Fort Langley
Joined Jul 2011
Originally Posted by Larry Dudeck View Post
"...Why is no one using thrust tubes? This would also direct the thrust past the wiring holes in the Nacelle and allow for more efflux..."
Like this?
Yea, kinda like that. How well do those ones work for you?
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Feb 02, 2013, 10:40 PM
WhalleyB0Y's Avatar
Joined Jul 2011
I would like to go with 90% FSA cones that extend about just an inch past the t.e. of the nacelle. Paint the cones black and adhere them to the back of the fans. I would try and make them look like this but with wider exhausts for the 90% FSA.
Description:
Old Feb 03, 2013, 12:12 AM
Jeanskydive is offline
Find More Posts by Jeanskydive
Jeanskydive's Avatar
Canada, QC, Saint-Jean-sur-Richelieu
Joined Feb 2009
Attachment 5503531
Yes , look better with tube extend a bit out side .
Jeanskydive is offline Find More Posts by Jeanskydive
Old Feb 03, 2013, 12:52 AM
WhalleyB0Y's Avatar
Joined Jul 2011
Woa exactly! What kit is this one? Looks pretty nice^^
Old Feb 03, 2013, 01:48 AM
Joined Feb 2009
This one come Laser Desing Services in wood kit., almost complete now am wait for is retract gear. Following is build-up at Republic Fairchild A-10 rcgroups. Cheers http://www.rcgroups.com/forums/showt...1777442&page=7
LDS Services wood kit http://store.laser-design-services.c...products_id=71
Old Feb 03, 2013, 08:52 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
"...Yea, kinda like that. How well do those ones work for you? ..."
As the outlet cones are adjustable, I was able to "aim" the thrust line through the balance point. This completely eliminates any pitch change when varying the throttle.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Feb 03, 2013, 11:24 AM
WhalleyB0Y's Avatar
Joined Jul 2011
+1, I see the importance of the adjustability.
Old Feb 04, 2013, 12:31 AM
WhalleyB0Y's Avatar
Joined Jul 2011
Description:
Description:
Description:
I used silicone to mount the fans and the ducts. These thrust tubes provide for 90% FSA.
Old Feb 04, 2013, 12:40 AM
Joined Feb 2009
Attachment 5507219
Attachment 5507220
Attachment 5507221
That looking verry nice with your thrust tube exit , nice rotor fan there .
Old Feb 04, 2013, 01:03 AM
WhalleyB0Y's Avatar
Joined Jul 2011
Lol, thanks. They look a lot more like your big kit now.
Old Feb 12, 2013, 07:43 PM
Joined Feb 2009
Yes Sir I did the same on mine also, with 1/64 plywood and 10degr.,angle upward a little bit , have somes mores pictures later Cheers
Old Feb 12, 2013, 08:16 PM
WhalleyB0Y's Avatar
Joined Jul 2011
Man, you are a wizard with the wood working! Nice work!
You might get to test your thrust tubes before I do so I would like to know how it works out in flight. Best of luck.
Old Feb 12, 2013, 09:29 PM
Joined Feb 2009
Yes I will do a flight test nex if weather here get calm in nex days with is news thrusts tubes to check if I get somes performences improve, I reduce a from 10degr., to 5 degr., upward thrust tubes. Cheers
Old Feb 13, 2013, 05:33 PM
Joined Feb 2009
Projet Nitro Planes A-10
Well I did a flight test this afternoon with is news thrust tubes with upward by 5 degr,angle, and I did not see any amelioration of is line thrust I still need tree clic elevateur trim up , same like before , but the speed increase pretty good with 55 mm exit dia., thrust tubes for the 70 mm fan. Cheers
Old Jun 05, 2013, 10:59 AM
WhalleyB0Y's Avatar
Joined Jul 2011
And at last, whalleyb0y's maiden!
Nitroplanes Projet A-10 Republic (6 min 57 sec)
Discussion New projet: Aerobatic 3d fiberglass manolitogafota Composites Fabrication 8 Jun 06, 2012 11:02 PM
New Product Brand New Nitroplanes.com Projet Sky Trainer Scale Plane Kit Nitro_Nancy Product Announcements 0 Apr 04, 2012 06:13 PM
Sold Nitro-003 Projet NIB tandemssafetyguy Aircraft - Electric - Airplanes (FS/W) 2 Apr 04, 2012 07:12 AM
For Sale Projet Trainer 50/AKA CMPro Cessna 182 50 LPU KaP2011 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 31, 2012 03:41 PM
Sold PROJET 98" RC Drone Craig Jacobs Aircraft - Electric - Airplanes (FS/W) 8 Mar 24, 2012 09:08 AM
