Old Jul 10, 2012, 11:26 AM
owlsabie is online now
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
She is coming on fast! Looking good
owlsabie is online now Find More Posts by owlsabie
Old Jul 12, 2012, 07:53 AM
rabidrue1 is offline
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
Thanks owl-hows the sportster? get to fly it yet?Got some done on the fleet before work this morning,one forward fuse side has the doubler glueing up under 10liters of water filled soda bottles.I used 1/16" hard balsa placed cross grain for most of the doubler with a1/16" ply insert where the wing bolt block will be to save a bit of weight.The works is glued with elmers newest wizz/bang wood glue wich is the reason for the 10liter press.The idea at this point is to build one side and copy it to get a mirror image for the other one.I need to dig out some aluninum and make up the rib pattern for the wing so I have it to cut the wing sadle area.
rabidrue1 is offline Find More Posts by rabidrue1
Old Jul 12, 2012, 10:23 AM
owlsabie's Avatar
South Africa
Joined Feb 2009
Hi there - the sportster is pretty much sorted, I just need to set up the radio and linkages. Maybe this weekend. . ..
Old Jul 14, 2012, 07:50 AM
sdy. ny
Joined May 2007
Side #2 is in the press,I'll post some photos when I start to join things up.
Old Jul 16, 2012, 07:51 AM
sdy. ny
Joined May 2007
I forgot to bring the card with the photos and will post them later,the sides are joined to the first three formers and 3 layers of 1/16" sheet is drying on the tube to later be laminated to form the front hatch and planking.
Old Jul 17, 2012, 08:39 AM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Coming on nicely Rab. Like the "hi-tec" press
Sundancer is online now Find More Posts by Sundancer
Old Jul 18, 2012, 07:54 AM
sdy. ny
Joined May 2007
Front top sheet is done and will be left to dry for a few days before the hatch is cut.The cockpit opening is roughed out,so its time to start on the cowl.
Old Jul 22, 2012, 08:08 AM
sdy. ny
Joined May 2007
I've been cutting wood like a rabid beaver,the cowl is shaped and the rear bulkhead fitted along with a mid point bulkhead to hold the fuse square.The bottom 1/4" sheet will be added later to give me room to drill the dowel holes at the front of the wing.I took some time this morning to take the modified skylark out for a bit.Powered by an e flite 25 and two 2100ma 3 cell lipos and a 12x7 apc prop the thing will move right out but still lands slow enough to keep me out of trouble.If the warden will let me I plan to finish what I can of the fuse today,the nose gear and bracket have yet to show up but I should be able to finish the rear deck and most of the sanding.
Old Jul 22, 2012, 09:33 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Making serious dust there Rab! It's starting to take shape nicely.
Old Jul 22, 2012, 09:50 AM
cd_webb is offline
Find More Posts by cd_webb
United States, AR, Hope
Joined May 2009
Very little can compare to the feeling you have after all the extra parts of wood are knocked off and what you're left with is something like that! It's sometimes tough for me to "see" the shape inside the wood blocks and get it out of there. Looks like you did it! Nice work, Rab.
cd_webb is offline Find More Posts by cd_webb
Old Jul 22, 2012, 02:47 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Starting to take shape now Rab. And lots of mess on the floor to prove it
sparks
sparks59 is offline Find More Posts by sparks59
Old Jul 22, 2012, 03:32 PM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
sparks
It keeps the bench a lot less cluttered than mine....!!!
Colonel Blink is offline Find More Posts by Colonel Blink
Old Jul 31, 2012, 03:54 AM
owlsabie's Avatar
South Africa
Joined Feb 2009
Looking great Rab!
Build Log KK Gipsy for Britkit build off kkphantom Vintage & Old-Timer Designs 169 Jun 27, 2016 03:57 PM
Build Log Britkit Build Off May 2012-31/12/2012 - Keil Kraft Sportster x1.8 Sundancer Vintage & Old-Timer Designs 66 Aug 17, 2013 10:45 AM
Discussion "Britkit" Build Off April 2012 - 31/12/2012 Sundancer Vintage & Old-Timer Designs 303 Jan 01, 2013 03:47 PM
Build Log Britkit Build Off April 2012 - Veron Deacon cd_webb Vintage & Old-Timer Designs 66 Sep 22, 2012 06:54 AM
Build Log BritKit Build Off 2012 - Mercury Crusader RFJ Vintage & Old-Timer Designs 66 Jul 28, 2012 06:34 AM
