Oxfordshire, UK
Joined Jan 2007
![]() ![]() ![]() That's really good since it means that I can use Aux 2 set to Gear and use EPA's to set Thanks again. Mike |
Oxfordshire, UK
Joined Jan 2007
So I put a few batteries through the Robird equiped 450 today and I have to say that I am very happy with it. As I already knew it is very stable in the air (even using cheap analogues on the cyclic - though they were great when this was Beastx equiped as well), just using standard 3D settings to start with.
I then set up the governor, initially using the Align RCE-BL35X that I was using with using with throttle curves previously. I then swapped to Governor with the Align ESC and it worked very nicely - the headspeed staying very constant throughout the flight. The only slight downside is that with the Align's (excellent) soft-start along with the G31 Govenor's soft-start lead to a really slow start up (the Align 450 ESC slow-start is the yard-stick for soft-starts for me, absolutely fantastic). So I then swapped in a HobbyWing Pertium 40A ESC that I had set up without soft-start to test the G31 soft-start, it's (very slightly) better than the HobbyWing, but still not very soft. So I then tried the Hobby-WIng super soft-start with the G31 and this is OK - not as good as the Align, but better than just the G31. To explain what I mean - I really like the Align as the first 3 or 4 rotations are very slow, but it then quickly ramps up to full speed in about 10 seconds; the G31 does the first few revolutions very quickly, but then takes about 15 - 20 seconds to get up to full speed; the Hobby-Wing goes from stationary to full speed in about 2 - 3 seconds. |
Setup parameter storage?
I setup the G31 on one computer, but intend to continue setup and adjustments on a different computer. Where is the setup file stored so that I can transfer to new computer? (Search has been futile.) Is there an option that will cause setup program to "read" the gyro to capture setup back to the comjputer?
Fly safe, Glover |
Joined Dec 2011
Joined Dec 2011
Joined Dec 2011
So what exactly is a "left pirouette"? I'm confused by this because what "left" actually means depends on what direction you're looking at the helicopter and whether you fly the tail or the nose. The meaning of clockwise and counter clockwise was clear, this is not.
United States, ND, Bismarck
Joined Mar 2012
New Robird G31 software update issued
Hey guys:
Robird has just released a new software update with two small improvements: 1). Added support for ppm single-line receiver 2). Increased the governor top speed The update can be downloaded at www.robird.net/G31 Thanks, Scott RobirdUSA |
| Thread Tools | |
| Discussion New ALZRC 3GY V2.0 FBL System | boredom.is.me | Mini Helis | 125 | Sep 13, 2012 10:58 AM |
| Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 | Mahu | Hot Online Deals | 6 | Jun 20, 2012 03:45 AM |
| Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 | pitchp | Mini Helis | 7 | Jun 10, 2012 10:30 PM |
| Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro | old4570 | Electric Heli Talk | 4 | Mar 15, 2012 10:18 PM |
