Old Jul 20, 2012, 05:26 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Originally Posted by SDHeliPilot View Post
Oh, I forgot to also mention this oscillation is happening as the heli is stationary. That is to say I am not adding any throttle (its at zero). I don't want to spool it up until I know that the tail is moving when I give it inputs.
Set the tail servo to analog. See if that helps.
ridge_racer is offline Find More Posts by ridge_racer
Old Jul 20, 2012, 05:31 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Do you think it might have been something with that particular servo?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 20, 2012, 05:37 PM
SDHeliPilot is offline
Find More Posts by SDHeliPilot
RobirdUSA.com
SDHeliPilot's Avatar
United States, CA, San Diego
Joined May 2012
Problems with the G31
It might have been as the second tail servo doesn't seem to be getting hot (yet) like the first one did. But even it it was a faulty servo that doesn't explain why the replacement is acting weird. That's why I'm thinking it's something outside of the servos, something somewhere else.
SDHeliPilot is offline Find More Posts by SDHeliPilot
Old Jul 20, 2012, 05:57 PM
Joined Nov 2007
I know I'm going over some pretty simple stuff, but it doesn't hurt to cover all littles things before assuming its a bigger issue. Try grounding your tail boom.
What version are you running? My led status pattern changed when I updated it.
Old Jul 20, 2012, 09:06 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Hey guys - I've installed a G31 on my Tarot 450 and have had multiple difficulties along the way. I've worked my way thru almost all and have succeeded in getting thru the entire programming process. I am ready to maiden the heli, or at least I thought I was.
When I plug the flight battery in and initialize the system the tail servo starts oscillating back and forth. It doesn't seem to be in the center anymore and although I had previously set the tail endpoints the servo arm sits further away from center (with the rudder stick at mid-point). When the servo is oscillating like this the rudder stick has no affect on moving the tail. The tail sensor direction works intermittently.
The tail servo is a Henge MD922. The link ball on the tail servo is set to the innermost hole (nearest to the center). The cyclics are Henge MD933. The servo frequencies for both are the same: 250Hz.
I upgraded the firmware to the latest version before I started the programmimg process.
Any ideas?
Hi SDHeliPilot. Thanks for the PM and sorry for the delay replying. I just got back from a few days away with very limited internet access.
Reading all of your posts I'm starting to think you have a faulty gyro. It sounds very similar to an issue I've read about the CX-3X1000.
It also reminds me of one of the cheap digital cyclic servos I was using to test this gyro. The only way it would work, was if I set it to analog. Does the 922 work on analog. Do you have any other brand of digital servos you could try.
beenflying is offline Find More Posts by beenflying
Old Jul 20, 2012, 10:24 PM
RobirdUSA.com
Joined May 2012
Reading all of your posts I'm starting to think you have a faulty gyro. It sounds kvery similar to an issue I've read about the CX-3X1000.
Beenflying-
Thanks for responding. I have some Align servos that I can try out as well as another gyro.
I checked my wiring (suggested in another post) and it all looks good. As for changing the tail servo setting to "analog" the only options I see are either digital .or 760uS in either the PC or transmitter stick setups.
Old Jul 21, 2012, 01:02 AM
Kauaiguy is offline
Find More Posts by Kauaiguy
United States, HI, Kalaheo
Joined Jan 2011
The henge 922 is 1520us and 250hz if you where to run it at 760us it might be trouble.
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Jul 21, 2012, 01:27 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
SDHelipilot,
It does sound very strange, one suggestion - check in the first s/w screen that you aren't getting the changing values on the rudder channel on the "monitor" screen just to ensure that you haven't got a Tx / Rx issue.
Good luck,
MikeHRC is offline Find More Posts by MikeHRC
Old Jul 21, 2012, 06:04 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Beenflying-
You're welcome. Sorry, I hadn't noticed there wasn't an analog option for the tail servo, only for the cyclic. Stick with the 1.5ms@250Hz setting, but try the Align digital servo and see if it does anything strange. Also keep as eye on it's temperature.
Please let us know whether the servo or the gyro is the issue.
Old Jul 21, 2012, 05:11 PM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Here's a quick (but not very good) video of my Protos with the G31 / 3GY V2 - it's taken with a hat-cam and it appears that I follow the heli with my eyes rather than turning my head - I was tryign my best, but it still keeps disappearing from shot. I'm using a "spy-cam" that seems to make things closer than they seem - the people at the end are about 80 metres away, even so I should probably have landed sooner
Protos G31 (4 min 25 sec)
Old Jul 21, 2012, 05:56 PM
Kauaiguy is offline
Joined Jan 2011
Align Dfc swash
Installed a Align Dfc swash on my 450 Beam, there's a lot of slop in the bearing and the bushing that slides on the mainshaft is loose.Not a upgrade on the Beam, made my vib levels go from below 200 to over 450 and then I had to turn the gains down to 12:30.Its coming off and back to my slop free Beam Swash.Just thought I'd let you guys know not to waste your money on slopy bling!
Nice flying Mike, your heli sounds solid!
Steve
Old Jul 21, 2012, 09:10 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Updated post # 3 with some other (non private) videos of Gavin Broadbent flying the robird G31.
Old Jul 21, 2012, 09:20 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Video of a Gaui X7 with the robird G31. Blade scrapes at 1:40.
Robird G31 on X7.wmv (3 min 0 sec)
Old Jul 21, 2012, 09:47 PM
Kauaiguy is offline
Joined Jan 2011
I put on another 17 flights, 120 so far and only had a non binding happen twice which leaves the unit led green , reconnected battery and then it did bind( maybe I bumped it?)So far I really think this gyro is a big set forward!!
Steve
Old Jul 21, 2012, 11:19 PM
RobirdUSA.com
Joined May 2012
You got it sir. I have switched out the first G31 with a new one and attached all ofthe leads. I have updated it to version 0.97a. I'll do the setup programming in the next few days and let you know how it goes.
Discussion New ALZRC 3GY V2.0 FBL System boredom.is.me Mini Helis 125 Sep 13, 2012 10:58 AM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
