Old Feb 07, 2013, 07:55 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Got mine finished with the FY30. Going to do a Line of Sight maiden tomorrow and if all goes well i'll slap the DragonOSD and other FPV bits. I ended up getting the new upgraded canopy as i plan on flying with the Canopy on.
Any tips for a successful maiden?
blueprint is offline Find More Posts by blueprint
Old Feb 07, 2013, 08:37 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Which motor did you go with?
Maiden for this should be easy, so dont over-think it....
Check CG..twice. Check all control surfaces are tight, slop free, and moving the right direction. Have a friend check all that stuff one more time if you can, as it is easy to get nervous and overlook something twice. Launch over tall grass or something soft if possible. Should be able to launch without power on this guy, then apply smooth increased throttle, (don't kick it in hard). Go ahead and put in plenty of expo too, as it cant hurt. I usually start with throws at ~20-50% greater than recommended, but with 40% expo.
Derek_S is offline Find More Posts by Derek_S
Old Feb 07, 2013, 09:04 PM
superevan is online now
Find More Posts by superevan
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
You're gonna love it!
Get some color on that thing
superevan is online now Find More Posts by superevan
Old Feb 07, 2013, 09:16 PM
fpvbasher is offline
Find More Posts by fpvbasher
Joined Sep 2012
looks like the 2815..
if possible do a ROG launch.
fpvbasher is offline Find More Posts by fpvbasher
Old Feb 07, 2013, 09:28 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Decided on the 3542 for my 5000mah 4s system.. Will post how it works out. The 3530 and 3536 seemed pushing in on specs for a 9" prop on 4s, so went with this 600w motor.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old Feb 07, 2013, 09:38 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
I was debating on using the 3536 NTM 1400kv motor but the motor adapter plate wouldnt screw on without modifying. Opted to try the stock motor.
Should i launch with stabilization on?
Old Feb 07, 2013, 09:40 PM
Joined Sep 2012
nope. its a pansy, the stab could be out of tune and run you into the ground.
Old Feb 07, 2013, 09:46 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Yes, agree, fly with the minimum stuff, the add/turn on as you get it tuned in regular flight.
FPV Pilot
blueprint's Avatar
Joined Sep 2007
I was considering wrapping the vertical stab and horizontal stab with orange econokote. I did not want to paint as im horrible at it. Lol
Old Feb 07, 2013, 09:48 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Good point. I'll fly it in manual and enable stabilization up high just in case things get screwy.
Old Feb 07, 2013, 09:49 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Oh and where is the preferred cg of this plane?
Old Feb 07, 2013, 09:59 PM
Joined Sep 2012
I eyeballed 33%, the way Ive done on my last 6 planes sans the ZII (my first wing) if anything you can go a little nose heavy to be safe
"a nose heavy plane flies bad, a tail heavy one flies once"
Old Feb 07, 2013, 10:12 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
So true. Learned that the hard way with my first plane.
Old Feb 07, 2013, 10:52 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Wow!
http://fpvlab.com/forums/showthread....es-quot/page25
Old Feb 07, 2013, 10:59 PM
aviatorgeek is offline
Find More Posts by aviatorgeek
PP/IR
aviatorgeek's Avatar
United States, CO
Joined Jun 2012
Flew 3 packs today with 85, 80 and 75mm CG. I think 75 flies best. This was in moderate winds and stability was far better.
aviatorgeek is offline Find More Posts by aviatorgeek
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
