Joined Jul 2012
Plantraco kit help.
Hi, for a science project I recently ordered a Deluxe Starter Set #2 from plantraco. However, when the kit arrived we noticed that the parts weren't as we expected and we had been given the Micro9 4 Channel PlugnPlay 0.95g Receiver instead of the 3 channel receiver.
Once we had read through the pretty bad instructions we assembled all the components and initially the motor spun momentarily but unlike the instructions stated the receiver did not make any tune. We then removed the battery and tried again but this time not even the motor responded and all that happens is the actuators vibrate. We have been re-reading the instructions and trying everything to get it to work but the receiver doesn't seem to respond. We emailed Plantraco about whether the new receiver was not compatible with the other components and they told us it should work and that we were given the 4ch as they had sold out of the 3ch. So really we're a bit stuck and any advice would be much appreciated, thanks.
If you are going to fly with three channels use the aileron (for rudder control) and elevator sockets and leave the rudder socket empty.
The 4ch works the same as the 3ch. Noise comes from the coils not sure which ones. Test all your actuators. Either use a multimeter on ohms, you should read something between 50 and 100, or a single LiPo battery which will just move the actuator to full motion. Its easy to break the thin wires so handle them very gently. If you do not get any resonse from the meter or battery, then you have a broken wire, most likely at the coil end which is very hard to ocate and solder up, I have never been able to do it but others have. You can also test the RX outputs by inserting the motor plug into the actuator sockets but do not move the sticks to full movement as the motor may draw too much power for the rx. The other common problem is the Bohama magnet contacts. I have seen tiny bits of dirt or even glue in or around the magnets which prevent the magnets making proper contact. You can clean grit out with stickytape but may need a sharp model knife to remove glue spots. |
Joined Jul 2012
Well I checked all the things you suggested today and they worked as you said they should so I really have no idea what we've done wrong, here's a picture of how we've got it set up just in case it's something really stupid.
![]() http://www.rcgroups.com/forums/showa...0&d=1341593075 |
Leave the motor unconnected for the time being.
Power on the TX and connect the battery. Report exactly what the LED on the RX does. You should get some tones from one of the actuators even if the the transmitter and receiver do not sync up. Try moving the aileron actuator to the rudder socket and repeat if it makes no noise. You may not be able to hear the tones if the bare actuators are just sitting on a soft cloth. Set them on the bare table top, a piece of glass, or something else that the vibrating actuators can resonate on and listen carefully. It will probably only be a faint "buzz". Generally, you should get a "happy" series of tones and then a count of the channel it is using. If the LED is flashing regularly at about 2 sec. intervals, move the sticks while watching the actuators. They will appear to slam from one extreme to the other because there is no physical load on them. |
Joined Jul 2012
| Thread Tools | |
| Question Plantraco transmitter | bjornkipper | Indoor and Micro Models | 7 | Jul 03, 2012 12:16 PM |
| Discussion Plantraco experimenter's kit, soldering | PerfectStranger | Indoor and Micro Models | 1 | Dec 14, 2007 09:20 PM |
| Wanted NIP Plantraco Micro Racer Kits | DesmoHead | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Nov 17, 2007 06:19 PM |
| Sold FS: Plantraco Micro Components & Shoe String Racer Kits ($300 takes all) | Draconious | Aircraft - Electric - Micro & Indoor Airplanes | 15 | Nov 03, 2007 12:09 AM |
| Sold Plantraco Butterfly Kit | Flyboy70 | Aircraft - Electric - Airplanes (FS/W) | 1 | Jan 14, 2006 03:23 PM |
