Old Jul 08, 2012, 02:44 PM
Kauaiguy is offline
Find More Posts by Kauaiguy
United States, HI, Kalaheo
Joined Jan 2011
That is much more interesting, I want one!
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Jul 08, 2012, 03:52 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I knew Robird was a name I've heard before!
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 08, 2012, 06:09 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by Kauaiguy View Post
I made a YouTube video with the Robird in my Beam on a windy slope !Nothing fancy but it does show how stable it is in winds over 30 mph!Not sure how to link the video from my IPhone.Tags: Stevekauai, Robird
Did another video with the Cx on a BlackAngel in 30 to 40 mph ( not on YouTube) but anyone wants a clip of that p.m. me and I will send , it really shows the disc stability of the Robird when you compare the two videos, also the Robird was doing most of the work.
Steve
Thanks Steve. I'll link it here for you:
Robird G31 /Beam E4 Dfc head (3 min 56 sec)
beenflying is offline Find More Posts by beenflying
Old Jul 08, 2012, 06:13 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by Daddy. View Post
Sorry to go OT....was looking to see your Robird wind vid and found this Robird instead...I didn't know such a thing existed! Or was technologically possible!
http://www.youtube.com/watch?v=bT3-vIxT-DY
Gosh, that's incredible. I never though they would be able to get the power to weight ratio good enough to do it, and to fly for that long. Thanks for sharing.
Old Jul 08, 2012, 09:38 PM
Kauaiguy is offline
Joined Jan 2011
Question about blade balancing
I used weigh my blades to balance, but recently I've been using a blade balancer. The two methods don't agree, blades can be level on the blade balancer but different weights.Whats the best way?Newbie question I know but I don't no the answer.
Steve
Old Jul 08, 2012, 09:51 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The balancer is the best, but you really should be checking the CoG as well. See this video:
Collective Pitch RC Heli Blade Balance & Setup Tips (1 min 48 sec)
This product from Infinity Hobby makes doing the CoG much easier:
http://www.infinity-hobby.com/main/p...oducts_id=7211
Old Jul 09, 2012, 01:15 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
That is the fanciest blade balancer I've ever seen.
So what's the verdict on the Robird G31?
Dr.M is offline Find More Posts by Dr.M
Old Jul 09, 2012, 02:53 PM
Kauaiguy is offline
Joined Jan 2011
Works great out of the box, easy to setup,software is easy to update( I'm no computer whiz so it has to be easy)Rotor disc seems much more stable compared to my Cx, probably because I wasn't able to run gains higher than 36.The lead slug in the base seems to really dampen vib feedback,vibra- analysis feature gives a flight log of head speed/tail speed ,vibration frequency and strength , pretty cool.I like it!!!
Steve
Old Jul 09, 2012, 05:03 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I haven't had the time to fit my 3GY yet, but opinion so far, from those that have, seems very good. It should be my next project, now that the 500 SDC head is installed.
Old Jul 10, 2012, 08:01 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I flashed the gyro up on the bench tonight with a full set of servos and played with the PC app. I setup all of the channel directions and went though all of the setup to see what it did. It all seems very straight forward.
Found out one of my Emax ES08MD servos will only work set to analog. Looks like it has the wrong label on it and is probably a ES08MA. This would explain why I had one servo that seemed to work at a very different speed to the others on the tester.
Old Jul 10, 2012, 04:06 PM
Kauaiguy is offline
Joined Jan 2011
What is the suggested servo arm length for a 450?
I'm running mine at 12.8, next hole in is 10mm,What are you guys running at?
Steve
Old Jul 10, 2012, 04:10 PM
Joined Nov 2007
Mine is ~8mm from center.
3DPRO DS9257MG
0.048sec/60
3.1 kg-cm / 43oz-in
Old Jul 10, 2012, 04:11 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Both of my FBL 450's are using ~12.5. The 250 uses 10-11mm.
Edit: This for the cyclic. The tail is ~8mm.
Old Jul 10, 2012, 04:18 PM
Joined Nov 2007
My cyclic is about the same: ~12.5mm.
3DPRO S410MG
Old Jul 10, 2012, 04:34 PM
Kauaiguy is offline
Joined Jan 2011
Thanks guys, I have the tail at 8mm also,on the Cx thread there using 10mm for cyclic , so I just wanted to be sure of the setting!
Steve
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
