So, just maidened my Penguin and I had barely enough power to get off the ground. And I'm on a 5800 mah 4S and also tried on a 4000 mah 4s with same issue. I think its a timing issue, but thought that the stock timing should've be fine. Did anyone else have this issue? I did calibrate it to my Rx, but I'll try that again along with checking the programming.
No I actually flew two flight with it, but could barely climb. but think I may have found the issue. I found that the deans connector on my Eagle Tree OSD was corroded and barely making connection, maybe that would explain why the OSD was acting weird too.
Update: yep, just wire wheel brushed the tabs and bent the thin tabs out and now have a solid connection and MUCH more power. |
United States, Mt, Great Falls
Joined May 2011
I'm pretty happy with my new Parkflyer.
2815 motor, 3 cell 5500mah, 9x6 APC. AUW, ready to launch is 4.75 lbs. No GoPro, just #16 keyfob.
Yabba |
United States, CA, Sacramento
Joined Feb 2012
Hey guys so I used the 3mm spacers on the top motor mount for the 2815 motor and wow! The penguin flies much better than it already did! When I reviewed the gopro footage it literally looked like it was completely still in the sky. I am using a fy31ap which helps, but I learn to love this bird more everytime I fly it.
Here is a little upgrade i did to use the canopy with the gopro. My PZ0420 is mounted on the nose right below the bottom screw that holds down the canopy. So they're no wires hooked to the canopy which makes taking it on and off lots easier. I also decided to line the inside of the hero 2 case with aluminum tape to cut down noise. Cheers, |
Joined Jan 2013
I am seeing that a lot of you guys use the Dragon Link -- an obvious choice for FPV. But I also see a lot of cloverleaf style vtx antennas (and lots of mention of 800mW 1.3Ghz vtx, too).
Is anyone using DL along with a cloverleaf for video? This is the root of my question: I figured the use of the DL implied hardcore FPV users with longish range in mind. Then, seeing so much cloverleaf throughout these Penguin threads got me wondering if an omni-directional video arrangement could cut it for users whose range needs required a DL. I figured everyone with a DL would be using patch antennas with head-tracking and maybe diversity. |
http://www.rcgroups.com/forums/showthread.php?t=1355327 For radio control yes you are correct most fly with some sort of UHF system. I personally fly with Dragon Link for my FPV but revert back to 2.4 for my LOS birds. I have flown to the max range of my HiTech 2.4 with my quad. At one mile I lost control. 72 mhz is another option and is good for several miles but in my opinion the best way to go is a good UHF. One of these systems should be good for 10+ miles. Here is my Penguin flying this weekend with the DL UHF antenna in one wingtip and my Vtx/antenna in the other.
Latest blog entry: Pan/Tilt servo mods
| Thread Tools | |
| Discussion fmkit's ULink (review/discussion/etc) | CrashMeUp | Video Piloting (FPV/RPV) | 112 | Apr 07, 2013 05:34 PM |
| Discussion general engine discussion thread | cale10 | Engines | 273 | Nov 13, 2012 01:22 PM |
| Spektrum DX7 technology discussion (moved from review thread) | Chipwillis | Radios | 62 | Jan 17, 2007 04:07 PM |
| Heliup.com CNC CF Shogun/Zoom frame build thread/review | Hoverup | Mini Helis | 123 | Jun 18, 2005 09:09 PM |
