Pickering Ontario CANADA
Joined May 2010
![]() Re ail and ele connections "correct" thank you Re rud gain and pitch/aux. Just wanted to confirm these are signal only (no +or-) wires Re rud and tail servo "correct" thank you Re 6Vpower supply. This was info only (how I am supplying power and the voltage) in case it mattered for my questions. Re gov.and RPM sensor> will not be used. Thank you Re parallel sat.s >My intention was to plug this into the receiver not the G31 but from what you say that probably won't work there either. Re Orange RX> although I have never had a problem with one, I agree and will use the Spektrum AR7000. I have about 5years of R/C heli flying but no FBL experience. Thanks for taking so much time on this, you efforts are much appreciated and I will heed your posting advice. ![]() Thanks Mike Kerry |
Joined Dec 2011
My limited experience with Orange receivers has been mixed -
- with a receiver on a HK250fbl paired with a zyx-s, which has been great so far - with a single sat on a HK550fbl, paired with a g31, and Kerry knows the disastrous result of that one (most likely comms failure), probably due to the esc bec being overloaded. I will hopefully have time to test the "failsafe" tomorrow, to see the mode it failed to, which will confirm the comms failure, and the behavior I do agree to what seems to be good conventions for heli's 500 and up: - use a receiver and sat - use a separate ubec (on 500-550 solder ubec 3-7A, 2-6S connection to main battery in parallel to esc, on 600 upwards separate 3S receiver battery + ubec 8-15A) - for those helis of better quality use original quality equipment (Spektrum/JR/Futaba radio/receivers/sat on Align etc), for clones ok to use Orange receivers/sat. Nobody likes losing any heli though, even the clones, but I am still to have Orange fail on me. Don't understand why Orange sometimes runs a solid orange light, or sometimes blinks, but both fly the same, no comms issue Kerry - Think Mike answered most of your queries re wiring. Let us know what else you may want to clarify |
Joined May 2010
Good for now I think, thank you. My BEC is a 10A cont. 15A burst. Re flashing receiver. I have found anytime I REconnect power to the receiver without waiting about 5 mins since last power on, I get the flashing rec. both Orange and Spektrum. I think the rec. is seeing it as a power/signal loss and just needs more "power off time" to properly reset. The falshing does not seem to affect range or anything else I can find. I believe it's the receivers way of showing there was a problem. Thanks again Kerry Oops, found one we missed. Any issues with my selected mounting locations for the electronics from pics in post #1183. |
Joined Feb 2013
G31 Failsafe: Talked to Scott from Robird USA and he said, rx has to handle the failsafe. But orange sat rx can't do this. So be careful with only two satellite rx. |
Joined May 2010
I thought we where supposed to get wiser with age?
It's not working for me ![]() I just spent 2 hours with an AR7000 that would not power up even though it worked in the glider I yanked it from. Minor breakage to the case trying to get it open, couldn't find anything wrong (I don't know electronics). It did finally hit me ![]() Said to self, BIND PLUG you dumb a_ _. Dam I feel stupid ![]() 2 Hours!!Everything is hooked up. Time to read up on the computer stuff and start setting it up. Then the questions will fly ![]() Kerry Edit: The Orange RX's light up right away. OK Thats my excuse.
Joined May 2010
Downloaded the program, plugged in the G31, it says I have the latest version.
Proceeded to the set up guide...."Receiver" I tried both DSM settings but nothing seems to work (I am using a DX7 with an AR7000)I thought that was DSM. What should I set it to?? What ever PWM is, it shows the connections I am using. Tried the next step......Servos (swash) 1.5ms@125hz or 250hz or 333hz I can't find this info on the servo box. Same for the tail, I searched the net for this info for my Futaba 9254. My swash servos are "Bluebird BMS-820 DMG+HS" What settings should I use or where to find this info?? Thanks Kerry |
USA, WA, Bremerton
Joined Feb 2007
Not sure about bluebirds, maybe at servodatabase.com but there is this for other servos:
http://www.ronlund.com/rcheli/HELP_SERVO_PULSE.html Don't you setup the RX mode with PwM settings? DSM is for SAT only I think, if I remember correctly. |
Joined May 2008
Joined May 2010
Blade Crasher: The link got me what I needed for the 9254. Still searching on the Bluebirds.
Thank you! PhantomLeg PWM it is. Thank you! ( what is PWM anyway or what does it stand for?) Just out of interest. ![]() Thanks again Kerry |
Joined Dec 2011
There was a link previously posted on a fbl system and servo types. Did not list Turnigy so I had to experiment and use servo setup that I thought was closest to that listed. Can't find link now and hope someone else (Scott?) can help - will keep looking. Just tested my failsafe (setup is G31 with one sat) with switching radio off, and it stays where it is - does not move at all. So this means I did not have radio comms failure as the major issue (I was close to the heli). Will test simulating BEC failure next and see what happens. Wish I could have more time to do complete testing... Deon |
Joined May 2010
Thanks for the reply and good luck with the testing. I wouldn't want to fly that bird without finding the problem first. Kerry |
Joined Dec 2011
Tested BEC failure by unplugging - heli just goes dead without any swash movement. So have not found root cause of sudden full pitch. Something in the combination of the G31 and the Sat. So will fit Spektrum receiver plus Orange Sat, 3-7A UBEC, replace all main drive parts with Align items, and carefully balance all blades. Then find a wide open space with no trees (doesn't exist in Philippines) and see what happens. I really liked this heli and its setup, and it seemed to have very good potential as a good value build. Hope not to be disappointed
Oxfordshire, UK
Joined Jan 2007
Something else that might be worth trying is turning on Tx + heli, but disconnect the motor to esc wires, connect your computer to the G31 and have it on the monitor screen. Waggle all wires and switches and see if you see any unexpected inputs on the monitor - it probably won't show anything, but it might. I've heard of the sat wires causing problems (not G31 specific) Cheers, Mike |
| Thread Tools | |
| Discussion New ALZRC 3GY V2.0 FBL System | boredom.is.me | Mini Helis | 125 | Sep 13, 2012 10:58 AM |
| Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 | Mahu | Hot Online Deals | 6 | Jun 20, 2012 03:45 AM |
| Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 | pitchp | Mini Helis | 7 | Jun 10, 2012 10:30 PM |
| Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro | old4570 | Electric Heli Talk | 4 | Mar 15, 2012 10:18 PM |
