Old Jan 25, 2013, 03:38 PM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
Originally Posted by Cervanchez View Post
Regarding motor swaps. Is anyone using the foam piece that covers the motor? If so, how attached. I didn't want to glue mine in in case I did need to get to the motor
I just tape mine in place. Makes it much easier to change motors than with glue.
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Old Jan 25, 2013, 06:03 PM
imagebuff is offline
Find More Posts by imagebuff
imagebuff's Avatar
United States, TX, Tomball
Joined Jan 2011
A few embedded magnets work nicely.
Chris
imagebuff is offline Find More Posts by imagebuff
Old Jan 26, 2013, 12:15 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Chris
ooh I like that idea, since I have tons of small magnets around.
Other options were good too, thanks guys
Cervanchez is offline Find More Posts by Cervanchez
Old Jan 26, 2013, 11:03 AM
Cpig is offline
Find More Posts by Cpig
United States, CO, Colorado Springs
Joined Sep 2006
All painted up
Thought it looked a little boring in white so I slapped some paint on, just waiting on pan and tilt cam mount and BEC now.
Installed:
RVOSD v5
Dragonlink
2815 motor
Castle 80amp ESC
Graupner 9x6e prop
4s Batteries 3300 - 6000mah
RMRC 1.3ghz, 400mW Tx w/ IBCrazy CP antenna
600TVL CCD FPV Cam
Contour Roam 1080P Cam
Cpig is offline Find More Posts by Cpig
Old Jan 26, 2013, 11:21 AM
imagebuff's Avatar
Joined Jan 2011
Spectacular!
Old Jan 26, 2013, 12:28 PM
SWAMPER is offline
Find More Posts by SWAMPER
SWAMPER's Avatar
Joined Feb 2009
whats the control throws ? at that point of setting it up
SWAMPER is offline Find More Posts by SWAMPER
Old Jan 26, 2013, 01:23 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
I have mine fairly aggressive. If you have a computer radio program dual rates and see what you like. The actual travel is not that critical for this bird. Just make sure you have enough for the first flight and they are in the right direction.
Mike Freas is offline Find More Posts by Mike Freas
Old Jan 26, 2013, 01:58 PM
fpvbasher is offline
Find More Posts by fpvbasher
Joined Sep 2012
My high rates are almist where the servo binds and low is about 60%
fpvbasher is offline Find More Posts by fpvbasher
Old Jan 26, 2013, 02:00 PM
TAREK.SAADE is offline
Find More Posts by TAREK.SAADE
TAREK.SAADE's Avatar
London-UK
Joined Sep 2007
Maiden Flight of PPFV!
PENGUIN FPV 26 01 2013 (8 min 52 sec)
TAREK.SAADE is offline Find More Posts by TAREK.SAADE
Old Jan 26, 2013, 06:31 PM
redodedo is offline
Find More Posts by redodedo
HD FPV on a 4m glider
Canada, BC, Richmond
Joined Dec 2012
looks sick. I love the flames
redodedo is offline Find More Posts by redodedo
Old Jan 26, 2013, 08:55 PM
SRush99 is offline
Find More Posts by SRush99
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Flew mine again today with my GoPro 3 attached. Winds were 10 - 15 mph. Flew great with the washers at the bottom motor mount holes. I guess as the commercial goes - "your results may vary" when it comes to setting the thrust line of the motor. I also found that the upgraded canopy will get blemished by sunscreen ( it was in the mid 70s today in Texas !) . I tried cleaning the blemishes off with dishwashing liquid with no luck. Also used windex - no change. If you buy one be very careful!
SRush99 is offline Find More Posts by SRush99
Old Jan 27, 2013, 04:23 AM
Amfamora is offline
Find More Posts by Amfamora
Multicopter Crash Tester
Amfamora's Avatar
Australia, QLD, Brisbane
Joined Apr 2012
Installed:
RVOSD v5
Dragonlink
2815 motor
Castle 80amp ESC
Graupner 9x6e prop
600TVL CCD FPV Cam
BEAST!
Amfamora is offline Find More Posts by Amfamora
Old Jan 27, 2013, 05:18 AM
azzurripro is offline
Find More Posts by azzurripro
Australia, SA, Adelaide
Joined Jan 2011
Installed:
RVOSD v5
Dragonlink
2815 motor
Castle 80amp ESC
Graupner 9x6e prop
600TVL CCD FPV Cam
wow great job. What type of paint did you use? what type can you paint on EPO
azzurripro is offline Find More Posts by azzurripro
Old Jan 27, 2013, 09:41 AM
Rick~K is offline
Find More Posts by Rick~K
Rick~K's Avatar
United States, WV, Salt Rock
Joined Nov 2006
Love that paint!!! Believe it or not mine is still in it original shipping box, ( unopened ) waiting on warmer weather. I'll have to go back though this thread to see all the fix's and updates before I start the build. I love this plane...
Rick~K is offline Find More Posts by Rick~K
Old Jan 27, 2013, 09:54 AM
Cpig is offline
Joined Sep 2006
Thanks azzuri,
I started by degreasing the entire plane with soapy dishwashing liquid and water. Then I sprayed Krylon Fusion for plastic as a base coat. Lastly, I airbrushed AutoAir Colors for the flames. I usually do a clear coat as the last step but decided to leave this as is.
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 06:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 02:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 05:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 10:09 PM
