Old Nov 11, 2012, 07:42 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
www.rctodayshow.com
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Originally Posted by scribble007 View Post
The splines inside the servo wheels are what stripped out..
That sounds like you had the wrong type of servo wheel. I've never had that happen on any of my FBL helis, even using plastic arms. If you have the wrong ones (for a different brand) it may seem to fit, but will strip out under a load.
Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Nov 11, 2012, 08:20 PM
scribble007 is online now
Find More Posts by scribble007
United States, CA, Yosemite Lakes
The fit on snugly. And had 23t like my servos. So I thought the were the right ones. Said "J" on it. for JR right?
scribble007 is online now Find More Posts by scribble007
Old Nov 11, 2012, 08:24 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by IFHELI View Post
It looks like my original thought of the CW/CCW brake setting gets reversed when you select tail servo reversed is wrong.
No but it does work backwards from the way everyone assumed.
I decided to raise max rate on tail to 72(720*) and played some more with CW/CCW and acc. values.
Does max rate have any effect on stop bounce?
Atomic Skull is offline Find More Posts by Atomic Skull
Old Nov 11, 2012, 09:32 PM
Joined Dec 2011
Well my first attempt at flybarless was a big failure.
I put on those align servo wheels. But they were to soft and stripped out causing me to loose control.
What servos are you using? Sounds like you may have the wrong kind of wheels. Generally there are three types of servo horns with several different sizes of each. The three main types are Futaba, Hitec and JR. There are some custom ones out there too but usually they fall into one of those three and 90% of the time it's a Futaba spline.
Old Nov 11, 2012, 10:23 PM
Its the exi 227f servo
Which I THOUGHT was JR splines. But guess I was wrong.
So Im going to have to put the old servo arms back on. Blades and need a new main shaft.
Old Nov 11, 2012, 11:00 PM
nismo240 is offline
Find More Posts by nismo240
Worcester, MA
Joined Oct 2003
Srx
Where can additional SRX adapters be bought to run 2x satelites?
nismo240 is offline Find More Posts by nismo240
Old Nov 11, 2012, 11:24 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
This one for the 3GY v2 will work with the G31:
http://www.oomodel.com/alzrc-satelli...0-p-64018.html
beenflying is offline Find More Posts by beenflying
Old Nov 12, 2012, 02:53 PM
Joined Dec 2011
No the EXI and Solar servos use a custom spline, they can use each others horns though (they come from the same factory)
Also they have fragile wiring that will eventually vibrate loose, or at least the smaller ones do (larger ones might have better wiring but I haven't checked). If you see any evidence of shaking or odd behavior in flight immediately check the servos.
When I build my 600 I'm going to be using these.
http://www.hobbyking.com/hobbyking/s...6sec_61g_.html
I've been using the standard voltage high speed version as the rudder servo on my 500 and it stays cool and works flawlessly. They have a standard version of this but for $4 difference might as well get the HV version as performance is the same at 4.2v and 6v anyway and the components are probably a bit more robust to handle the higher voltage. They use a three stage gear train which is very smooth and quiet (or at least it is in the high speed version). The case and gear train looks suspiciously like certain JR servos and I wonder if they aren't compatible (do they copy or are all these cases and gears coming out of the same factory I wonder?)
Some have said that Blue Arrows 333hz spec is wrong and they should only be run at 280hz but I haven't had any problems, the tail servo I'm using doesn't even get warm. They are very "chattery" servos when at rest, though they aren't as loud as the smaller 280xxx series Mi servos.
The picture is now wrong, they updated the case so they look like this now:
Old Nov 12, 2012, 03:38 PM
I must have counted wrong.
Im acutally very happy with the exi servos. I have well over 100 flights on them, and never had an issue. Though, If I see a good deal on some aligns Ill prob jump on that.
Old Nov 12, 2012, 05:57 PM
IFHELI is offline
Find More Posts by IFHELI
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
Atomic Skull,
I do believe upping the max rate did help. On the two helis I set to 3CW and 4CCW brake I had always had to do 1 & 3 on brake. I`m still alittle confused on why the MiniTitan w/ the black 3GY is at 1 & 1 on brake since it has a KST servo on tail like the other MiniTitan.. Looks like there are more test flights for this one...
I hope to get some more flights in this weekend if it`s not to cold.
IFHELI is offline Find More Posts by IFHELI
Old Nov 13, 2012, 08:22 PM
Joined Dec 2011
Atomic Skull,
The 3GY V2 is the metal case version?
Old Nov 13, 2012, 08:35 PM
IFHELI is offline
IFHELI's Avatar
Joined Apr 2010
The first 3GY V2 had a black plastic case. The newest one which has a blue label on top has a metal lower case.
Old Nov 15, 2012, 12:25 PM
SDHeliPilot is offline
Find More Posts by SDHeliPilot
RobirdUSA.com
SDHeliPilot's Avatar
United States, CA, San Diego
Joined May 2012
This is the Maximum Yaw Rate with each unit being measured in 10 degrees per second. Think of it as the Speed Limit for your tail: you can go 360 degrees in one second or 720 degrees in one second.
The "Stop Bounce" is controlled by the Left and Right Piro Brake setting. Increasing this value gives you harder stops during piros in the noted direction.
SDHeliPilot is offline Find More Posts by SDHeliPilot
Old Nov 15, 2012, 01:00 PM
2Doggs is online now
Find More Posts by 2Doggs
Ask Mike
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
...and in general you have to find a compromise between hard stops with bounce or softer stops without bounce....
2Doggs is online now Find More Posts by 2Doggs
Old Nov 15, 2012, 01:05 PM
Ok
So, I'm about to put the finishing touches on my 6s 450 pro with the robird g31.
I'm going to triple check everything this time.
What kind of settings should I put in?
Use the sport default? or 3d default?
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 11:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 04:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 11:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 11:18 PM
