Old Jan 02, 2013, 05:08 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Hitec HS81 or HS85 for aileron? I have the HS85MG and 65MG on elevator and rudder.
blueprint is offline Find More Posts by blueprint
Old Jan 02, 2013, 05:24 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
I put 81's on ailerons and the MG equivlent (82 i believe) on the elevator. 65 HB on the rudder. The only reason I used these is I happened to have them. I almost put 65HB's on the ailerons and I'm sure they would have been fine.
Mike Freas is offline Find More Posts by Mike Freas
Old Jan 02, 2013, 05:43 PM
swartzracing is offline
Find More Posts by swartzracing
Aerial Operator
United States, CA, Sacramento
Joined Feb 2012
I know we've covered this topic before but I'm still trying to figure out if I need the spacers on the motor mount. At this point I have not used any spacers and the penguin flies good, but we RCGroupers are never satisfied lol!
Look forward to hearing back!
Cheers,
swartzracing is offline Find More Posts by swartzracing
Old Jan 02, 2013, 05:49 PM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
Originally Posted by robstach View Post
Am curious about the type of paint you used.. if you don't mind sharing! Looks great!
Thanks in advance!
Primer Tamiya White Primer, with Faskolor paint. I used the Faskolor paint on an Easystar2 (EPO) without primer and it is wearing pretty good I have about 20 flights on it. I believe the primer may make the paint even more durable not sure if it is worth the additional step and cost. (Tamiya primer is expensive)
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Jan 02, 2013, 06:53 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
Thanks Tom!
I also build models so I have tamiya primer on the shelf. I'm willing to bet that you're right - the primer gives the paint something to bite into.
Thanks a ton!
robstach is offline Find More Posts by robstach
Old Jan 02, 2013, 07:44 PM
SRush99 is online now
Find More Posts by SRush99
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Got my Penguin in the mail today - looking forward to flying it as soon as I can get it built and the weather clears. I have a GoPro 3 on order and plan to start flying it LOS, then upgrade to FPV later. Great thread!
-Stuart
SRush99 is online now Find More Posts by SRush99
Old Jan 02, 2013, 08:05 PM
Cpig is offline
Find More Posts by Cpig
United States, CO, Colorado Springs
Joined Sep 2006
Prop for 2815 on 4s
This is probably a stupid question but what prop do I need if running the 2815 motor on 4s. The Finwing website says APC9060 but NOT EP 9060. The only APC pusher prop that I find is APC 9060EP, is this the same EP 9060 they say not to use? Will this prop work or not?
Cpig is offline Find More Posts by Cpig
Old Jan 02, 2013, 08:06 PM
Maxintheair is offline
Find More Posts by Maxintheair
Canada, ON, Moonstone
Joined Sep 2011
Did my maiden flight today, it was great!!!!!!! 25min flight on a 3300mAh 3cell batt!
I can't wait to throw some paint on it and start FPVing it!
Maxintheair is offline Find More Posts by Maxintheair
Old Jan 02, 2013, 08:53 PM
fpvbasher is offline
Find More Posts by fpvbasher
Joined Sep 2012
ep9060 is a slow flyer prop
you can use either the apc 9x6 or the pusher version apc 9x6p one just rotates in the opposite direction.
the regular apc 9x6 is easier to come by though.
fpvbasher is offline Find More Posts by fpvbasher
Old Jan 02, 2013, 09:05 PM
Joined Sep 2012
Cheers,
hope this explains it ok..
the firewall has 2 sets of mounting holes, an inner and an outer, depending on the set it depends on which spacers you use, the inner gets the smaller and the outer gets the bigger, if you use the bigger on the inside it throws off the geometry.
Old Jan 02, 2013, 11:56 PM
LandoV2 is offline
Find More Posts by LandoV2
USA, CA, Irvine
Joined Apr 2009
so with the proper spacer the motor should end up pointing straight back (horizontal) with out any up or down tilt. is this correct?
LandoV2 is offline Find More Posts by LandoV2
Old Jan 03, 2013, 03:19 AM
Aerial Operator
Joined Feb 2012
Thanks for clearing that up! Much Appreciated.
Nice Drawing too!
Cheers,
Old Jan 03, 2013, 05:01 AM
Joined Sep 2012
Nice Drawing too!
Cheers,
no problem came upon that discovery on the crapper a while back..
Old Jan 03, 2013, 09:00 AM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
I am trying to decide if I want to go 4s or 3s on my setup. I have only flown it with 3s on the APC 9x6E prop and it lacked power here at 7300 ft. Typically I up the pitch or diameter or both to compensate for the thinner air. I bench tested 4S with the 9x6 prop and I was at 38 amps static at ~90% throttle on a 3.9v per cell charge. The best I ever got on my 3S bench tests was 29-30 amps WOT. I am using the NTM 3530 1400kv motor with 40 amp ESC from HobbyKing. I am concerned the KV is a little high for this prop.
I ordered the APC 9x7.5E and 9x9E props to bench test on 3s. I also started using a voltage regulator (step up/down) for my video system so I can use whatever battery I want and not have to worry about it.
cactus is offline Find More Posts by cactus
Old Jan 03, 2013, 12:40 PM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
In an effort to be 100% in compliance with regulations I ordered a vinal sticker from buildasign.com with my contact information, AMA, and HAM. Cost me 3.26 shipped. I guess I could have done it myself but it would not have been as neet looking.
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
