Old Aug 02, 2012, 08:46 PM
Atomic Skull is online now
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by Kauaiguy View Post
You might have some binding developing in the tail slider assembly ?Right servo frequency,servo going bad?Let us no what you find?
Steve
Already checked that, mechanically there is nothing wrong with the tail. HSG-5084 is 333mhz 1500us. Servo was working perfectly 2 days ago with the old gyro.
Atomic Skull is online now Find More Posts by Atomic Skull
Old Aug 03, 2012, 02:52 PM
Kauaiguy is offline
Find More Posts by Kauaiguy
United States, HI, Kalaheo
Joined Jan 2011
I set my max rate on the slider control under performance settings for both to 24 and my cyclic pitch speed is very fast now but didn't seem to change roll and yaw speed as much, just an FYI if your looking to speed up cyclic pitch speed.
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Aug 03, 2012, 05:31 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Can you please clarify this, Steve, as I think it's important. Do you mean cyclic pitch or collective pitch and did you mean to use yaw?
BTW, congrats on 1000 posts.
beenflying is offline Find More Posts by beenflying
Old Aug 03, 2012, 06:15 PM
Kauaiguy is offline
Joined Jan 2011
I set max rate on aileron to 24 and elevator to 24.Makes pitch changes quicker but doesn't seem to make it roll or flip faster. Sorry for the wrong terminology , it's easy enough to give it a try and go back.
Steve
Old Aug 03, 2012, 06:21 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
That sounds backwards. Pitch doesn't change with the rates.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Aug 03, 2012, 06:22 PM
Joined Dec 2011
Last night I completely tore down the tail, replaced all bearings, changed out tail rotor shaft and checked that bell crank was completely free. Still had the same problems with the HSG-5084. Is it possible for ail/elv gain to affect the tail? I was trying out an Emax tail servo and having similar problems. I noticed that the helicopter was wobbling visibly during piros so I lowered the elv/ail gain pots to try to get rid of this and the tail seemed to get better. I'll try the HSG-5084 again later.
How do I know when I have the elevator and alieron gain set right? The helicopter never develops the shakes and I can pretty much just max out the pots and the only effect is that it tries to tip over on the ground and wobbles during piros.
Old Aug 03, 2012, 08:17 PM
Kauaiguy is offline
Joined Jan 2011
I just reset my other heli to 22 on both and again my cyclic changes pitch quicker but doesn't speed up the roll and flip,maybe it's mislabeled?Has anyone else tried ?
Steve
Old Aug 03, 2012, 08:22 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks, Steve. I'm about to try it myself. I had also noted in the 7HV video in post 4, that they were using 26 and 23, and I was planning to try that this weekend.
Old Aug 03, 2012, 08:47 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I just flew 26 aileron and 23 elevator, and it definitely has an affect on the collective pitch, so thanks for suggesting this, Steve. It almost seems to be a combination of damping and agility, on the cyclic, which is also reflected into the collective pitch.
My advise with this gyro would be to fly as high a setting on the Maxrate's, as you feel comfortable with. As you progress past just hovering, aim for max rates 22 or above and use expo to reduce the sensitivity.
My advanced settings for this flight were:
Old Aug 03, 2012, 09:44 PM
Kauaiguy is offline
Joined Jan 2011
That's what I thought was going on but I mostly feel it as quicker pitch with a little affect on Aile and elev.Im going to up mine a little at a time!
Steve
Old Aug 03, 2012, 09:48 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I'm really happy with this gyro now. Just had another flight and, if anything now, I feel I could remove the extra half a degree I added to the collective pitch. I really enjoyed throwing it around this time.
Negative pitch descending forward flight, pulls out smoothly now, whereas before it would always bounce back up, unless I was really careful.
The tail seemed a bit more sensitive around middle stick then I'm used to with my normal expo setting, yet the piro speed was about right for me. Perhaps that why I've seen others with -25 in the gyros tail expo.
Gyro gains are still at 3 o'clock. Increased tail brake CW to 4 and tail MaxRate to 58.
Old Aug 03, 2012, 10:17 PM
Joined Dec 2011
Problem solved I think. When I mounted the gyro I thought it would be a good idea to not use the cheap foam pads it came with, so instead I put some fusano gyro tape on either side of the metal plate and used that. As it turns out this was a bad idea. I remounted the gyro with just the grey foam and the tail holds perfectly now.
I still don't like this stuff though, it lets the gyro wiggle around too much and when you plug in the USB cable it can twist the gyro out of alignment slightly. Anyone know of any good quality flybarless gyro mounting pads that can replace this stuff?
Old Aug 03, 2012, 10:26 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I use this foam on all of my gyros, including the 3GY v2 and the beastX. No straps needed and flies great:
http://www.infinity-hobby.com/main/p...oducts_id=7649
Old Aug 03, 2012, 10:33 PM
Joined Dec 2011
Is there a US source for that?
Old Aug 03, 2012, 11:03 PM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
AMains hobbies has a verity of double sided tape. I don't know if it's the same as beenflying uses though.
prop bender is offline Find More Posts by prop bender
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
