Sep 09, 2012, 08:16 AM
Williamsville, NY, USA
Joined Sep 2000
Projet A10 maidened (part 2)
Last Saturday I attempted to maiden the Projet A10. She just broke ground when the front end came off. The resulting cartwheel caused the battery to eject, punching a hole in the port wing. Other than that, the damage was minor.
Turns out the root cause of the breakaway front end was the total lack of any kind of glue in some of the tab/slot alignment points. Essentially, the front end was held together by two 1/4" balsa longerons, one 1/8" balsa spine and the iron-on covering.
I added two 1/8" x 3/8" spruce longerons, some 1/2" tri stock and CA'd the heretofore unglued tab/slot joints. I removed some of the covering and added a bit of FG cloth, followed by a bit of rattle can paint, to complete the repair. Total repair time - 2 hours
This morning I had ideal weather for the maiden; 62 degrees and no wind. Stretched the bungee 18 paces (about 16 lbs.or 2.8 x the AUW). Pushed the throttle to the half way point and hit the release. The A10 lifted off cleanly, trailing quite a bit of water from the very dewy grass.
The balance point was just about perfect. The published balance point, as well as that supplied by fellow Ezoner jcdfrd and my calculations were in good agreement. I added 2 clicks of "up" on the elevator. to get her level.
I had previously "aimed" the thrust line at the balance point and I could vary the throttle from one end to the other without any change in attitude. I was able to do this as I used the tail cones from the WM400's. Now that she has been flown, I will remove the electrical tape from the tail cones and glue them into position.
My A10 has neither flaps or rudders nor does it seem to need them. On low rates I thought my aileron and elevator throws were a bit much and made a note to reduce them. My first landing attempt appeared to be hot so I added power and went around. The second attempt resulted in a smooth landing, although she kicked up a lot of spray from the dew.
The second flight went equally well. I had reduced the throws a bit and this resulted in a less twitchy flight. My A10 has an AUW 0f 88 oz. and the actual wing area, ignoring the instruction manual value of 505 sq. inches, is about 450 sq.inch, measured. This results in a wing loading of 28.2 oz./sq.ft. but she flies as if she were lightly loaded.
The A10 has a wide speed envelop and seems equally stable anywhere between gliding and full throttle. No where near enough thrust for vertical flight but that's never been my style, anyway. The only negative of this morning was the loss of the canopy. Not sure why it came off but it fell into the trees that border the east side of the field.
All in all, the Projet A10 seems like a decent flier. After a rocky start with the damaged wing and zero help from Nitro Planes, she has turned out to be just fine. Before I fly her again I will fab a canopy, probably from pink foam as well as add some contrasting color to the wing bottom. Under certain lighting conditions it will be hard to tell which side is up.
