Old Nov 15, 2012, 12:06 PM
scribble007 is offline
Find More Posts by scribble007
United States, CA, Yosemite Lakes
Originally Posted by IFHELI View Post
The first 3GY V2 had a black plastic case. The newest one which has a blue label on top has a metal lower case.
Still no RPM sensor?
scribble007 is offline Find More Posts by scribble007
Old Nov 15, 2012, 03:01 PM
SDHeliPilot is offline
Find More Posts by SDHeliPilot
RobirdUSA.com
SDHeliPilot's Avatar
United States, CA, San Diego
Joined May 2012
Originally Posted by scribble007 View Post
Ok
So, I'm about to put the finishing touches on my 6s 450 pro with the robird g31.
I'm going to triple check everything this time.
What kind of settings should I put in?
Use the sport default? or 3d default?
Yes, start out with the Sport settings and if you decide later that they are too tame then go to the 3D settings. After that you can try varying the rates and Agility settings to get the type of flight behaviors you want.
After you complete each of your first few flights under the Sport settings you should come back and hook up your G31 and run the Vibration Analysis tool. You'll have log of the entire flight and you can look for any vibration anomolies that might need to be addressed.
SDHeliPilot is offline Find More Posts by SDHeliPilot
Old Nov 15, 2012, 03:38 PM
IFHELI is offline
Find More Posts by IFHELI
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
No RPM sensor yet. I have two G31s on order that will come w/ sensor.
IFHELI is offline Find More Posts by IFHELI
Old Nov 15, 2012, 04:25 PM
Now should I leave dual rates and expo out of my radio and adjust in the Robird program?
And yeah. I'm a little excited to have the vib analysis.
Old Nov 15, 2012, 05:39 PM
RobirdUSA.com
Joined May 2012
If you're used to setting your Expo in your transmitter you can continue to use that. Otherwise if you want to set the Expo in the G31 Performance tab just remember that the negative values will provide a slower and smoother feel around mid-stick.
Old Nov 15, 2012, 06:58 PM
Hate getting hung up on the little stuff.
Can some one tell me how to bind to the robird when Im using just a dsm2 satalite plugged into the robird?
Do i have to bind the sat to a full receiver then plug it in to the robird?
And how have you guys set the esc?
Analog
or 1.5ms @ 125hz?
ect ect
Old Nov 15, 2012, 08:46 PM
And now that I have solved all of my problems from the previous post.
My tail is acting funny. Its very slow to my control inputs when the light is blue and VERY slowly counter acts tail movements.
But when the light is red, No tail control
This normal?
Old Nov 16, 2012, 01:54 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
This normal?
Assuming this is actually in the air then no it's not.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Nov 16, 2012, 05:06 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
This normal?
Have your read the instructions? Reason I ask is that with many FBL units Red indicates HH mode and Blue indicates rate mode each of which behaves very differently.
Charles
Old Nov 16, 2012, 10:26 AM
RobirdUSA.com
Joined May 2012
New Robird G31 Users Manual released
We've just released a new users manual for the Robird G31 flybarless system. This new manual covers the PC setup process, setting the governor and also provides further details on the settings in the Performance tab.
The manual covers the new 0.98D software version which will be released shortly but the rest is basically the same for the current 0.98C version.
The manual can be downloaded from www.robird.net/g31.
Let us know what you think! This was a collaborative effort and we think you'll find the manual very helpful.
Also, we'll be announcing the website for the U.S. distributor for Robird very soon. Keep watching here for details.
Old Nov 16, 2012, 11:16 AM
Charles
Being that they were posted an hour ago.
No :P
BUT, Now that Iv had a chance. I think I can figure it out.
Amazing how helpful the user manual can be **Turns in man card**
Old Nov 16, 2012, 11:57 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Excellent! This gyro is destined to be the next vbar, for less than half the price.
beenflying is offline Find More Posts by beenflying
Old Nov 17, 2012, 07:52 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
New TGY-211DMH installed on the cyclics...
New Turnigy TGY-211DMH cyclic servo with ALZRC 3GY V2 (Robird G31) (3 min 6 sec)
ridge_racer is offline Find More Posts by ridge_racer
Old Nov 17, 2012, 05:27 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks for the video, ridge_racer. Can't wait to get my 211's.
Did you get a chance to try other servo arms, or did you just use the ones supplied?
Old Nov 17, 2012, 07:14 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Now that is some pretty tall praise...
Originally Posted by ridge_racer View Post
New TGY-211DMH installed on the cyclics...http://youtu.be/V7FfyrTRJzk
these ought to be better than the Solars... they cost twice as much. But are they twice as good?
Dr.M is offline Find More Posts by Dr.M
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
