Old Jul 05, 2012, 03:52 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Question
What can be causing this (Eagle Eyes black&white video problem)
Any of you with idea what might be causing this kind of video problem?
Eagle Tree, Eagle Eyes generating noise (0 min 20 sec)
There are two 1.2Ghz video receivers hooked up to Eagle Eyes inputs and Fatshark goggles and Aiptek MPVR on the outputs. Camcorder that in any other configuration (with video splitter for example) is working flawlesly is recording (and displaying) this kind of picture only when hooked up to Eagle Eyes output. Fatsharks are showing correct picture all the time.
Already tried different output ports, other set of cables etc.
hefest is offline Find More Posts by hefest
Old Jul 05, 2012, 09:13 AM
CryptoHawk is offline
Find More Posts by CryptoHawk
Joined May 2012
I have no experience with this hardware in particular - but 2 common generic causes to intermittant loss of colour content in analogue video are:
- current or voltage drop between video camera and display or recorder.
- conflicts in video signal processing and/or hardware components e,g, component to composite (or the other way round).
CryptoHawk is offline Find More Posts by CryptoHawk
Old Jul 05, 2012, 10:12 AM
nkkromhof is offline
Find More Posts by nkkromhof
NKK for short...
nkkromhof's Avatar
United States, IN, Mitchell
Joined Oct 2010
I don't know what would cause it, but it almost looks like NTSC and PAL signals are being mixed.
nkkromhof is offline Find More Posts by nkkromhof
Old Jul 05, 2012, 05:26 PM
Joined May 2012
Very possible.......
Playing a PAL video camera signal through NTSC monitor can cause:
- rolling screen
- blank screen
Playing an NTSC video camera signal through a PAL monitor can cause:
- intermittent black & white frames
- a blank screen or
- what folk call in the trade “picture tearing”
You know the old definition for NTSCNever The Same Color Twice.
The definition stems from the color variance flaw - a well known problem in the NTSC format.
Old Jul 05, 2012, 07:07 PM
NKK for short...
nkkromhof's Avatar
Joined Oct 2010
Exactly what I was thinking, but the only way that makes sense is if the VRx's can be set to NTSC or PAL, which doesn't sound likely, they're usually able to handle both types of signals.
I would start by hooking up each VRx individually and checking the Aiptek to see what it looks like.
It just looks like the Eagletree is switching between the two RX's and one of them is the problem
Old Jul 06, 2012, 02:18 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
That's not the case, signal from both RX's is behaving in the same manner.
Without EagleEyes when one RX is connected trough simple video splitter to Fatshark goggles and Aiptek DVR everything is ok.
EagleEyes shouldn't change any of the video passing trough it, its just inspecting the quality of the signal.
Old Jul 06, 2012, 11:32 AM
NKK for short...
nkkromhof's Avatar
Joined Oct 2010
I understand that the ET is just a conduit, it's not supposed to do anything except pass the strongest signal through.
Having said that, yours appears to be defective or there's something that all of us don't know about the ET diversity controller. I would contact them to find out what they think, because you've eliminated the rest of the equipment.
Old Jul 06, 2012, 03:00 PM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
A low video level can cause this. Right after the synch pulse, there is a "color burst". This signal the presence of a color format NTSC. If undetected, the display devide switch to black and white mode. There is a video adjustment pot on the EE, turn it to max brightness and see if the input 2 does not bahave like this anymore.
Hugo
Hugeone is offline Find More Posts by Hugeone
Old Jul 08, 2012, 08:09 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Hugo
Interesting idea, i'll try that but there is only one video adjustment pot for second channel.
Old Jul 08, 2012, 08:12 AM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Yes, but if it work, you know your problem.
Hugo
Discussion Skyjib 8 with Wookong - M rudder problem, what can be the cause? Stef stuntpiloot Multirotor Talk 23 Sep 26, 2012 11:00 AM
Discussion How can this be ? High KV ... low amps ? solentlife Electric Ducted Fan Jet Talk 7 Jul 02, 2012 05:34 PM
Discussion what could cause a belt to get lose and what can i do wc_wickedclown Electric Heli Talk 6 Jun 23, 2012 03:01 AM
Help! What would cause this..? (plane buried itself) xDennis Crash Discussion 11 Jun 17, 2012 08:12 PM
Full scale crash video - what can cause this failure? dw1122 Electric Heli Talk 4 Jul 03, 2004 12:48 PM
