Old Jul 15, 2012, 03:21 PM
eranrc is offline
Find More Posts by eranrc
eranrc's Avatar
Joined Feb 2010
Informative Thread and a nice setup Don!
eranrc is offline Find More Posts by eranrc
Old Jul 15, 2012, 04:36 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
I flew two flights today on some brand new 4S 2200 40C packs and boy was it hauling. We had about a 10 mph wind down the flight line and some of my passes via RCspeedo were in the 125-130 mph range (that is with a tailwind on the fresh pack). This is really an awesome light setup on this model, glad I used it. I had a blast flying it today.
Don
The Don is offline Find More Posts by The Don
Old Jul 15, 2012, 04:59 PM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
Don
Please check out ya PMs please :-)
Old Jul 18, 2012, 09:09 PM
cbr600f2 is offline
Find More Posts by cbr600f2
cbr600f2's Avatar
United States, NY, Rochester
Joined Nov 2007
Don
Hey Don,
I'm runing your same set up that I ordered from you and the balancing and a 40c make all the difference in the world. My thrust tube is at 80% FSA. I have no problems with hand lauching with that tube and the top end is simply amazing ! Nice work on the plane and on your recommendation for fan/motor set up.
cbr600f2 is offline Find More Posts by cbr600f2
Old Jul 18, 2012, 09:18 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Glad you like the setup. People are amazed when I take out the lipo and hand them the model which is only 16 ounces less lipo, they can not believe how light it is and also how fast.
Don
Old Jul 18, 2012, 11:18 PM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
Don
That's cool ;-) Pretty soon I hope to enjoy the F-16 setup as well!
Old Aug 03, 2012, 03:08 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Don,
What was the FSA on your thrust tube for your set up? Thanks.
DamonH is offline Find More Posts by DamonH
Old Aug 03, 2012, 03:43 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
80% fsa
Old Aug 09, 2012, 05:16 PM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
My Phase 3 EF 16 using a Wicked plus EDF 4400 KV motor watt meter test....
Wicked Plus EDF Motor 4000KV with Cobra ESC watt meter test (0 min 51 sec)
Old Aug 09, 2012, 05:35 PM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
I wasn't planing on flying with a 4 cell TP 1800 mAh battery... It was the only battery around during the video :-) Those are my 450 pro helicopter batteries that are really beat!
Old Aug 26, 2012, 08:31 PM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
OMGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG !!!!!!!!!!!!!!!!
Don, ya motor ROCKZZZZZZZZ!!!!! I wish to make a better/clear clip than this.....
Phase 3 EF16 with Don's Wicked RC 4000KV motor (2 min 15 sec)
Old Aug 27, 2012, 11:44 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Looks good! Glad you guys like it. I sadly just lost my F16 do to both tailerons coming off in flight. It was one of my favorites as it was so light and yet so fast. The kit I had when I built it already had the reinforcements glued on the stab area on the fuselage. That is where it failed. They must not have been glued on well from the factory as it did not break where I added the carbon but forward of that, right where the reinforcement ended on the fuselage side and looking at the wreckage the last half inch of the reinforcement was not glued to the body very well. It was a hot day and I think the glue they used softened in the sun a little. I was surprised it broke there as the foam is pretty thick in that location. Both came off at the same time when I was in a shallow dive at full power. :-(
Don
Old Aug 27, 2012, 11:50 PM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
Don
Oh no :-( Sorry for your loss!!
Old Aug 28, 2012, 06:46 AM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Don
I had the exact same thing happen to mine on the maiden this past Sunday. Only difference is it was only the left side. Maiden was going great, had done a couple of high speed passes and was starting another. Was just coming out of a very shalow dive and was alomost level and hit full throttle. A second or two later the left taileron ripped off. It came off at the same place you are describing, right ahead of the carbon tube i put in.
Old Aug 29, 2012, 04:48 PM
cbr600f2 is offline
cbr600f2's Avatar
Joined Nov 2007
If you fly these with any type of 4S power set up you need to do the full taileron reinforcement mod. The kit version comes with the templates to use (they may be posted on here somewhere as well). Some use carbon sheet, I just used ply.
Found It: http://static.rcgroups.net/forums/at..._Templates.jpg
The reinforcement pieces get embeded quite far into the fuse and you can basically pick up the hole plane by the two taileron extensions and swing it around its so strong.
Sorry Don, but perhaps its worth another build from the Kit version !!
Cheers.
Discussion ... WyoRip Electric Ducted Fan Jet Talk 1 Jan 05, 2015 12:17 AM
Help! Hobby People Phase 3 F-16 lv2soar Foamy EDFs 3 Feb 22, 2010 10:33 PM
