Old Nov 29, 2012, 01:01 AM
kornetto is offline
Find More Posts by kornetto
Austria, Wien, Vienna
Joined Jan 2006
### PRICE DROP ####
price including worldwide shipping:
1 board: 5 USD
2 boards: 8 USD
each board comes with blue SMD-LED, Resistor and BT-FC-Adapter
kornetto is offline Find More Posts by kornetto
Old Jan 25, 2013, 07:59 PM
arielba is offline
Find More Posts by arielba
Spain
Joined Nov 2009
hello,
My mMWC in my flying wing and have a little problem.
I can't change the servo direction
I changed this line and compile/download and not see any change in the servo response, are the same directions.
#define SERVO_DIRECTION { -1, 1, 1, -1, 1, 1, 1, 1 }
I need invert the elevator.
that's what happens? maybe I have something wrong in the configuration?
thanks.
best regards.
Ariel
arielba is offline Find More Posts by arielba
Old Jan 25, 2013, 10:45 PM
kornetto is offline
Joined Jan 2006
hi!
when you say you want to invert elevator, do you expect the two delta mixed aileron servos (since on a wing usually you have two aileron-servos mixed for elev as well)
a) to move to the opposite direction when giving commands with your transmitter
b) to move to the opposite direction when reacting to the sensor measurments
c) both?
Actually, just swapping the servo-connections (i.e. servo from D11->D12, servo from D12->D11) should do the trick.
Other than that try to change the servo direction for the aileron servos:
Code:
//                                 AIL1  AIL2  RUDD  ELEV
Code:
#define SERVO_DIRECTION  { -1,   1,   -1,   1,    1,    1,   1,   1 }
let us know your findings...
christian
Old Jan 27, 2013, 07:44 AM
arielba is offline
Spain
Joined Nov 2009
Originally Posted by kornetto View Post
hi!
c) both?
Code:
Code:
christian
thanks by your fast reply Christian
the option b)
i move the flying wing and the response are oposite to correct.
i change any 1 by -1 and not see any change in the response.
best regards.
Ariel
Old Jan 27, 2013, 09:40 AM
kornetto is offline
Joined Jan 2006
please zip all your source-files to one ZIP-archive and upload it here. I can then check and compare with my code.
best regards,
christian
Old Jan 27, 2013, 10:31 AM
arielba is offline
Spain
Joined Nov 2009
best regards,
christian
thanks Christian
the complete source-file attached.
and another question,
What is the direction of flight of the mmWC?
best regards.
Ariel
MultiWii_2_1_no_invert
Old Jan 27, 2013, 11:50 AM
kornetto is offline
Joined Jan 2006
what I can see from your code, you did not apply the changes in def.h as I have described in the How To:
2.) ONLY FOR FLYING_WING: swap servos
ATTENTION: If you use AIRPLANE mode, ignore this step and jump over to step 3.
Multiwii for some reason uses per default in flying wing mode different pins than in airplane mode for controling the aileron servos. Since all these is only software, this can be simply changed in def.h.
In fact swap
SERVO_1_ ←→ SERVO_5_
and
SERVO_4_ ←→ SERVO_2_
in the pro mini section.
This means, the original part:
Code:
  #define SERVO_1_PINMODE            pinMode(A0,OUTPUT); // TILT_PITCH - WING left
  #define SERVO_1_PIN_HIGH           PORTC |= 1<<0;
  #define SERVO_1_PIN_LOW            PORTC &= ~(1<<0);
  #define SERVO_2_PINMODE            pinMode(A1,OUTPUT); // TILT_ROLL  - WING right
  #define SERVO_2_PIN_HIGH           PORTC |= 1<<1;
  #define SERVO_2_PIN_LOW            PORTC &= ~(1<<1);
  #define SERVO_3_PINMODE            pinMode(A2,OUTPUT); // CAM TRIG  - alt TILT_PITCH
  #define SERVO_3_PIN_HIGH           PORTC |= 1<<2;
  #define SERVO_3_PIN_LOW            PORTC &= ~(1<<2);
  #if !defined(MONGOOSE1_0)
    #define SERVO_4_PINMODE            pinMode(12,OUTPUT); // new       - alt TILT_ROLL
    #define SERVO_4_PIN_HIGH           PORTB |= 1<<4;
    #define SERVO_4_PIN_LOW            PORTB &= ~(1<<4);
  #endif
  #define SERVO_5_PINMODE            pinMode(11,OUTPUT); // BI LEFT
  #define SERVO_5_PIN_HIGH           PORTB |= 1<<3;
  #define SERVO_5_PIN_LOW            PORTB &= ~(1<<3);
will then look like:
Code:
  #define SERVO_5_PINMODE            pinMode(A0,OUTPUT); // TILT_PITCH - WING left
  #define SERVO_5_PIN_HIGH           PORTC |= 1<<0;
  #define SERVO_5_PIN_LOW            PORTC &= ~(1<<0);
  #define SERVO_4_PINMODE            pinMode(A1,OUTPUT); // TILT_ROLL  - WING right
  #define SERVO_4_PIN_HIGH           PORTC |= 1<<1;
  #define SERVO_4_PIN_LOW            PORTC &= ~(1<<1);
    #define SERVO_2_PINMODE            pinMode(12,OUTPUT); // new       - alt TILT_ROLL
    #define SERVO_2_PIN_HIGH           PORTB |= 1<<4;
    #define SERVO_2_PIN_LOW            PORTB &= ~(1<<4);
  #endif
  #define SERVO_1_PINMODE            pinMode(11,OUTPUT); // BI LEFT
  #define SERVO_1_PIN_HIGH           PORTB |= 1<<3;
  #define SERVO_1_PIN_LOW            PORTB &= ~(1<<3);
and mMWC will handle your wing's servos connected same way like airplane aileron-servos to D11/D12, but of course with delta mixing done by multiwii.
concerning the direction of the mMWC:
It's actually not the mMWC, but the sensor board which defines the direction it should be used. There are 2 arrows shown on it. The Y arrow must point forward and the X arrow to the right.
see the attached picture...
Old Jan 27, 2013, 01:07 PM
arielba is offline
Spain
Joined Nov 2009
I did what had changed.
is this correct? extracted from my code:
#endif
#define SERVO_6_PINMODE pinMode(3,OUTPUT); // TRI REAR - BI RIGHT
#define SERVO_6_PIN_HIGH PORTD|= 1<<3;
#define SERVO_6_PIN_LOW PORTD &= ~(1<<3);
#define SERVO_7_PINMODE pinMode(10,OUTPUT); // new
#define SERVO_7_PIN_HIGH PORTB |= 1<<2;
#define SERVO_7_PIN_LOW PORTB &= ~(1<<2);
#define SERVO_8_PINMODE pinMode(9,OUTPUT); // new
#define SERVO_8_PIN_HIGH PORTB |= 1<<1;
#define SERVO_8_PIN_LOW PORTB &= ~(1<<1);
Old Jan 27, 2013, 01:21 PM
arielba is offline
Spain
Joined Nov 2009
hi!
c) both?
Code:
Code:
christian
but....
in How do document say:
what is the correct??
Old Jan 27, 2013, 03:37 PM
kornetto is offline
Joined Jan 2006
hahaha, sorry. I was completely confused. seems I still suffer from my flue I had a couple of days ago...
forget about what I wrote in the last posting and just simply check config.h again and go a few lines up.
you will find a special "Flying Wing" section and right after the comment written there the first two lines are:
Code:
    #define PITCH_DIRECTION_L 1 // left servo - pitch orientation
    #define PITCH_DIRECTION_R -1  // right servo - pitch orientation (opposite sign to PITCH_DIRECTION_L, if servos are mounted in mirrored orientation)
and guess what they do...
Sorry for the confusion.
greetings from vienna,
Christian
Old Jan 29, 2013, 08:07 AM
arielba is offline
Spain
Joined Nov 2009
jajajaj
no problem.
now work fine !!
I am very happy with the mmWC, thanks for your help.
best regards
Old Jan 29, 2013, 08:11 AM
kornetto is offline
Joined Jan 2006
glad to hear, it is working now for you
Old Mar 03, 2013, 11:20 AM
gtrick90 is offline
Find More Posts by gtrick90
aka Nigel Uno
Italia, Lazio, Monterotondo
Joined Sep 2004
My new Stryker F27Q ParkZone FPV with mMWC with MultiWii 2.1
The MWii 2.1 mixer table has been rewrited by me (with Dynamic PID attenuation mod too)
http://www.rcgroups.com/forums/showp...postcount=7233
Later the maiden flight video
Ciao
gtrick90 is offline Find More Posts by gtrick90
Old Mar 03, 2013, 12:15 PM
gtrick90 is offline
aka Nigel Uno
Joined Sep 2004
Maiden FPV flight (Stryker F27Q)
Striker F27Q Maiden flight (2 min 11 sec)
The mMWC needs some pid tuning but it's a good starting point
Ciao
Luca
Old Mar 25, 2013, 09:20 PM
OrlandoP is offline
Find More Posts by OrlandoP
Santo Domingo, Dominican Republic
Joined Mar 2007
Do you still have boards available? I'm interested in a couple.
OrlandoP is offline Find More Posts by OrlandoP
New Product Bob's Super Simple Shield - MWC board Qrome Multirotor Talk 563 Dec 26, 2013 08:20 PM
Discussion Bob's Super Simple Shield - MWC bob4432 Multirotor Talk 3 Aug 30, 2011 09:53 PM
Sold Paris MWC board Ready for flight w/Arduino Pro Mini 5/16mhz,Wii Motion+,Bosch BMA02 Z06 Tony Aircraft - Electric - Multirotor (FS/W) 16 May 27, 2011 08:56 AM
