Old Dec 18, 2012, 07:55 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by SDHeliPilot View Post
Hey guys:
Robird has just released a new software update with two small improvements:
1). Added support for ppm single-line receiver
2). Increased the governor top speed
The update can be downloaded at www.robird.net/G31
Scott
RobirdUSA
Great! That's the only serial option I have with the Hitec, ATM.
Thanks for letting us know, Scott.
beenflying is offline Find More Posts by beenflying
Old Dec 18, 2012, 09:28 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Something odd is happening with the vibration log.
Most of the log entries don't have a max vibration value. Is this normal? It never used to do this.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Dec 18, 2012, 11:42 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
http://static.rcgroups.net/forums/at...Untitled-1.jpg
I think they only add that level to the index when it is over a certain level. Probably what robird thinks is too high and should be looked at.
Old Dec 18, 2012, 11:53 PM
SDHeliPilot is offline
Find More Posts by SDHeliPilot
RobirdUSA.com
SDHeliPilot's Avatar
United States, CA, San Diego
Joined May 2012
You're welcome sir
SDHeliPilot is offline Find More Posts by SDHeliPilot
Old Dec 19, 2012, 12:03 AM
dogjumpjump is offline
Find More Posts by dogjumpjump
dogjumpjump's Avatar
Hong Kong Intl, Hong Kong
Joined Apr 2004
Originally Posted by PhantomLeg View Post
Just connect the whole plug with all the wires into the Rs/Gain/Pit/Ax port like the rest with the whilte wire facing the top of G31.
I have a question that, from manual page the RS/GainPts/AX port is connect to Receiver channel 5 and 6, how can you connect all things(channel 5,6 + RPM sensor) into one port??
dogjumpjump is offline Find More Posts by dogjumpjump
Old Dec 19, 2012, 01:53 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
You can only use the RPM sesnor (and the Governor) when you run the G31 with satelite(s) rather than a full receiver. When you run the G31 with satelites you don't use the 3 into 1 lead.
I'm not sure how this pans out for the latest software (with the single-line receiver) announced yesterday, but it is certainly the case for the Spektrum satelite that I am using on my latest G31
MikeHRC is offline Find More Posts by MikeHRC
Old Dec 19, 2012, 02:56 AM
Joined Apr 2004
Thank you, so I have to change my system to use RPM.. cost too high..
Old Dec 19, 2012, 03:03 AM
PhantomLeg is offline
Find More Posts by PhantomLeg
Joined May 2008
Are you talking about the 2.4Ghz A-FHSS Compatible 5CH Micro Receiver (Hitec Minima compatible) from HobbyKing? Becareful using that in PPM mode because it's PPM signal is not that "pure" and you might experience some servo twitch once a while.
PhantomLeg is offline Find More Posts by PhantomLeg
Old Dec 19, 2012, 03:07 AM
Joined May 2008
You should be happy when you sees this, that means your heli is super smooth without any noticeable vibrations.
Old Dec 19, 2012, 05:58 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yes, that was the one I was talking about. Thanks for letting me know.
Old Dec 19, 2012, 06:08 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
All you need is a Satelite and a RPM Sensor, but yes extra expense
Old Dec 19, 2012, 04:27 PM
DudeInMyrtleBch is offline
Find More Posts by DudeInMyrtleBch
United States, SC, Myrtle Beach
Joined Jun 2011
Ok - after tuning everything mechanically as perfect as I could get, I found that if I set my tx gyro gain at 100%, and the dials on the g31 at 2 o'clock, the tail holds like a rock with no wag. The PC program shows my true avcs at 127. (gently) flew her around the yard, did a few rolls but nothing fancy.
I'm assuming it's ok to run like this? I was under the impression that I wouldn't be able to run it that high.
DudeInMyrtleBch is offline Find More Posts by DudeInMyrtleBch
Old Dec 19, 2012, 05:19 PM
Joined Dec 2011
Is this also the case for the 8CH full range RX or just the 5CH?
Old Dec 19, 2012, 05:23 PM
Joined Dec 2011
If you have the rudder gain set to max it's probably going to cause wagging when the tail is put under stress like in a hard climb or fast sideways or tail first flight.
The only way I've ever been able to get the tail perfect is to center the neutral position at 0 degrees. For some reason the tail only seems to work well when the pitch is equal in both directions. If it's not then it causes all sorts of problems. And while the manual says that centering the slider leads to the CW stop being softer than the CCW stop in my experience it's the exact opposite of this. A centered slider makes for similar CW and CCW stops while a tail set up for rate mode makes the CCW stop much harder than the CW stop.
Old Dec 19, 2012, 09:51 PM
Joined May 2008
No testing has been done on the 8CH yet.
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
