Old Jan 03, 2013, 01:17 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Originally Posted by Cpig View Post
This is probably a stupid question but what prop do I need if running the 2815 motor on 4s. The Finwing website says APC9060 but NOT EP 9060. The only APC pusher prop that I find is APC 9060EP, is this the same EP 9060 they say not to use? Will this prop work or not?
The below image shows recent prop test results for my Penguin which can be found on my Build Log. The test was run on my bench tester with an HK SK3530-1400 Motor (2815-1400 equiv.) and 3S Packs. The first 5 props shown on this chart are 9x6, the last one is a 9x5.
I selected the Xoar 9x6 for mine because it is really quiet and they are darn near perfectly balanced. Pusher props generally just reverse the rotation and were originally designed to accomodate a Glow engine which will only run one direction. Some of the prop manufacturers like Master Airscrew also move the centering bushing to the opposite side of the hub for a better fit (too bad they are so inefficient ).
The APCe props work really well, they are just a bit noisier than pretty much everything else. If you are going with 4S and a KV around 1400, go for the Graupner 9x5 eProp also shown on this chart (make sure it's the eProp). This prop is wicked on 4S.
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Jan 03, 2013, 02:21 PM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
Looks like you are using very similar hardware as what I am building.
How do you like the Bluebird 385DMAX servos??
I am installing a Turnigy Aerodrive SK3 - 3536-1200kv I am finding it very powerful with the stock 3 blade prop. How about you?
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Jan 03, 2013, 02:43 PM
swartzracing is offline
Find More Posts by swartzracing
Aerial Operator
United States, CA, Sacramento
Joined Feb 2012
Originally Posted by fpvbasher View Post
no problem came upon that discovery on the crapper a while back..
haha isn't it amazing the things you come up with when your on the pot.
swartzracing is offline Find More Posts by swartzracing
Old Jan 03, 2013, 04:08 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Well, I went ahead and got a Zippy Flightmax 3s 5000 20C pack for $20. Going to do some flight testing with the APC 9x7.5E and the 9x9E props on my 3530 1400KV setup and see how I like it. I am on the light side for setups, no GoPro so I am hoping for 25min flights on average. I am trying to strike a balance between flight time and lighter weight for spirited performance at my altitude.
cactus is offline Find More Posts by cactus
Old Jan 04, 2013, 03:10 PM
garrettt04s is offline
Find More Posts by garrettt04s
3d Master in Training
United States, PA, Tunkhannock
Joined Dec 2011
Would the FY-21 with gps be a good choice for this plane
garrettt04s is offline Find More Posts by garrettt04s
Old Jan 04, 2013, 03:28 PM
wootenelli is offline
Find More Posts by wootenelli
Michael W.
wootenelli's Avatar
United States, TN, Cleveland
Joined Nov 2011
hey guys, I have a penguin withthe 2815 motor, fpv set up with 2 2700 mah batts in parralell. i did have her an inch or so forward of the COG, but it was considerably hard to fly. i have moved the cg back and upgraded the prop and have yet to fly a second flight...any other advice that could help flight performance? I am just shocked that everyone else said she was so easy to fly...mine was hard to keep steady! if it had not been for the stabilize mode on my apm 2.5, I think i might have lost her...what say you all? I can post pics and auw when I get home
wootenelli is offline Find More Posts by wootenelli
Old Jan 04, 2013, 03:31 PM
Michael W.
wootenelli's Avatar
Joined Nov 2011
i am sure it would...any of the APs with this plane have had good reports...i fly with the apm 2.5 and it was rock solid while in stabilize mode....if you are considering upgrading to a RTH set up, at 179 bucks the apm2,5 is hard to beat and upgradeable as hell
Old Jan 04, 2013, 03:38 PM
Joined Dec 2011
Does the apm 2.5 also control the throttle during failsafe rth
Old Jan 04, 2013, 03:40 PM
Mike Freas is online now
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
I believe it does.
Mike Freas is online now Find More Posts by Mike Freas
Old Jan 04, 2013, 03:45 PM
fpvbasher is offline
Find More Posts by fpvbasher
Joined Sep 2012
hard to beat rctimer on the apm 2.5 im considering one,
http://rctimer.com/index.php?gOo=goo...cat=206&gtype=
fpvbasher is offline Find More Posts by fpvbasher
Old Jan 04, 2013, 04:25 PM
Joined Dec 2011
What the differences
Old Jan 04, 2013, 08:00 PM
Cpig is offline
Find More Posts by Cpig
United States, CO, Colorado Springs
Joined Sep 2006
Great info Mark and thanks for posting it. I've always loved the Zoar props, I fly them on my 3D planes; always balanced, lightweight and super efficient with their light weight. I may try a Zoar and your recommendation - Graupner Eprop, which I also like, I run them on my Quad. I may go for 9x6 though as I fly at over 6000' MSL so I need a little extra push.
Cpig is offline Find More Posts by Cpig
Old Jan 04, 2013, 08:03 PM
Cpig is offline
Joined Sep 2006
ep9060 is a slow flyer prop
you can use either the apc 9x6 or the pusher version apc 9x6p one just rotates in the opposite direction.
the regular apc 9x6 is easier to come by though.
Thanks for the help fpvb
Old Jan 04, 2013, 08:14 PM
Cpig is offline
Joined Sep 2006
I'd recommend the original, American version. I'm running one on my quad and like it a lot. A few reasons to consider the 3DR / US version:
1. You're American, stop supporting China and show some support for your own country's businesses and economy. Also putting money back into the developers of this board gives them more R&D cash to develop better products for you and I. Giving money to China just supports more theft of our ideas.
2. The 3DR version comes with a power module which works great to keep track of mAh burned as well as supplying required voltage to your board and peripherals.
3. Highly recommend the $50 upgrade to the Ublox LEA-6 GPS. This thing is by far the best GPS I've ever seen (I've see a lot). I live in a 3 story house and this gets lock in the middle of my basement.
Old Jan 04, 2013, 09:25 PM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
Anyone see a issue on how I routed my DL UHF antenna?
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
