Old Jan 07, 2013, 10:25 PM
krefi is offline
Find More Posts by krefi
rather fly, but this'll do
krefi's Avatar
Portland, OR
Joined Feb 2008
I want an app to do it from my android phone. A guy can dream, right?
krefi is offline Find More Posts by krefi
Old Jan 07, 2013, 10:28 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I'd rather dream about fitness models....
2Doggs is offline Find More Posts by 2Doggs
Old Jan 08, 2013, 12:51 AM
Atomic Skull is online now
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by 2Doggs View Post
I bet the TX manufacturers would love that!
You must be an exception to the rule - most people complain about having to program the controller with a pc, but you want more tabs in the program!
They said they will eventually have a smartphone app for this though.
Atomic Skull is online now Find More Posts by Atomic Skull
Old Jan 08, 2013, 12:57 AM
Joined Dec 2011
I can think of a few uses for this. Like a planker with a 5 channel radio wants to give helicopters a try or using it in an RTF package to lower the radio cost.
Old Jan 08, 2013, 07:33 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Flew 3 full packs on the G31 installed on the VWINRC 450 Pro. It flew well but not as precise and crisp as the HB800.
ridge_racer is offline Find More Posts by ridge_racer
Old Jan 09, 2013, 12:26 AM
SDHeliPilot is offline
Find More Posts by SDHeliPilot
RobirdUSA.com
SDHeliPilot's Avatar
United States, CA, San Diego
Joined May 2012
What settings are you using on the G31?
SDHeliPilot is offline Find More Posts by SDHeliPilot
Old Jan 09, 2013, 10:50 AM
Joined Nov 2010
AS....Your setting are actually a good start for setting up my 450Pro FBL. Thank you..I made a few minor changes
Increased agility to 1600 for elevator and aileron
Increased ele/ail roll rate to 22
Increased swash stop to 120
Added about -20 expo all around.
Seems to work fine with my TGY-211DMH cyclic servos, however I think I might have developed a problem with the ESC. I keep getting random servo movements causing the heli to go down sharply almost like a reset. I'm thinking the BEC is not keeping up (hopefully not the G31). Also noticed the ESC has a slight delay before responding to throttle hold/cut. I ordered an AE-45 and will also replace the rx to be safe.
Same as AS with only the changes above. It kinda feels like I am dangling the heli from a string at times.
Old Jan 09, 2013, 11:34 AM
krefi is offline
krefi's Avatar
Portland, OR
Joined Feb 2008
I get some of these random servo twitches too. I don't think it's related to the ESC because I'm not using the govenor and I have an external BEC running 6V to HS65 cyclic servos.
Old Jan 09, 2013, 03:29 PM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
I had some weird twithes in the servos allso when the weather was cold and dry. I ran a ground wire from the tail to the boom and moter mount and so far everything works fine.
prop bender is offline Find More Posts by prop bender
Old Jan 09, 2013, 04:42 PM
Joined Nov 2010
That was another isolated problem. Broken shield ground on the board for the rx. Installed new rx and all is fine..
Old Jan 09, 2013, 05:03 PM
RobirdUSA.com
Joined May 2012
You may have your Ail and Ele Pitc Gains set too low. Try increasing both gains until you see the heli twitch or oscillate. When you see this occur, back off the gains a little bit until it stops. The heli will feel a lot more locked in and not so sluggish or disconnected when you input a stick command.
It's important to make sure these gains are properly set before making any adjustments in the Performance tab of the software.
Old Jan 09, 2013, 06:33 PM
krefi is offline
krefi's Avatar
Portland, OR
Joined Feb 2008
Yeah, I did the ground wire thing already.
I'm not sure I understand "Broken shield ground on the board for the rx" and why installing a new receiver would fix that? For what it's worth, I'm using a full AR6100e receiver. So you think I might have a defective unit, and if so is it user repairable? It's not really a debilitating problem (so not likely I would try to send it back to HiModel) but kind of unsettling, so I'm never really flying with full confidence.
Thanks for the suggestions, gentlemen!
Old Jan 09, 2013, 10:52 PM
Joined Nov 2010
Krefi...i use a Turnigy 9x radio with 6 channel hobbyking rx. The rx uses a single coaxial antenna that has a ground shield beneath the insulation. Where the shielding is soldered to the rx board was broken. Considering I paid 10 bucks for the rx and I have a spare safer for me to trash it and install a new one. I'm not that great at repairing those antenna leads.
Old Jan 09, 2013, 10:58 PM
Joined Nov 2010
I have them set at the 2 o clock position. The heli response is very fast but it just doesn't feel as natural to me. I will drop the roll rates to 21 but should I increase agility from 1600 to a higher setting or decrease?
Old Jan 09, 2013, 11:25 PM
krefi is offline
krefi's Avatar
Portland, OR
Joined Feb 2008
Gotcha. Thanks. I've got a couple other receivers I might try for kicks then (6 channel orange and a ar6200 laying around).
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
