Old Dec 11, 2003, 05:45 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Bob that is a very cool looking motor there.
Reckon if you used 3 coils it would dly a plane?
Billy
billystiltner is offline Find More Posts by billystiltner
Old Dec 11, 2003, 08:56 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
All
I haven't been able to get the controller working yet, probably my fault. But I did check the 6mm motor to see if it would trigger a Hall and it does, at least it triggers the hall I'm using for an RPM meter. You all should understand that I'm just making an on-off controller, no throttle control, no BEC, no nothin' but on-off for 1 Li-poly.
Bob
How did you get the hole in the magnet?
mcross is offline Find More Posts by mcross
Old Dec 12, 2003, 08:28 AM
madsci_guy is online now
Find More Posts by madsci_guy
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
I am currently doing a design that uses an ATTINY micro and discrete MOSFETS. If there is interest, I should be ordering PCB's in the early part of the year. The good thing about discrete FET's is that you can replace them with better ones as they become available. The board as designed should be able to handle 3 amps/phase. The baord will be able to handle 3 or 4 phase motors(steppers). Let me know if yiu are interested.
madsci_guy is online now Find More Posts by madsci_guy
Old Dec 12, 2003, 10:47 AM
bselman is offline
Find More Posts by bselman
bselman's Avatar
sw missouri
Joined Sep 2001
Billy,
I don't know about 3 coils. The circuit I came up with is single phase but I was going to lower the coil resistance and add a second coil at 180 degrees. A speed control would be fairly easy to do by putting a PIC between the HE and the H bridge to change the timing according to the input pulse from the receiver.
Mike,
The magnet came from an early Ruijsink actuator. Our Plug n Play actuator has a large magnet with a hole in it too.
Bob
bselman is offline Find More Posts by bselman
Old Dec 12, 2003, 07:30 PM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
Bob,
to use 2-3 or more coils you just need to have the same no of control circuits ie 1 for each coil , can you post your circuit ?
as we are looking at a similar system to try on the small b/l motors driven from a standard brushed controler .
Stewart
clipclop is offline Find More Posts by clipclop
Old Dec 13, 2003, 05:18 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
It works
I finally have a working controller based on the Philips 5144 chip. I still need to add a DC-DC so it will run on a single Li-Poly. I have a Micro Chip DC-DC I'll add to the back of this board. As it is now it weights 1.6 grams without wires. Remember that this is for a bit radio so there is no throttle or BEC.
Old Dec 13, 2003, 07:57 PM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
Really nice job. Now got to come up with a really small motor.
Thatovalguy is offline Find More Posts by Thatovalguy
Old Dec 13, 2003, 08:06 PM
clipclop is offline
QLD, Australia
Joined Sep 2003
Mike,
Do you have circuit details , component values that you used ?
any tips from your experiance on getting the chip going with dif motors ?
Stewart
Oh and - congrats Mike , nice job on the board
Old Dec 14, 2003, 01:03 AM
Koichi Tanaka is offline
Find More Posts by Koichi Tanaka
Koichi Tanaka's Avatar
Japan
Joined Dec 2002
The test of a micro motor and a controller was begun. PIC12F629 are used for the controller. It only checked rotating. PWM control cannot be performed yet.
Koichi
Koichi Tanaka is offline Find More Posts by Koichi Tanaka
Old Dec 14, 2003, 02:51 AM
clipclop is offline
QLD, Australia
Joined Sep 2003
Koichi,
Great work, glad you too are working on a brushless solution
Stewart
Old Dec 14, 2003, 05:58 AM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Koichi
Very cool! It looks like it's a lot simpler than the motor I made so it should be a lot lighter. It also looks like it would be very easy to build.
Very good work!
Old Dec 14, 2003, 11:37 AM
Foam rules
HdG Md.
Joined Jan 2003
Now I love that motor.
Old Dec 15, 2003, 10:44 AM
bselman is offline
bselman's Avatar
sw missouri
Joined Sep 2001
BL Controller
Here is the schematic for my little single phase motor. The original did not have the PIC in the circuit. This was the "next step" that I never took. The HE just drove the H bridge in the working unit shown above.
Bob
Old Dec 15, 2003, 10:47 AM
bselman is offline
bselman's Avatar
sw missouri
Joined Sep 2001
I got bit by the "picture too big" bug. As I kept shrinking it, some of the lines went away. I'll see if I can reformat it and submit again.
Bob
Old Dec 15, 2003, 11:07 AM
bselman is offline
bselman's Avatar
sw missouri
Joined Sep 2001
I ZIPPED it
Here is the schematic in a zip file.
Bob
Discussion Micro brushless ESC discussion Hotflyer Scratchbuilt Indoor and Micro Models 10 Feb 19, 2008 08:23 PM
Discussion micro brushless esc Ivan2280 Scratchbuilt Indoor and Micro Models 4 Aug 08, 2007 04:13 AM
Found Looking for lightweight micro brushless ESC. rumme Aircraft - Electric - Power Systems (FS/W) 1 Nov 02, 2005 07:22 PM
castle creations PH10 brushless esc "MICRO"8-) littlepiston Aircraft - Electric - Helis (FS/W) 2 Sep 16, 2004 09:58 AM
For sale or trade CC pheonix25 brushless esc and hitec 555 micro RX neg shift Eric Giorgianto Aircraft - General - Radio Equipment (FS/W) 6 Jul 20, 2004 10:20 PM
