Old Jul 04, 2012, 12:19 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked powered Hobby People Phase 3 F-16
Here is my build log.
I used "Setup B" on this page
http://www.rcgroups.com/forums/showp...21&postcount=2
Power setup: (this is about 600 watts and goes about 105-110mph)
Motor: Wicked 4000 motor with standoff and EDO plug
Fan unit: 64mm EDO Type 1 fan unit
Dynamically balanced
Hobbywing Pentium/FlyFun 40 amp ESC
Lipo: 4S 2200 40C Skylipo
Alternate Setup: For a little more speed (this is about 670 watts on 4S)
Motor: Wicked Plus 4000 motor with standoff and EDO plug
Hobbywing Pentium/FlyFun 60 amp ESC
Don
The Don is offline Find More Posts by The Don
Old Jul 04, 2012, 12:24 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Photo 1:
I used 5 min epoxy and glued in the brass bushings the elevons go in to the fuselage. I also used a long rod through both to hold them straight when drying.
Photo 2:
I used an Xacto and removed a little foam to clear the servo wires.
Photo3:
Servos glued in, these are 8 gram Emax servos (I have hem on my website)
Old Jul 05, 2012, 10:36 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The power system is ready to install. I added about 3" to the battery lead on the ESC.
Old Jul 07, 2012, 10:39 PM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Any updates, Don?
MRGTX is offline Find More Posts by MRGTX
Old Jul 09, 2012, 06:10 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Model is finished and test flew yesterday. Will upload the rest of my build photos shortly.
Old Jul 12, 2012, 10:52 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Ran some doppler passes today. Got 113 mph on the first fresh lipo pass. Rest of the passes were about 108-110 mph. Not bad for the regular Wicked 4000 KV motor. If the Wicked Plus 4000KV was installed should be closer to 115 mph which matches what I doppler a customers video at that is posted on Youtube.
If you find your F16 has a more elevon trim in one side to make it fly level, (mine had about 1/4" more up on the right elevon to fly level) I suggest bending the wing where the aileron would normally be out near the tip to correct it. I found that about 1/16" up aileron over about a 3" section at the trailing edge of one wing tip allowed me to remove about 1/4" elevon deflection to counter the same roll. This makes sense as the aileron has a longer lever arm than the elevons do. Also the small amount of aileron trim is much less drag than lots of elevon roll trim.
Don
Old Jul 12, 2012, 10:54 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
What is your AUW Don? Gotta be pretty light I'd say. Looks good!
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jul 12, 2012, 10:57 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Model less lipo = 16 ounces, with 4S 2200 40C Skylipo lipo ready to fly, 25.5 ounces.
Don
Old Jul 12, 2012, 11:00 PM
DonQ8401 is offline
Find More Posts by DonQ8401
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
Did you paint the wings with that paper stickers on it or did you do it without them?
DonQ8401 is offline Find More Posts by DonQ8401
Old Jul 12, 2012, 11:12 PM
Nashville TN.
Joined Mar 2006
Yea. About 8 oz. lighter than mine!
Old Jul 12, 2012, 11:38 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The kit I had had the paper on the elevons and wings already so I just painted them with Testors Model master. I have two more of these F16 kits I am going to make combos on (motor/fan/ESC and servos) and sell in the for sale section now that I know this light setup works well.
Old Jul 13, 2012, 11:27 AM
Runnikee is offline
Find More Posts by Runnikee
Crash and burn, huh Mav?
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
Don,
Looks great. Just a couple questions for clarification from Post #6:
1) Why did you sand the tabs off of the fan housing?
2) Why did you glue the 3/32 pieces of ply to the fan housing? Does the housing you're using not fit into the model the same?
Runnikee is offline Find More Posts by Runnikee
Old Jul 13, 2012, 05:21 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
1) they did not line up with anything and I wanted the motor wires to go as shown in the photos so it was easiest to just remove them.
2) To center the housing equally between the fuselage and belly pan. Since the OD of the housing is smaller than the cavity in the foam, the shims were used to get equal spacing.
Don
Old Jul 14, 2012, 03:01 AM
ozfella is offline
Find More Posts by ozfella
Nasir Khan
Australia, NSW, Fairfield
Joined Feb 2009
subcribed
ozfella is offline Find More Posts by ozfella
Discussion ... WyoRip Electric Ducted Fan Jet Talk 1 Jan 05, 2015 12:17 AM
Help! Hobby People Phase 3 F-16 lv2soar Foamy EDFs 3 Feb 22, 2010 10:33 PM
