This thread is privately moderated by shelterock, who may elect to delete unwanted replies.
Old Jul 04, 2012, 11:21 AM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Build Log
HexaCopter
I've ordered from Hobbyking the basics to build a Hexacopter
Frame: H550 V2 Glass Fiber Hexcopter Frame 550mm - Integrated Power PCB
Description: Hexacopter Frame H550 with Power Distribution
Motors: 6 NTM Prop Drive 28-26 1000KV / 315W + NTM Prop Drive 28 Series
Description:
Also got Accessory Packs + (2) 2826 Series Replacement Shaft
Flight Controller: Hobbyking KK2.0 Multi-rotor LCD Flight Controller
Description: Hobbyking KK2 Flight Controller
ESC: 6 F-30A Hobby King 30A ESC 3A UBEC
Description:
(simonK Flash Possible for High Mhz operation)
Bullet Connectors: PolyMax 3.5mm Gold Connectors 10 PAIRS (20pc)
Props: Slow Fly E-Prop 9x4.7 / 229x119.5mm w/ Adapters
Slow Fly E-Prop 9047R SF (4 pc Right)
Slow Fly E-Prop 9047 SF (4 pc - Green
Slow Fly E-Prop 9047R SF (4 pc - Green)
Optional Props: 1047SF Combo (1047SF & R1047SF) (3 Standard 3counter rotating)
Receiver Leads: 3cm Male to Male Servo Lead 26AWG (10pcs/set)
HobbyKing ESC Programming Card for F-30A ESCs
Lipo Alarm: TURNIGY 3~8S Voltage Detector
Description: 3S-8S lipo Alarm
Receiver: HK-T6A-V2 Hobby King 2.4Ghz Receiver 6Ch V2
Description: 6Ch Hobbyking Receiver for ER9X flysky Transmitter
Standoffs and nuts and bolts to build platform and mount Flight Controller:
M3 Nylon Nut (10pcs/bag)
M3X10 Nylon Screws (10pcs/bag)
5.6mm x 14mm M3 Nylon Threaded Spacer (10pc)
5.6mm x 30mm M3 Nylon Tapped Spacer (10pc)
Freebie Turnigy Badge (self adhesive) Thanks Hobby King!
So, a Hexa with KK2 in X config with 9" props on 3S 4000mAh+ battery coming up.
Next choice is the landing gear and camera gimbal.
I'm partial to the AeroXcraft F550 compatible landing gear
Name: AeroXcraft 550 landing gear.jpg
Description:
With Hard Camera Mount
Name: Camera Hardmount.jpg
Description:
Other possibilities include:
leg extensions from GotHeliRC.
Description: GotHeliRC F550 landing gear extensions
The X468 XT landing gear and gimbal combo look good too.
Description: X468.com FlameGear XT Mount
I'll take some build photos and videos.
I will make the landing gear / Gimbal decision once I've read more reviews.
H
shelterock is offline Find More Posts by shelterock
Old Jul 16, 2012, 02:31 PM
wkruger is offline
Find More Posts by wkruger
Joined Jun 2012
how's it coming?
I have almost the identical setup. I purchased the AeroXcraft landing gear with gimble and am VERY pleased with the quality and functionality. I just got my HK KK2.0 board in the mail on Friday and will be replacing the antiquated HK board I started with.
I'm curious what gain settings you have for your KK2.0 board? I haven't taken a maiden flight yet and would like to get a ballpark for what settings give good steady hovering results. Any help would be much appreciated!
Thanks!
Will Kruger
wkruger is offline Find More Posts by wkruger
Old Jul 20, 2012, 07:03 PM
Joined May 2011
Thanks!
Will Kruger
Hi Will,
I'm just done assembling. I did the simonK firmware flash on the F30a escs. I am planning to go stock settings but it's raining 2 days now.
The firmware upgrade theoretically allows for higher gains. To be seen.
How are you finding the aeroXcraft gimbal. I was concerned about the cost of the digital servos and few choices that fit the gimbal. there are several complaints about digital servo jitters.
How did you mount your kk board? Did you drill mounting holes? Also if you did, did you use nylon standoffs?
H
Old Jul 22, 2012, 09:15 PM
Joined May 2011
Hexacopter Maiden KK2 + SimonK F30a & NTM2826 1000kv (4 min 29 sec)
Her eis the maiden flight of my H550 hexacopter. Flew first time out with stock KK2 settings at 150 P gains for Roll and Pitch. Yaw 100. Limits also stock at 100 and 50.Now starts the tuning process.
H
Old Sep 27, 2012, 03:57 PM
Zector123 is offline
Find More Posts by Zector123
The best FPC impaler!
Canada, MB, Winnipeg
Joined Jun 2012
what did you find for the best gains? i have a similar setup, and havent found the sweet spot yet.
Zector123 is offline Find More Posts by Zector123
Old Sep 28, 2012, 06:54 PM
Joined May 2011
I got exactly 4 flights out of it and 1 video before a crash caused it to burst into flames. I had gains in the 160-165 with high I gains over 100. I don't remember the yaw gains. Pretty high too.
Sorry I don't remember more specifically.
Make sure you don't have any sharp solder joints on the power distro that can pierce the battery.
H
Discussion Battery amp draw hexacopter question Reginak Batteries and Chargers 6 Aug 03, 2013 12:01 AM
Discussion Video - Maiden and Second flight of my newly built Hexacopter chargenut Aerial Photography 15 Jul 15, 2012 06:51 PM
Discussion Building a Payload Hexacopter Bearsa LLC Multirotor Talk 5 Jun 16, 2012 10:21 AM
Build Log Hexacopter Build Bearsa LLC Multirotor Talk 0 Jun 16, 2012 01:24 AM
