Old Aug 05, 2012, 09:46 PM
Daddy. is offline
Find More Posts by Daddy.
Everyone is an idiot (or I am)
Daddy.'s Avatar
United States, TX, Red Oak
Joined Jun 2012
My 500 had a couple episodes of wobbles again yesterday. Today I stayed close...did great. Just came in from a second pack...no wobbles but it was like a backward elevator trim and right cyclic trim were on and had to keep the right thumb busy. No changes and double checked trims (none).
Anyway, why this thread, has anyone put a g31 on with just power for a vib log? I'm thinking I can run a a jumper from rx or zyx to power the g31 and fly. Do you think I'd even have to set it up?
Yes, I may replace the zyx with the g31 but I want to know if it's the zyx causing these problems. Would like to keep the zyx as my cx on my 450 is solid as a rock and would like to have the same unit on both birds.
Ken
Daddy. is offline Find More Posts by Daddy.
Old Aug 05, 2012, 10:26 PM
SDHeliPilot is offline
Find More Posts by SDHeliPilot
RobirdUSA.com
SDHeliPilot's Avatar
United States, CA, San Diego
Joined May 2012
Tarot 450ProV2 with the Robird G31
OK, I am soooooo close now.
The servos made all the difference. I received the KDS 215MGs and put them on. The setup was fast and without problem. Previously I tried several Henges and some Align servos and none of them made it through the Setup phase. I fried a few servos along the way.
So it appears that the Robird G31 isn't very tolerant of different servo brands. Your thoughts?
I throttled it up and right before lift-off it rolled to the right and I lost a set of blades to the asphalt. A couple of more attempts with the same results and now my shop garbage can is looking like a scrap heap for blades.
I have read others posting here about the same problem - the heli being tipsy. I'll go back and re-read the posts and see what you guys are doing.
Keep up the good work guys!
SDHeliPilot is offline Find More Posts by SDHeliPilot
Old Aug 05, 2012, 10:37 PM
Kauaiguy is offline
Find More Posts by Kauaiguy
United States, HI, Kalaheo
Joined Jan 2011
Check your vib log and see what it showed just before the crash, it will probably read pretty high( above one thousand).Also if you set your cyclic pitch higher than 8 degrees it will have a wobble tendency.Make sure your wires to your gyro aren't to tight but I'm pretty sure vibs is the problem.
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Aug 05, 2012, 10:57 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Helicopter seems more stable now that I leveled the swash at min/max collective and equalized the travels. My elevator link is crooked no matter how you mount the servo and was causing slightly unequal travels. Hopefully they add this to the setup program because having to do it on the gyro is annoying.
No matter how much revo mixing I use there is always a bit of yaw in a full speed instant climb (i.e.jamming the stick from hover to full climb). Is this normal? I'm using this motor and a 4S battery.
Also the climb rate is terrifying, is there any way to limit max pitch to 11 degrees?
Atomic Skull is offline Find More Posts by Atomic Skull
Old Aug 05, 2012, 11:03 PM
clearprop88 is offline
Find More Posts by clearprop88
Joined Apr 2011
I had my first flights this morning after repairs, and a run through the set up.
I put the training rig on for the first flight because I expected it to tip. Even though the swash looks level it still wanted to tip to the left. I got the heli just light on the training gear to see if the disk would be level, it wasn't, I added some right, and back trim to level the disk, set it back down, and did the runup again. This time the disk was pretty level, and I could take off, and fly it without the training gear.
I agree with Steve that it's probably a vibration problem. I have spikes at 1800, and 2350. I replaced the main shaft, and inspected the FS. So hopefully when I fly it again it will be more stable.
clearprop88 is offline Find More Posts by clearprop88
Old Aug 05, 2012, 11:05 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Have you set the tail gyro gain to the highest setting first before wag then backed it off a little? You want to run the highest gain possible first then start added collective to tail compensation. As for the collective pitch you can limit it by using the collective pitch tab and a pitch gauge.
ridge_racer is offline Find More Posts by ridge_racer
Old Aug 05, 2012, 11:07 PM
Kauaiguy is offline
Joined Jan 2011
Change your pinion one tooth smaller or reduce your throttle curve ,not sure what heli your flying ,at 3000 headspeed my tail rotor on the Beam is at 14000 rpm and on my BlackAngel it's 12500 according to the vib log.Both heli's climb straight in pitch pumps and I'm running about the same power as your motor.If you have a TT tail they spin slower and can kickout if your headspeed is below 3000.
Steve
Old Aug 05, 2012, 11:28 PM
RobirdUSA.com
Joined May 2012
Tarot 450 Pro V2 with the Robird G31
Thanks Clearprop88: I went into the Adjust menu and levelled the swash at min pitch, mid pitch and max pitch. I will run it up tomorrow and see if that helps to eliminate the "tipsy" behavior. Also, on the Adjust menu my control behaviors are set to steady blue
Like yourself, I thought the swash was pretty level but it wasnt.
I have the control dials on the G31 set to their original positions,12:00.
So theres nothing radical in the settings and I think its just a matter of finding what I need to tweak.
Old Aug 06, 2012, 12:11 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Mine seems to tip to the left if you look at it from the tail. I am going to try out some good servos for it to see if that helps. So far the fbl and the servos will cost 4 times more than the heli . It seems on takeoff it wants to be a flybar
jombo is offline Find More Posts by jombo
Old Aug 06, 2012, 12:38 AM
Joined Dec 2011
I'm running the gyro gain as high as I can without wag. The yaw only happens when I jam the stick hard from hover to full climb instantly, it with either yaw a few degrees or if the gyro gain is too high it will wag as it climbs.
Old Aug 06, 2012, 12:51 AM
Joined Dec 2011
Ino labs HGD-202 carbon gear (not metal they are slower) or Hitec HS-65MGs if you want quality servos that aren't ridiculously priced. The Hitecs are analog but have a 2 year warranty, the ino-labs can run on a 333mhz signal (not sure about any warranty on these). If you had a Sport I'd recommend the HGD-260HB's and HS-82MG's as well, they actually cost less than the micro servos (need the modified upper frame panels for those)
Best cheap servos I've found are the Corona 929 digitals and the HK relable version (which is a bit cheaper and has a weaker case) They're the only ones I've found with decent internal wiring and soldering. Resolution is ok, I've seen them used successfully with a ZYX.
You running the digitals at 250 or 333mhz? Many "normal" digital servos (i.e. not tail servos) can't run on a 250 or 333mhz signal. Unless it's a tail servo it's usually safest to assume it can't use a high frequency signal unless the specs say otherwise. And even then with the really cheap servos it's not a good idea to run them that way even if the specs say they can.
My take on cheap servos is that once you get up into the $10-$15 range you might as well just spend a little more for something that's not junk. The only cheap servos I'll use now are the 929 digitals and only in something I don't care too much about like my backup HK beater helicopter.
Old Aug 06, 2012, 04:06 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
If the G31 works the same way as the Beastx then it uses the CollPit screen to learn the geometry (as it does with the CycPitGeom), so you would want to keep setting that to 12 degrees.
What you could do though is check the maximum / minimum collective pitch and use Dual Rates to limit the collective pitch to 11 degrees
MikeHRC is offline Find More Posts by MikeHRC
Old Aug 06, 2012, 07:58 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I personally think it's safe to adjust the collective pitch away from 12 degrees in the ColPit tab, as the gyro learns the geometry in the next tab ColPitGeom, where you set 8 degrees.
The other option is to adjust the pitch curve, so you get +/- 11 degrees.
beenflying is offline Find More Posts by beenflying
Old Aug 06, 2012, 12:03 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
i don't remember since i did mine a way back but i wasn't too sure of how much i wanted to test this out on. i think i ended up setting it up to -10+10 and 6 on the cyclic. i was having some weird pitch changes until i made my pitch curve linear and raised my throttle curve . it was a bit fast still on the cyclic , i ended up raising the expo and d/r . also on the 8FG i can set the swash ring like expo but does something separate to expo.
Old Aug 06, 2012, 12:20 PM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Hmmm, interesting - but it's not ColPitchGeom - it's CycPitGeom - the manual suggests (to me a least ) that the G31 is learning both the Cyclic and Collective Pitch - it calls these settings "Positive/Negative collective pitch geometry Cyclic pitch geometry"
BF - do you have yours set to 11 degrees as this might be a cause of your slow collective ....
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 11:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 04:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 11:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 11:18 PM
