Old Jul 04, 2012, 10:23 AM
Eddy is offline
Find More Posts by Eddy
Malibu Ca
Joined Feb 2000
Glider for 4 pound thrust turbine?
Can anyone recommend a glider that's reasonably priced and sized right for this engine?
Eddy is offline Find More Posts by Eddy
Old Jul 04, 2012, 11:55 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
http://shop.strato.de/epages/6131678...2OPUS-V/Jet%22
WimH is offline Find More Posts by WimH
Old Jul 04, 2012, 05:35 PM
thecrawfords67 is offline
Find More Posts by thecrawfords67
Joined Apr 2008
These are a more reasonable 400 euro's.
http://www.rcuniverse.com/forum/m_11...m.htm#11023280
thecrawfords67 is offline Find More Posts by thecrawfords67
Old Jul 05, 2012, 02:55 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
When I scanned the market I only looked for V-tail gliders... but that's not needed as proven by the guy flying the Swist with turbine power. That widens the perspective alot and suddenly you can choose any F5B glider you like. I would however not use the chepest ones like the Hawk/Tiger.
There are nice flying slopers all over the place but they rarely has room for fuel, so the F5B range is my recomendation.
henke is online now Find More Posts by henke
Old Jul 05, 2012, 03:49 AM
henke is online now
henke's Avatar
Joined Jan 2001
http://www.fvk.de/Englisch/Backfire.html
Anyone flying this one?
Old Jul 05, 2012, 04:17 AM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
There's at least one in NZ flying. Looks really nicely built from what I have seen.
Build pics around at: http://www.parkflyers.org.nz/modules...d=1043&forum=8
sykotic is offline Find More Posts by sykotic
Old Jul 05, 2012, 05:00 AM
olavjoergensen1 is offline
Find More Posts by olavjoergensen1
Joined Feb 2012
Originally Posted by henke View Post
I have a Backfire with F5F setup.
A really good flyer but has quite a bit og wingflex on hard turns
olavjoergensen1 is offline Find More Posts by olavjoergensen1
Old Jul 08, 2012, 12:15 PM
Eddy is offline
Malibu Ca
Joined Feb 2000
Thanks for the recommendations,
What are your thoughts on this one?
http://www.soaringusa.com/Micro-Flash-II-Carbon.html
or this one?
http://www.soaringusa.com/Mini-Blade-1.5-E.html
Old Jul 09, 2012, 03:26 AM
henke is online now
henke's Avatar
Joined Jan 2001
or this one?
I was also looking at the X-models blade series for my turbine but there simply are no room for fuel.
F5B or the Swist will house about 8,5oz of fuel, I guess the ones above doen't have room for more then half that.
If you choose the Swist I can sell you the parts needed to fit the turbine, such as fueltank, the detachable nosecone, CNC parts, pylon for the turbine, clamp etc.
Are you useing a Lambert or the JJJ? or maybe something else :-P
Swist fuelcell (0 min 28 sec)
Old Jul 09, 2012, 08:34 AM
Eddy is offline
Malibu Ca
Joined Feb 2000
Does the blade have a smaller diameter fuse?
My engine is a home built
Old Jul 09, 2012, 08:49 AM
henke is online now
henke's Avatar
Joined Jan 2001
No way to get a fueltank in there... remember you need o put it on the CG too. they fly it on a 3S 2000mAh pack, which is about 85cc of volyme.
Compared to the Swist where you can fit a 5S 4100 right at the CG (250cc of fuel)
Old Jul 09, 2012, 08:52 AM
henke is online now
henke's Avatar
Joined Jan 2001
Cool, which specs?? the Kolibri is 7,7oz airstarted and I need about 100grams of lead in the nose so an 11oz engine would be fine too on the Swist :-)
Old Jul 09, 2012, 09:03 AM
Eddy is offline
Malibu Ca
Joined Feb 2000
How about gluing in fiberglass bulkheads at the front of the wing and at the trailing edge in the fuse, voila, instant fuel tank and this also uses every bit of space for fuel.
Maybe run a 3/8 fiberglass tube through it for wires, should work fine.
Old Jul 09, 2012, 09:05 AM
Eddy is offline
Malibu Ca
Joined Feb 2000
4 pounds of thrust if I use it conservatively, it weighs just under 6 oz
May have to move it forward on the fuse
Old Jul 09, 2012, 12:12 PM
henke is online now
henke's Avatar
Joined Jan 2001
new world record then pix please
Discussion mid air crash mirage 2000 40 pound turbine!! sherlockshah Jet Turbines 6 May 09, 2012 08:50 AM
Discussion amazing footage 40 pound turbine mirage 2000 Midair crash!!! sherlockshah Crash Discussion 21 Mar 29, 2012 10:10 AM
Wanted WTB-turbine 12-15 pounds of thrust max101 Aircraft - Fuel - Jets (FS/W) 1 May 22, 2011 01:22 PM
Discussion Thrust need to lift a 7 - 9 pound glider? oracle_9 Electric Sailplanes 13 Oct 09, 2008 09:27 PM
Is 30 pounds of thrust in a 14 pound plane good? fbw4 Sport Planes 13 Nov 19, 2004 09:44 AM
