Joined Dec 2010
My pushrod has been holding up fine so far after pulling out in a crash. I've had about 4 flights since and it's been great! Finally I can do back flips consistently! mCpx would either blow out the tail or simply lose power and fall out of the sky for me when I tried, and i've been too worried about breaking my 450 to do much experimenting. Been flying the 130x over tall/soft grass and I can crash it from 10-15 without much problem.
United States, TX, League City
Joined Jun 2008
My tail blade shot off and made a decent scratch on my arm. This was out of the box on a idle up (70/60/70) tail in hover check. Hit throttle hold and it fell to the ground, only damage is my scratch on arm, semi stripped crown gear, broken tail pitch control (little nub sticking out the bottom) and tail blade.
Time for a week without a heli |
Joined Oct 2007
Grounded for now... I hope Horizon Hobby will replace it! Issues since new are: -Loose (floppy) main and tail blades -sloppy tail pitch slider mechanism -tail pitch slider guide pin fell off in flight -overheated servo But the worst one of all is that now I'm grounded from flying my most favorite heli !!!!!!! PS .... I have adjusted each of the 3 gyros to take out some the observed shake (from head?)(elv/ail adjusted to 5 clicks, left of center). I have adjusted the tail gyro to 5 clicks (stick-selections) to the right of center. |
I think my tail control problem was due to a broken-off tail pitch slider pin. I drilled it to the bearing and super glued in a toothpick and it seemed to fly well for one tame test flight and the toothpick held up. Will have to give it a few hard flights to really test it out now. Here's a bad picture of my repair.
| Thread Tools | |
| Discussion Blade 130x tail servo flaw | Howeroll | Micro Helis | 5 | Jul 03, 2012 06:15 PM |
| Discussion Any hobby shop in ct, ma or ri stocking blade 130x yet? | HeliStyle | Micro Helis | 4 | Jul 03, 2012 09:46 AM |
| Discussion So, the Blade 130X and it's battery...charging/balancing? | sertav | Batteries and Chargers | 16 | Apr 23, 2012 05:56 AM |
| Discussion How's the Blade 130x? | sertav | Electric Heli Talk | 1 | Apr 18, 2012 12:22 PM |
