Old Oct 03, 2012, 12:08 PM
Jose5x5 is offline
Find More Posts by Jose5x5
The ground is my Enemy!!!
Jose5x5's Avatar
United States, CA, Crestline
Joined Aug 2008
Don,
I am in the process of building my Phase3 f16 with your Wicked Plus 4000KV motor and 60a ESC but the power wires from the the esc does not reach the cockpit area. Is it ok to lengthen the two wires on the esc as you did in you build log without any ill effects?
Jose5x5 is offline Find More Posts by Jose5x5
Old Oct 03, 2012, 03:59 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Yes I extend the wires all the time.
Don
The Don is offline Find More Posts by The Don
Old Oct 03, 2012, 05:16 PM
eranrc is offline
Find More Posts by eranrc
eranrc's Avatar
Joined Feb 2010
Phase 3 EF16 with Don's Wicked RC 4000KV motor (2 min 15 sec)
I love my setup!
eranrc is offline Find More Posts by eranrc
Old Dec 06, 2012, 08:40 PM
CrashMaster39 is offline
Find More Posts by CrashMaster39
Add your country to profile:)
CrashMaster39's Avatar
Joined Oct 2006
Originally Posted by Jose5x5 View Post
Don,
Hey There Jose,
I have lengthened the two battery wires before as well, with no noticeable problems.. But,,,, surprisingly, it is definitely preferable to lengthen the 3 motor wires instead, if possible. Current gets pulled out of the battery in pulses, and the longer those battery wires are, the higher their resistance and the more the ESC input voltage will fluctuate. They say if you need really long battery wires, you should put bigger capacitors across the ESC inputs to supply the pulses of current needed. Apparently when people have problems with too long battery wires, the damage they see is to the smaller stock capacitors on the inputs to the ESC. If you are using an oversize ESC, it will have bigger caps and is less likely to have an issue with long battery wires. Thicker wires should help too, less resistance (but heavy). There, more than you ever wanted to know. Its time to get that Falcon airborn
Greg
EDIT: Just read the rest of the thread and I see that he is only talking about adding 3 inches or so to that battery leads, that is nothing. I would not hesitate to do that, even 5" or so is no big deal. So, nevermind
CrashMaster39 is offline Find More Posts by CrashMaster39
Old Jan 20, 2013, 01:10 AM
Jose5x5 is offline
Jose5x5's Avatar
Joined Aug 2008
Hey Don,
Well after having my kit for over a year I finally maiden my jet with Dons Wicked 4000 Plus with a 4s 2650 nanotach. I just wanted to say HOOOOOOLLLLYYY COW !!!!!!!. I wish I would of finished this sooner. But I did fiberglass the whole plane minus the canopy and coated it WBPU and lightweight Spackle. Here is a video of it flying today and a picture. Dons Recommendations exceeded my expatiation. I measured 990 watts @ 59 amps. Super fast and the jet gets small super fast, but I love it.....
Maiden of Phase 3 f-16 with Dons wicked motor (3 min 36 sec)
Thanks to Crashmaster39 for the video
Old Jan 20, 2013, 10:13 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Thanks for posting the video! Which fan unit is that the HET 6404? or the stock 70mm fan unit?
Don
Old Jan 20, 2013, 11:08 AM
Jose5x5 is offline
Jose5x5's Avatar
Joined Aug 2008
Don
That was the EDO Type I fan.
I had everyone asking about my setup.
Thanks again Don
Old Jan 20, 2013, 11:53 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Your 990 watts made me think it was the stock 5 blade rotor or the HET 64mm fan. In any case glad you like it!
Don
Old Jan 20, 2013, 01:46 PM
Jose5x5 is offline
Jose5x5's Avatar
Joined Aug 2008
I pretty sure it was the EDO fan maybe the watt meter I used wasnt accurate, but either way it was smokin fast.
Old Feb 10, 2013, 07:14 AM
FlyBoyKB is offline
Find More Posts by FlyBoyKB
FlyBoyKB's Avatar
USA, OH, Cincinnati
Joined Dec 2003
Don - Do you have any of the Phase 3 F-16 kits with your recommended balanced motor/ fan and ESC available? If so what is the cost?
kb
FlyBoyKB is offline Find More Posts by FlyBoyKB
Old Feb 10, 2013, 09:16 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
I do not have any F16 kits.
Old Feb 10, 2013, 09:42 AM
FlyBoyKB is offline
FlyBoyKB's Avatar
USA, OH, Cincinnati
Joined Dec 2003
Don - What is your recommendation for a balanced fan/motor ESC system and its' cost?
Old Feb 10, 2013, 10:27 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Depends how fast you want to go, do you want to glass the airframe, what lipos you want to use etc. Everyone has different goals. The setup I used in my build is listed at the beginning of this thread and the speed was about 105-108 mph. Here are the various 64mm setups I sell for the F16. You can follow the links to see the prices.
http://www.rcgroups.com/forums/showp...21&postcount=2
If you want a 70mm setup I now carry the Wemotec 70mm fan and HET 2W-18 motors. That will be the fastest setup and the most costly. They are here:
http://www.donsrc.com/cart/index.php...gory&cat_id=25
Old Feb 10, 2013, 12:27 PM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
Don, the setup I got my F-16 months back, STILL ROCKS!! Thank you :-)
Old Nov 29, 2013, 11:41 AM
hobbyist2 is offline
Find More Posts by hobbyist2
Joined Jun 2009
Originally Posted by cbr600f2 View Post
Hey Don,
I'm runing your same set up that I ordered from you and the balancing and a 40c make all the difference in the world. My thrust tube is at 80% FSA. I have no problems with hand lauching with that tube and the top end is simply amazing ! Nice work on the plane and on your recommendation for fan/motor set up.
Does the thrust tube come with the fuse only kit?
If not where is a good place to buy it?
hobbyist2 is offline Find More Posts by hobbyist2
Discussion ... WyoRip Electric Ducted Fan Jet Talk 1 Jan 05, 2015 12:17 AM
Help! Hobby People Phase 3 F-16 lv2soar Foamy EDFs 3 Feb 22, 2010 10:33 PM
