Old Jul 04, 2012, 01:10 PM
Asatorae is offline
Find More Posts by Asatorae
Joined Jul 2012
Control, channels, mixing and servo query - absolute beginner!
Hello there, I'm completely new to the RC flying scene and I have been throwing caution to the wind in order to have a bit of fun with a first-time project.
Here is my query, my model is a bi-plane (think Sopwith Camel) to have an elevator, a rudder and four ailerons. My initial plan was to have one channel for yaw control via the rudder, one channel for elevator control and two channels for the aileron sets (left and right). Each of these channels using one respective servo. (It may be possible to initially just use the elevator and rudder for flight making this question redundant but I will aim to have aileron control at the end of the day). So, getting to the point, how do I configure the controls to allow for the ailerons to all move in the same direction when the elevator is used AND get them to move in opposite directions for cornering/rolling?
I've heard the term mixing floating around but I'm not sure what this involves; would it be the case that I could mix the pitch control of both the elevator and the ailerons onto a single channel?
Also, how could the aileron servos be configured such that one channel can be used for 'left and right', as it were, it seems that needing to use a channel for each side seems a bit complex - can servo wires be connected such that multiple channels' signals can affect the same servo?
I'm not sure I've explained myself as succinctly as possible, but rather than toying around with servo connections and rendering tens of pounds worth of equipment unusable, I thought I'd seek some advice.
Regards,
Asa.
Asatorae is offline Find More Posts by Asatorae
Old Jul 04, 2012, 02:22 PM
600Bob is online now
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
I don't know just what you are trying to do. Maybe for some type of wildly aerobatic model you might use some of the mixes you are asking about but for a Sopwith Camel type of biplane I can't see it.
For general sport flying I don't even use mixes, I want to fly the plane not my computer transmitter.
It is common to use one channel for elev and rudder and two for aileron. You would use a 6 channel receiver (RX), plug a "Y" lead into the ail channel and your two right ail servos into the Y. Do the same thing for the left ail servos plugging them into the AUX1 channel. Your TX would be set to Dual Ail wing type, or maybe Flaperon.
600Bob is online now Find More Posts by 600Bob
Old Jul 04, 2012, 03:45 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
It would be more fun if you learn how to fly an RC plane before trying to build your own and do all the fancy mixing and such. Just trust me on this. You could even just build a simple 3-channel trainer to learn on.
The ailerons will be controlled by one transmitter channel. Using two aileron servos means you either need to use a Y-lead or flaperon mixing, where one servo is in the receiver's aileron spot and one is in the flap socket.
Yes, as long as you have some decent dihedral in the wings.
This would be a combination of flaperon mixing and a secondary elevator-to-flap mix. However, this type of setup is extremely unnecessary and is much more likely to cause difficult control. It's sometimes known as "snap flaps" and is occasionally used with fast racers to change the overall camber of a wing (via flaps) which increases the wing's lift and allows faster, sharper cornering. For 99% of planes, it is REALLY not needed. You can experiment once you're proficient at flying, but you don't want strange things happening while learning.
It's not so much "left" and "right". One transmitter channel will control as many servo outputs (receiver) as your radio will allow. I explained flaperons earlier. If you want you can connect servos via a Y-lead, but then you have no individual control of the two servos. You cannot plug one servo into multiple channels, though. The effect must be achieved through transmitter mixing.
The big question is which radio you have, or which one you're planning to buy. Some are capable of damn near anything, and some are totally dunderheaded with no mixing whatsoever. Multiplex's EVO series (German manufacturer) is really incredible in its flexibility, for example, whereas most Asian-styled stuff (JR, Spektrum, Futaba etc.) is a little more rigid but still incredibly capable at the higher end. For what it's worth, most decent radios will include flaperon mixing. Many also allow a couple "free" mixes with user-assignable channels.
Piece is offline Find More Posts by Piece
Old Jul 04, 2012, 05:11 PM
Asatorae is offline
Joined Jul 2012
Thank you for the quick responses, it seems I should be able to fly the plane just on the rudder, elevator and simple aileron control using three channels.
To simplify my original point, how has the modeller here configured his TX and servos to allow for the range of control shown and how many channels would this require?
http://www.youtube.com/watch?v=P9Qc0jmgASA
Regards,
Asa.
Old Jul 04, 2012, 05:27 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Regards,
Asa.
If you are really looking for advice to keep from wasting tens of pounds then forget all of that control mixing garbage and self built biplanes and buy an airplane that is purposely designed to help a beginner learn to fly. Then find an experienced RC flyer to help you.
Before trying to emulate that monstrosity, you might look for a video that shows it can actually fly, and more importantly, that it is even controllable.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jul 04, 2012, 05:36 PM
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
You need at least 4-channels for throttle, rudder, elevator and ailerons. For the setup in that video you will need either a 5 or 6-channel receiver and a transmitter with flapperon programming or programmable mixes. However the plane in that video isn't for someone who has never flown before.
I agree with the others you should build a 3-channel trainer first (throttle, rudder and elevator), or better yet get one that's already built like the hobbyzone champ or super cub. You will have a much better chance of success, not to mention fun (crashing a plane you just put a lot of time into building isn't fun). There are plans in the foamies (scratchbuilt) section for trainers that you can build such as the blu-baby or ezfly. You can also buy these in kit form with some of the work done for you (EzFly and Blu-baby). I also would suggest building it out of EPP as it's very tough and easy to fix. If you build it make sure to plan out your build, take your time and get it right. If you do a sloppy job on building it won't fly well (something a beginner really needs for their first plane).
You should also read the six keys to success for new pilots, it covers the most common mistakes beginners make. You may also want to look into buying a simulator and seeking out a local club or an experienced rc pilot to help you learn how to fly.
Rayne is offline Find More Posts by Rayne
Old Jul 04, 2012, 05:46 PM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
While I think that some of the answers to your questions were a bit harsh, I think the advice is solid. Flying your self built bipe should be left for the day when you can honestly handle a trainer type aircraft. A good solid 3 channel plane like the Hobbyzone Super Cub will get you in the air and give you some practical experience with orientation while flying. I have been flying my 3 channel airplanes now for about 3 months and recently graduated to 4 channel. My first flight on the 4 channel went well, my second, not so much. I ended up crashing and finding my plane about a mile from where I thought it went down. Up until then, I had only crashed one of my planes once, and that was on it's maiden flight. A good simulator would help immensely too. In this hobby, it is essential to take baby steps and not jump into advanced aircraft too quickly. That is, unless you don't mind destroying your plane.
chucksolo69 is offline Find More Posts by chucksolo69
Old Jul 04, 2012, 05:59 PM
Joined Aug 2011
The plane in the video has 2 aileron servos on the bottom wing, the top 2 are linked with a rod to the bottom pair.
What I saw was basically a standard setup. However the ailerons were set to work as Flaperons and Spoilerons, which is less common and not needed to fly a plane. That is when the ailerons all go down, Flaperon, and all go up, Spoileron. That is not a mix so much as a function of the wing type selected in the TX. I could be wrong but I don't believe a DX6i TX could do both spoilerons and flaperons but I can do it with my DX8. It would take a 6 channel RX to set those functions up.
1) Throttle
2) Ail (right wing)
3) Ele
4) Rud
5) Gear (not used)
6) AUX (Left aileron)
Old Jul 05, 2012, 03:37 AM
Asatorae is offline
Joined Jul 2012
Thank you for the replies, I think I'll stick to a simple three channel set up to start with.
It is not my intention to fly my model myself as I refuse to plough several weeks/months work into the ground the moment it gets (or doesn't, as the case may be) in the air.
For me the fun/challenge was always going to be in the construction of the vehicle and the relevant systems rather than flying it, that is someone else's realm.
Regards,
Asa.
Old Jul 05, 2012, 11:33 AM
Joined Aug 2011
To avoid confusion when talking to people at hobby shops or wherever you might buy parts or when asking for advise you should know that a "3 channel set up" would be:
1) Throttle
2) Ele.
3) Rud
Ailerons are not used with a 3 channel. If you want a plane with ailerons it would be a 4 channel setup. Unless of course it is an un-powered sailplane
Old Jul 05, 2012, 12:45 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
1) Throttle
2) Ele.
3) Rud
Not necessarily. A huge number of three-channel planes have throttle, elevator, and aileron control and simply do away with the rudder.
Old Jul 05, 2012, 12:48 PM
prefabu is offline
Find More Posts by prefabu
Kansas City
Joined Dec 2009
If that's the case you should build whatever kind of plane interests you. I think it would be helpful to know how to fly, but that's certainly not necessary. I lived with two aerospace engineers in college, and they were designing airplanes and testing aspects of flight performance without any real flight experience.
If you do want to learn how to fly, the traditional 3 or 4 channel trainer is the best way to go. Even so, there's no rule against building more than one plane!
prefabu is offline Find More Posts by prefabu
Old Jul 05, 2012, 01:12 PM
prefabu is offline
Kansas City
Joined Dec 2009
Check out the ER9X project if you want to learn more about mixing. The actual goal of the project is to replace the firmware in a particular type of radio, but they have a related project called eepe (links are on the same page) that includes a very handy radio simulator utility. Download eepe, read the ER9X manual, and watch some of the instruction videos on youtube. It's quite easy to create some very sophisticated mixing setups.
The ER9X mixing is more flexible than what is available on most radios. There are no built-in mixes that group several individual mixes together. That can sometimes make it more tedious, but I think it better illustrates what is happening "behind the scenes". So, even if you have no interest in the various 9X projects or radios, I suggest you check out eepe as a resource for learning and experimentation.
Old Jul 05, 2012, 01:32 PM
Joined Aug 2011
Since the OP hasn't flown I was thinking of trainer type planes, how many beginner planes are designed that way? The 3 channel rudderless planes I have seen are a PZ P-51 and a very large F-86, not really what I was thinking of at the time
Old Jul 05, 2012, 07:11 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I'm still amused by that no matter how many times I see it. Real pilots can look at an airplane and know if it will fly or not, but aerospace engineers run equations on computers and play with billion dollar wind tunnels for five years and come up with a plane so tail heavy even Chuck Yeager can't fly it. Amazes me every time.
My advice is to learn to fly, and more importantly, learn to own an aircraft, before you try to design one... trust me, with literally thousands of airplane designs out there, you aren't going to come up with anything original at your current skill level, and you might design a beautiful plane that handles the stresses of flight just fine, but if the wing breaks on the car ride to the field, the owner of aircraft is not going to be happy with you.
When you have some flying experience then you will understand how to build an airplane properly so that it not only flies well, but is a joy to own. Many of the designs coming out of China right now show that they don't understand that at all.
jasmine2501 is offline Find More Posts by jasmine2501
For Sale 32 Channel Servo UART Controller board unit ihor14448 Non R/C Items (FS/W) 0 Jun 21, 2012 06:43 PM
Discussion Scratch Build that fly easy for absolute beginner jjfi30 Foamies (Scratchbuilt) 13 May 30, 2012 10:11 PM
For Sale 32 Channel Servo UART Controller board unit ihor14448 Non R/C Items (FS/W) 3 May 02, 2012 08:43 PM
Discussion Parrot "Absolute Control" patent betsi Multirotor Talk 1 Apr 07, 2012 03:26 PM
Discussion DX6i Radio Mixing query zagiflyer67 Electric Plane Talk 0 Mar 10, 2012 05:17 PM
