Old Jan 29, 2013, 03:56 PM
ron-sand is offline
Find More Posts by ron-sand
ron-sand's Avatar
Norway, Troms, Tromsų
Joined Sep 2002
If it ain't broken, don't fix it
In any case to get it perfect you might want to tune it so that it flies level both on and of throttle:
Shim on top will give more down thrust (or less up-thrust, depending at how you look at it).
Shim on bottom will give you more up-thrust (or less down-thrust depending at how you look at it).
ron-sand is offline Find More Posts by ron-sand
Old Jan 29, 2013, 04:57 PM
redodedo is offline
Find More Posts by redodedo
HD FPV on a 4m glider
Canada, BC, Richmond
Joined Dec 2012
I know this might not be the perfect place for this question, but I know that many of you would have a solution which is why I post this here.
I have a dynam 185 sonic rc glider and when I chuck it into the air it just wants to barol roll left. I trimmed its ailerons and rudder all the way to the right which keeps it more steady but now performans is decreased and battery is drained ( do to the extra drag as the ailerons and rudder stick out like crazy).
Im sure this has happened to someone elses plane before. does anyone know what I should do to fix this so I dont have to be flying trimmed all the way to the right?? (like a couterbalace, etc).
thanks
redodedo is offline Find More Posts by redodedo
Old Jan 29, 2013, 05:13 PM
imagebuff is online now
Find More Posts by imagebuff
imagebuff's Avatar
United States, TX, Tomball
Joined Jan 2011
Originally Posted by swartzracing View Post
Hey guys I have no spacers on my motor mount and the penguin flies pretty good. Do you guys recommend the 3mm spacers on the top of the motor mount?
Mine is doing much better with spacers on the bottom. No more lurching upward on throttle.
imagebuff is online now Find More Posts by imagebuff
Old Jan 29, 2013, 07:08 PM
swartzracing is offline
Find More Posts by swartzracing
Aerial Operator
United States, CA, Sacramento
Joined Feb 2012
thanks guys ill try it out and see how she does!
Much appreciated
swartzracing is offline Find More Posts by swartzracing
Old Jan 29, 2013, 09:55 PM
Maxintheair is offline
Find More Posts by Maxintheair
Canada, ON, Moonstone
Joined Sep 2011
I have mine on the top like in the manual, and it fly's great! I find the penguin to be the best hand lunching aircraft I have. I lunch it with about 1/2-3/4 throttle and I do a long steady lunch dropping down to one knee. My penguin flys right out of my hand and heads straight out to the horizon with a slight climb.
Maxintheair is offline Find More Posts by Maxintheair
Old Jan 29, 2013, 10:03 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
This is all too weird...
Because it is a pusher and the motor is mounted behind and above the CG, top spacers should drive the nose more down under power.
However the actual results vary and they vary a lot. So, I wonder if it is a thrust/wash problem? That is, since a significant amount of the prop wash hits the top of the horizontal stab, could this overcome the normal thrust angle application?
Just a random hmmmm?
mark_q is online now Find More Posts by mark_q
Latest blog entry: X-UAV Mini Talon #2
Old Jan 29, 2013, 10:20 PM
ron-sand is offline
ron-sand's Avatar
Joined Sep 2002
It depends a lot on your CG and the incidence of the tail to main-wing. In addition it depends on the accuracy of the built in angle in the motor pod..... And not to forget any offset (trim) on the elevator to level the model.
A lot of variables here you see.
I have read that the tail/main-wing incidence can vary from kit to kit. Mine was set at 3.5 degree positive which i way to much for my style of flying. I reduced it to 2 degrees and it suits me much better. I also have the CG at 90-95 mm (85 mm as per manual).
So there you go. This is a big part of the explanation for the different thrust angles reported
Old Jan 30, 2013, 11:14 AM
sutors is offline
Find More Posts by sutors
sutors's Avatar
Canada, ON, Toronto
Joined Nov 2004
Has anyone opened up the main wings? I'm trying to install the lighting system but I'm having hard time fishing the cables through. I'm not sure what's the best way to go about it.
sutors is offline Find More Posts by sutors
Old Jan 30, 2013, 11:25 AM
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
I made small holes in the hollow sections to run my DragonLink antenna and VTx wires out to the wing tips. I then used needle nose pliers to pull them along and covered the holes with extreme tape when done.
cactus is offline Find More Posts by cactus
Old Jan 30, 2013, 11:34 AM
Deadstick 8409 is online now
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
I ran wires from the servo outboard. Strobes powered by servo power.
Deadstick 8409 is online now Find More Posts by Deadstick 8409
Old Jan 30, 2013, 02:31 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
That is the one thing I think they screwed up on this was the preglued bottom wing panels. I fished all my stuff through the wing which is a huge pain.
Mike Freas is offline Find More Posts by Mike Freas
Old Jan 30, 2013, 04:14 PM
sutors is offline
sutors's Avatar
Canada, ON, Toronto
Joined Nov 2004
Yeah. I agree. They should not have come preglued. I'll try what cactus suggested..
Old Jan 30, 2013, 04:42 PM
imagebuff's Avatar
Joined Jan 2011
I used the servo extension cable which was already in place to pull through a dummy line to attach other things I wanted to fish through the channel. One way to do it.
Old Jan 30, 2013, 05:36 PM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
I used a dowel. I needed to get a antenna extension in one wing and antenna in the other.
Old Jan 31, 2013, 02:20 AM
Aerial Operator
Joined Feb 2012
Hey Guys I'm thinking about going to a 4S battery to run the 2815 with the APC 9x6E Prop. What are you guy's thoughts on this setup compared to a 3S 5000mah pack?
Flight Time?
Thrust?
Max amps on esc?
Look forward to hearing back from all you nerds (including myself) on RCG
Cheers,
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
