Old Jul 10, 2012, 11:29 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
This is my rule for Trex FBL cyclic and tail arm lengths:
250 cyclic ~10.5mm - tail ~5mm
450 cyclic ~12.5mm - tail ~8mm
500 cyclic ~18mm - tail ~10mm
550 cyclic ~21mm - tail ~13mm
Note, some heads have different length blade arms, which can require these lengths to be altered.
beenflying is offline Find More Posts by beenflying
Old Jul 11, 2012, 09:07 AM
cgriffith is offline
Find More Posts by cgriffith
cgriffith's Avatar
United States, FL, Oviedo
Joined Apr 2011
thanks BF, I think I'll print that out and hang it on my fridge.
cgriffith is offline Find More Posts by cgriffith
Old Jul 11, 2012, 11:13 AM
Kauaiguy is offline
Find More Posts by Kauaiguy
United States, HI, Kalaheo
Joined Jan 2011
Vibra-analysis
I've been tweaking my heli and have got my vibs below 200 on the vibra- analysis .At 3050 or higher it doesnt show any vibs, at 3000 to 2950 it's around 220.Pretty cool but I wonder if it's that accurate or more for show?just installed four Kst ds215 servos and running them at 7v, awesome!
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Jul 11, 2012, 04:22 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Steve
The vib analysis sounds like a nice feature. I wonder what the possibilities of a bluetooth link are, with this gryo.
Those KST215's should be amazing at 7 volts. Let me know if you had to lower the gain any, and what did you use as a BEC to get the 7 volts?
Old Jul 11, 2012, 04:55 PM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
I used Hercules SuperBec/w 7v option, configured 7.4v output voltage for KST DS215. though 7.4v (no load) a bit high for DS215 operating at 7v under load, no issue at this moment.
wlee1017 is offline Find More Posts by wlee1017
Old Jul 11, 2012, 05:00 PM
Kauaiguy is offline
Joined Jan 2011
Didn't have to lower gain but probably should add some expo till I get used to it!I am using the castle ice 50 with internal 5a bec.Seems at this voltage the battery life is shorter.Are higher voltage servos more or less efficient ( comparing the two Kst ).Also do you think 5a is enough with four Kst 215 at 7v?
Steve
Old Jul 12, 2012, 08:20 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks for the info.
Steve
Usually higher voltage less current is more efficient, but since these servos are operating faster, because of the higher voltage, then they will use more power.
5 amps at 7 volts should be fine for those servos.
Old Jul 14, 2012, 05:33 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I've updated the second post with installation details and a test flight video.
Old Jul 14, 2012, 06:21 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Mine arrived this morning - better read the manual now
MikeHRC is offline Find More Posts by MikeHRC
Old Jul 14, 2012, 06:31 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
It doesn't sound as if you are very impressed ???
Old Jul 14, 2012, 06:56 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Let's just say the jury is still out on this one. I've only been flying the 500's and 550 recently, but last time I flew the 450 pro with the 3GYS v1, I though it flew better than with this gyro.
The first flight was a real shock. It felt like I was flying a 450 with the Align 3GX (bad). Increasing the gain made a big difference, so now perhaps it's just a matter of getting used to it and used to flying a 450 again.
I'll take it to the field and see how it performs with a bit more space to do some 3D.
Old Jul 14, 2012, 07:25 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
OK, thanks. I've just been watching the set-up videos and the set-up software looks very good
Old Jul 14, 2012, 10:36 AM
Kauaiguy is offline
Joined Jan 2011
Hey Beenying, just curious as to what servos your running during your test?I no the Robird team has been using the Kst 215's and they work great just wondering if servo speed and resolution has a part in your results.one more question, what's your vibra log look like, are you able to keep the numbers below 200?
Steve
Old Jul 14, 2012, 11:04 AM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
I was going to put this on my Protos, but I'm slightly nervous from a couple of BF's comments, so I will put it on my old Copterx 450 that used to have a Beastx on it, and is almost identical to a Clone 450 that currently has a 3X1000 on it - it will be interesting to compare
Old Jul 14, 2012, 11:12 AM
Kauaiguy is offline
Joined Jan 2011
Left is still on your left and the elevator can be in front or behind the swash.It will correct for everything as you set it up.Both my Beam and BlackAngel have the elevator in back.
Steve
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
