Old Jan 07, 2013, 01:10 AM
simchippy is offline
Find More Posts by simchippy
United States, NJ, Flemington
Joined Oct 2006
Planning a Penguin build and have question for you guys using APM 2.5 with antenna tracking, are you using the 3dr radio to GS or is there a way to tap into the APM GPS to an osd that sends the gps data through the video or audio? Hate to run the extra radio and figure out how to get the additional range to match the video and uhf...
Thx
simchippy is offline Find More Posts by simchippy
Old Jan 07, 2013, 02:09 AM
Amfamora is offline
Find More Posts by Amfamora
Multicopter Crash Tester
Amfamora's Avatar
Australia, QLD, Brisbane
Joined Apr 2012
Is there enough clearance for a 10 inch prop on this plane?
Amfamora is offline Find More Posts by Amfamora
Old Jan 07, 2013, 02:19 AM
ron-sand is offline
Find More Posts by ron-sand
ron-sand's Avatar
Norway, Troms, Tromsų
Joined Sep 2002
There is if you lift the motor about 6-7mm (1/4in). I have done it on my Penguin, swinging a xoar 10x6 with a hacker A30 16L 800kv on 4 to 5 cells
ron-sand is offline Find More Posts by ron-sand
Old Jan 07, 2013, 05:42 AM
Amfamora is offline
Amfamora's Avatar
Joined Apr 2012
Thanks for the tip
Old Jan 07, 2013, 07:19 AM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Can you say unlimited vertical?
Mike Freas is offline Find More Posts by Mike Freas
Old Jan 07, 2013, 07:55 AM
ron-sand is offline
ron-sand's Avatar
Joined Sep 2002
There is no lack of power if there is so to say
Old Jan 07, 2013, 08:06 AM
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
Wow!
cactus is offline Find More Posts by cactus
Old Jan 07, 2013, 12:59 PM
Tim Green is offline
Find More Posts by Tim Green
Joined May 1999
Originally Posted by mark_q View Post
The below image shows recent prop test results for my Penguin which can be found on my Build Log
Nice work.
Tim Green is offline Find More Posts by Tim Green
Old Jan 07, 2013, 01:11 PM
aviatorgeek is offline
Find More Posts by aviatorgeek
PP/IR
aviatorgeek's Avatar
United States, CO
Joined Jun 2012
Thx
That's one of the setbacks of the APM systems. AT is all done through your telemetry radios and cannot be encoded into the video/audio streams like RVOSD and Eagle Tree.
aviatorgeek is offline Find More Posts by aviatorgeek
Old Jan 07, 2013, 05:09 PM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
The below image shows recent prop test results for my Penguin The test was run on my
Mark, do you mind if I add this to the front page here for prop info? Great work!
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Old Jan 07, 2013, 06:27 PM
Cpig is offline
Find More Posts by Cpig
United States, CO, Colorado Springs
Joined Sep 2006
Just measured mine, with a 10" prop I have just under 1/8" clearance with the tail boom. This is without lifting the motor.
Cpig is offline Find More Posts by Cpig
Old Jan 07, 2013, 06:37 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Be my guest! I have also recently done a 10" Multirotor prop test which can be found on my Wiki here:
10" Quad Props
Use anything you like!
mark_q is online now Find More Posts by mark_q
Latest blog entry: X-UAV Mini Talon #2
Old Jan 07, 2013, 06:50 PM
Cpig is offline
Joined Sep 2006
Paint prep
I like to paint but I've never done styrofoam. What do you guys use for paint prep on stryrofoam?
Old Jan 07, 2013, 06:57 PM
cactus is offline
Joined Sep 2001
I found a paint that works good on the canopy gray foam. I used Krylon Plastic in flat black and turned out nice and I can take the canopy on and off without it rubbing off like the stock paint.
Old Jan 07, 2013, 07:04 PM
fpvbasher is offline
Find More Posts by fpvbasher
Joined Sep 2012
ive brushed faskolor on multiplex foam and it lasted well over 2 years of flying, itd be better if i had a good airbrush
fpvbasher is offline Find More Posts by fpvbasher
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
