Old Jul 30, 2012, 02:25 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Will it work to have the positive and negative power lines on only one of the cyclic connections between the receiver and gyro and just have the signal lines connected on the other two? I ask because I'm making short servo lines to go between the gyro and receiver and it will be easier to have all three leads in a single piece of 1/8 flexo if I can eliminate the positive and ground wires from two (5 wires vs 9)
Atomic Skull is offline Find More Posts by Atomic Skull
Old Jul 30, 2012, 05:58 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
This gyro needs power to the rudder input and also power to either the aileron or elevator input.
beenflying is offline Find More Posts by beenflying
Old Jul 30, 2012, 11:51 AM
Kauaiguy is offline
Find More Posts by Kauaiguy
United States, HI, Kalaheo
Joined Jan 2011
Running all the power through just one set of power lines may be marginal for the cyclic?
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Jul 30, 2012, 05:36 PM
SDHeliPilot is offline
Find More Posts by SDHeliPilot
RobirdUSA.com
SDHeliPilot's Avatar
United States, CA, San Diego
Joined May 2012
KauaiSteve
KauaiSteve - I saw your video on YouTube last night. I knew when I saw the title "Robird G31 with a Beam E4" that it was your bird. Thanks for sharing it with us and I added my "Like" vote. - SDHeliPilot
SDHeliPilot is offline Find More Posts by SDHeliPilot
Old Jul 30, 2012, 06:46 PM
Kauaiguy is offline
Joined Jan 2011
I'm glad you liked it, it's a great flying area but usaually windy!And finding my heli after a crash is also fun( lots of wild pig down in the valley and heavy under growth)!I emailed Skyhobbies about the firmware update but haven't got a reply yet, maybe if more of us contact them they will give us an answer?
Steve
Old Jul 31, 2012, 12:01 AM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
Hey guys. Just curious how the 3gy is holding up? I used to be huge into 3D heli's until I got side tracked, ended up selling most of what was usable on my 450. I flew the pants off of it for a year with Align 3gx.
Well now I have that itch again, But really dont want to spend another $600+ on a fully built up Align 450 3gx.
My passed experience with clones is less than adequate. the HK stuff was junk.
However I ran across ALZRC and it looks like decent quality. Saw one in person and was very impressed for it being a clone! That being said a knock off for ~$300 looks pretty damn good, if it holds up even 90% as well as my align. How does the 3GY hold up? IS it a decent gyro when compared to 3GX etc?
Thanks guys! really trying to scratch that itch!
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Jul 31, 2012, 10:59 AM
Kauaiguy is offline
Joined Jan 2011
Reply from Sky Hobbies
Got an email from Sky Hobbies:
Hi Steve
Not to sure about the pitch change speed mentioned by you as we do not have this issue.Next update covers the governor function and parameters.we are still waiting but was told soon hopefully Aug.
Best Regards
Derrick Tan
Sky Hobbies
Old Jul 31, 2012, 05:52 PM
Joined Dec 2011
Personal experience with ALZRC is that it's not as good as Tarot. At least the plastic 450 Sport bottom plates I bought weren't as good as the Tarot ones (plastic is more flexible, lacks the zip tie holes at the front) and the pack of main shafts were very slightly off true (Tarot shafts are perfect and I have no reservations about using them). I like ALZRC's stainless steel feathering shafts. I can't tell you about their CNC parts though.
Old Jul 31, 2012, 09:05 PM
MartinSloan71 is offline
Find More Posts by MartinSloan71
Joined Sep 2010
ALZRC and tarot are quite similar in many ways, both are nice copy of align
MartinSloan71 is offline Find More Posts by MartinSloan71
Old Jul 31, 2012, 10:11 PM
Kauaiguy is offline
Joined Jan 2011
Check out the Beam E4 Advantage fbl kit,Amainhobbies has it in usa(California).No up grades needed, frame is roomy so you can easliy fit everything in and it is very tough,the frame sides are1.75mm thick and replacement parts are also very reasonable.Its made in South Korea, very high quality and will save you money in the long run.I have a Copterx Black Angel also but it's not in the same league( more typical of the Trex clones but slightly better ).The Beam is the only heli that I would purchase again (There's a new SE version that has a Beam Dfc head and innovative tail mechanism soon to be released).
Steve
Old Aug 01, 2012, 01:49 AM
Joined Dec 2011
Maybe this is a dumb question but where is says "servo left" and "servo right" do they mean looking from the tail or from the nose? I can't find anything that clarifies this.
Old Aug 01, 2012, 02:18 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I'm glad I'm not the only that got majorly confused. I still can't answer that question though...
boredom.is.me is offline Find More Posts by boredom.is.me
Old Aug 01, 2012, 02:21 AM
Kauaiguy is offline
Joined Jan 2011
I hope I have mine right , I went as viewed from the tail.
Steve
Old Aug 01, 2012, 10:03 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Steve
And I followed Steve's lead and went from the tail as well, so letf viewed from the tail
Mike.
MikeHRC is offline Find More Posts by MikeHRC
Old Aug 01, 2012, 04:04 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Yes, from the tail. Think about which side of your car you would call the left or right side.
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
