Old Jul 05, 2012, 03:47 AM
alfapistola is offline
Find More Posts by alfapistola
Joined May 2012
Hot ESC without doing nothing - HK blueseries
Hi dear,
I'm installing an hobbyking ESC blueseries rated at 30A, trying to let it connected to
battery without any driving signal leads the ESC to come hot... in other word, no current
to motor and the ESC is hot (my hand can touch it without excessive pain, say 45-50 degree I think)... is it normal?
alfapistola is offline Find More Posts by alfapistola
Old Jul 05, 2012, 04:41 AM
teslahed is offline
Find More Posts by teslahed
Joined Jul 2008
That doesn't sound normal to me.
If you plug a speed controller in to a battery and a motor but don't plug the cable in to the receiver it should not heat up.
teslahed is offline Find More Posts by teslahed
Old Jul 05, 2012, 05:28 AM
brodiej is offline
Find More Posts by brodiej
Joined Jun 2012
teslahed has the right idea, unplug the 3 pin control line and see if it gets hot.
The ESC's contain a seperate regulator designed to power other devices other than the motors. If this device is pulling too much current, or if the ESC is connected to a device with other ESC's it is possible for the esc's to have a bit of a battle to supply varying voltages anomalies.
brodiej is offline Find More Posts by brodiej
Old Jul 05, 2012, 12:17 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
with no load, no its not normal. you say the little servo connector is not plugged in, so is probably a bad ESC. try it with another motor to see if it is a shor in the motor or the ESC is bad.
sirbow2 is offline Find More Posts by sirbow2
Old Jul 05, 2012, 10:08 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
bad speed controller
vic20owner is offline Find More Posts by vic20owner
Old Jul 06, 2012, 11:16 AM
Joined May 2012
yeah, thanks guys, just one esc out of six was bad, it can also drive the motor but it's produce totally random sounds with any attempt to programming, it starts motor without any sound and....as originally posted, it became hot pretty soon..
-hobbyking blueseries 30A-
how much often happens to find a bad esc in a set? This is the first set for me, next time I will order one or two in addition
thanks again
Old Jul 06, 2013, 04:40 AM
natael is offline
Find More Posts by natael
Joined Sep 2012
I had a similar problem with my tricopter with the blueseries esc. One esc is getting really hot when the servo cable is plugged in, up to feel pain on my skin. It's not getting hot when the servo cable is removed.
So i removed this esc+motor and left the other two plugged in, with servo cable, and surprisingly one of the other two got really hot this time, while it had no problem when all three where plugged in.
Any idea ?
natael is offline Find More Posts by natael
Mini-HowTo HK 30A BlueSeries ESC schematic and I2C/TWI mod [TwisteR] DIY Electronics 29 Sep 25, 2013 08:44 AM
Discussion Do nothing Congress thunder1 Life, The Universe, and Politics 40 Jun 20, 2012 03:54 PM
Discussion HK blueseries 8Khz or F-30A 8/16Khz - Simonk FW alfapistola Multirotor Talk 6 Jun 11, 2012 11:26 AM
New Product HK 12A / 40A BlueSeries Brushless controllers CrashingDutchman Power Systems 3 Jan 01, 2011 10:34 PM
Discussion HK 450 - ESC and Engine hot hot hot framos Mini Helis 13 Feb 12, 2010 11:54 PM
