Old Feb 23, 2013, 12:52 PM
Pickering Ontario CANADA
Joined May 2010
Originally Posted by Blade Crasher View Post
Kerry: Take this for what you paid for it. Zip.
But here is an idea to get you what you want. Get some Zener diodes (maybe Radio shack?), maybe about 5 of them. Wire them up in Series so that the "forward voltage" drop feeds into the next diode, etc.
Google " Zener Diodes" and you can read more than you want to know. Or look at this link:
http://www.ehow.com/how_7810346_add-...e-voltage.html
5 diodes, .7v "forward voltage drop" = 3.5 drop, 8.4v - 3.5 = 4.9. About perfect for the tail. Not sure how "hot" this might get though pulling 2-3 amps on the tail through all these diodes...
A single zener is basically what Align sells their tail voltage reduction wire as. The align esc has default volts of 5.5 thus 4.8 at the tail.
If you decide to build this, let me know if it works or you got "zip value" from this crazy idea.
Wow, I think that would be over my head. Thank you very much for your efforts but I think I may have found what I need. http://www.amainhobbies.com/product_...tage-Regulator
My concern is that it is only 1AMP although it is apparently made for the application I have in mind.
Opinions??
Kerry
EDIT: I followed your link which led to another link (re:12V>4V)and directly to the item I had just found.
Helitime is offline Find More Posts by Helitime
Old Feb 25, 2013, 04:02 PM
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Alright, I just followed the setup thing using the Robird application and... Everything seems to be in order. I have no idea what some things meant, (Like the tab with the slider on the right, the one that is green in the middle, red up top and at the bottom, something about 8°) the heli isn't perfectly setup mechanically due to the lack of a swash leveler and pitch gauge. But ehhhh, close enough.
There's one thing that isn't clear to me though... Pitch curves for some simple hovering around, motor connection (on receiver or FBL controller? One channel says "Aileron OR motor", whatever the heck that means), programming of idle up, throttle hold etc. NO info about that whatsoever. So where do I start?
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 25, 2013, 04:40 PM
Joined May 2010
Pitch curves, throttle hold and idle up are transmitter settings. Start with your Tx manual and then you can ask more specific questions.
The 8* thing is cyclic settings. It is important to get these settings at least close. I will let someone else respond to the bal. as I am new to flybarless.
It's a start.
Kerry
Old Feb 26, 2013, 03:41 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Have you read the manual and watched the videos? Whilst the videos are slightly outdated as one or two of the menu screens have changed they will explain most of this.
This screen is to tell the G31 where 8 degrees is, so that the G31 understands your geometry - I'm not really sure how you managed this step without a pitch gauge, this is an important step to a correct set-up. The red - yellow - green indicates how good your servo geometry is.
This is covered in the manual - the G31 can either be set up to use a Rx or to use Satelites, depending on which approach you are using the channel allocation is different.
Not wanting to be too rude, but if you don't read the manual and the set-up tips in this thread you are very likely to have a failed set-up and crash on maiden
MikeHRC is offline Find More Posts by MikeHRC
Old Feb 26, 2013, 05:26 AM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Well, I am exaggerating a bit. :P Most of it looks fine. Everyting moves the right way, it compensates for movement properly, there's no binding no matter where I point the swash or tail. Setting up pitch curves and whatnot is new to me though, I'm not really sure what's suitable for a first hover without any kind of 3D. All channels are hooked up to the right place and so on. Servo arms are at 90° and neutral pitch is at roughly 51-52% throttle right now.
As for the 8° thing, alright, I understand now. Time to work on that.
As for missing parts, that's just what happens when everything you want is not in stock and parts elsewhere are too expensive for what they are. Before the maiden I'm taking the heli to someone who has set up a bunch of helis before.
Old Feb 26, 2013, 06:06 AM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Alright, just went through the setup again and found a way to measure the pitch somewhat accurately. Everything should be OK-ish now. Roughly 12° up and down on the collective, 8° on the cyclic. (Although it's awfully close to the yellow area) About the simulated cyclic right in the last tab, what is a good value to use there, as high as possible without binding?
Some things are difficult to adjust right now, I need to get the ball link pliers at the rc clubs place to make adjustments to ball links, everything else looks good. Shoved another bearing into the tail the other day, it feels very smooth right now.
EDIT: Radio has been set up. So all that remains is to maiden it then. Scary stuff.
Old Feb 28, 2013, 08:37 AM
Good News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
When you do maiden , don't forget to duck
jombo is offline Find More Posts by jombo
Latest blog entry: NH airshow
Old Feb 28, 2013, 10:36 AM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Well, sadly, the maiden sorta failed. Not because of how I set up my radio or the helicopter. Some of the parts were simply way out of balance and caused some really bad vibes that shook the whole thing. I got over the fear after a short time, altho I do feel like wearing safety goggles whenever I'm near these things. If a feathering shaft breaks and you get a blade in your face you'll probably get knocked out or get a massive gash somewhere.
Old Feb 28, 2013, 10:55 AM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
If the parts are that far out of balance you really need to sort that out before flying it
Old Feb 28, 2013, 05:41 PM
USA, WA, Bremerton
Joined Feb 2007
Wiseduck: You really want to make sure the locktite on the feathering shaft nuts/screws is well applied and dry. Having had my 450 blades come loose one time during a low hover at 2800 hs, it's not something I ever want to experience again.
Sorry to hear about the shakes in the machine. The G31 is great and I'm barely a novice user but it makes me look like I know what I'm doing.
You will be thrilled soon when it's sorted out.
Blade Crasher is offline Find More Posts by Blade Crasher
Old Feb 28, 2013, 06:04 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
and by the sound of it the G31 vibration log may well come in very useful!
2Doggs is offline Find More Posts by 2Doggs
Old Mar 01, 2013, 01:47 AM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Well, there's nothing really to see in it. Just huge red bars at 80% throttle on both the main rotor and the tail. The issue isn't the blades, I've spooled it up without blades and it's the main shaft and torque tube for sure. (By huge I mean they max out)
Anyhow, I've already decided to just replace the entire head and buy an Align kit this summer. I'm converting this to a flybarred heli, someone at the local rc club donated a complete flybarred head to me so I'm taking the current one off. (Mine has got a bunch of stripped screws on it, so taking apart the head is almost impossible)
Old Mar 02, 2013, 11:36 AM
Joined May 2010
Electronics question
Considering the ESC's proximity to the G31 and Rx.
Description:
I have placed the ESC where it fits into the frames on the side to get maximum cooling. This puts it about 3" from the Rx+G31. I don't know if it helps but there is C/F between the ESC and Rx/G31. This will also put the 12S battery wires about 3" from the Rx antenna with nothing in between.
Will any of this be a concern ie. can I expect good reception etc. in reference to "electromagnetic something or others".
Kerry
Edit: Ignore the Sat. Rx it will be moved to the front when the long wires arrive.
Don't know how the second pic. got here.
Old Mar 02, 2013, 02:44 PM
USA, WA, Bremerton
Joined Feb 2007
Have you flown your YEP before? This is off topic but I just returned my 80 amp version to HK USA outside of warranty period. Not sure if anything will come of it, but I could never get the ESC to work with any motors. I'm really "down" on this ESC at present, and have wired my G31 govenor into a cheapo ESC for the time being. If you have any thoughts on setting up your YEP I would like to read them.
Old Mar 02, 2013, 02:50 PM
2Doggs's Avatar
Joined Nov 2009
I'm pretty sure Paul1968 uses YEP's, and swears by them - he's often on the 550 thread.
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
