Old Feb 02, 2013, 06:37 PM
airbasher is offline
Find More Posts by airbasher
United States, MI, East Lansing
Joined Mar 2008
Hey guys, just finished setting this up for my Protos 500 and since it's too cold and windy lately to fly i've been fiddling and going over it. I went and adjusted the endpoints for the rudder gain channel to match the units output so when it says 50% AVCS so does my transmitter. So now I was wondering if someone could give me a ballpark figure for the tail gain so i'm in the neighborhood for the maiden. Preferably what the unit says in the calibration menu. I'm leaving everything else at the default sport settings for the maiden. Thanks for any advice. Looking forward to better weather.
airbasher is offline Find More Posts by airbasher
Old Feb 03, 2013, 01:22 AM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
I have the G31 on my Protos, but to be honest unless we are running exactly the same set-up sharing numbers is not very relevant - I would start at about 40 ish and see how that is, if you have wag drop a few points, otherwise keep raining it until it wags then drop a few.
MikeHRC is online now Find More Posts by MikeHRC
Old Feb 03, 2013, 08:15 AM
Saschi is offline
Find More Posts by Saschi
Joined Feb 2013
Originally Posted by MikeHRC View Post
Failsafe works fine
What do you use? Spektrum satellite receivers or a standard receiver.
When i bind the sat with help of a standard receiver with failsafe, the sat only on G31 can't manage the failsafe. So for all who are planing to use two satellite receivers... think about it...
Saschi is offline Find More Posts by Saschi
Old Feb 03, 2013, 09:03 AM
deonjams is online now
Find More Posts by deonjams
Philippines, NCR, QC
Joined Dec 2011
Sounds like this could have been my problem - no failsafe when my sat lost power. Will bench test (after disconnecting wires Kerry)
deonjams is online now Find More Posts by deonjams
Old Feb 03, 2013, 11:38 AM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
No insults intended from here, I was responding to the gentlemans first post.
First post is "often or at least sometimes" someone new to R/C so I started with safety first, just in case. It would now seem that Saschi already knows more than me, but no harm done.
I wuz jus tryn ta help
Kerry
Helitime is offline Find More Posts by Helitime
Old Feb 03, 2013, 01:45 PM
Helitime is offline
Joined May 2010
Just noticed my rec.(Orange RX 7ch with fail safe) has an "S Bus" jack. Should I use the S Bus connection method or the standard rec.>G31 hook up. Is there any advantage to one method or the other ?
(I have just finished watching the 18 tutorial vids on youtube)
Kerry
Old Feb 03, 2013, 03:05 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Spektrum DSMX sat (running DSM2) in this case - I tested again yesterday. Switched it all on, turned off Tx and it just sits there, admittedly the motor wasn't on at the time - I can try that if you like. What symptoms are you seeing ?.
I also have a Protos using the G31 with a full receiver - but in that case the Rx will be managing the failsafe - unless I am mis-understanding what you mean by failsafe
Old Feb 03, 2013, 03:20 PM
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Quick update - I just checked my failsafe works fine - started up heli, motor running, turn off Tx, motor stops.
The failsafe is usually be set when you bind the rx / sat to the Tx, did you bind with the throttle at zero?
Old Feb 03, 2013, 06:48 PM
Saschi is offline
Joined Feb 2013
I tried orange satellite rx. Binding with zero throttle. Powered on tx and heli, turned off tx and throttle does not go to zero. Will try DSMx origin rx.
Kerry
Sbus you only use one wire to G31. Just easier to wire it up.
Will geht r710 too to get failsafe if DSMx satellite can't handle the failsafe.
It was my first post, right. But I fly heli for two years now... ;-)
Old Feb 03, 2013, 09:52 PM
Helitime is offline
Joined May 2010
[/QUOTE]
It was my first post, right. But I fly heli for two years now... ;-)[/QUOTE]
Thanks Saschi, Sbus it is.
I was the same, reading RC Groups for several years and flying longer before I made my first post.
Kerry
Old Feb 03, 2013, 11:04 PM
Joined Dec 2011
Kerry
None taken Was just acknowledging a useful reminder to us all, and best to write as if the general reader may not know
Old Feb 03, 2013, 11:37 PM
Helitime is offline
Joined May 2010
Thank you sir
Now it's off to find all the servo info etc. required for set up while I wait for answers to my questions here. I hope "Beenflying" comes back soon. Seems he's the answer guy (not to knock anyone else here) If you have answers I'm listening!
Kerry
Old Feb 04, 2013, 12:25 AM
Joined Dec 2011
Thank you sir
Kerry
Remind us of your current questions that still require answers? Time constraints always a challenge and good when others respond with possible answers, relevant to their experience. I understood s bus as a Futaba and associated equipment standard (like Spektrum, JR being DSMX/S) but it appears from above this is incorrect. We learn as we go along. Learning to fly easier with ARF's but understanding and building another challenge. Good thing I am not learning on my more expensive heli's such as Align 550 and 700 DFC's, which are still happily waiting for their build turn, as I play around with the Blade and HK models
Old Feb 04, 2013, 01:20 AM
Helitime is offline
Joined May 2010
Post 1183 pg79 is most of it (for now)
I am usuing a Spektrum DX7 tx and the 7ch Orange RX with fail safe.
Now 2:20AM here, work at 7 I will check back tomorow PM
Kerry
Old Feb 04, 2013, 03:08 AM
PhantomLeg is offline
Find More Posts by PhantomLeg
Joined May 2008
Kerry
You cannot use the S.bus of the Orange 7ch RX unless your TX can re-assigned the channels because it is outputting Spektrum channels arrangment, different from true Futaba S.bus signal.
PhantomLeg is offline Find More Posts by PhantomLeg
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
