Old Dec 31, 2012, 09:23 AM
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Originally Posted by blueprint View Post
Anybody using the readymaderc pan/tilt kit? If so please post a picture of your setup. Working on my camera setup now.
Ok ... Some pics attached, but it's on a rover, not a Penquin.
Tim Green is offline Find More Posts by Tim Green
Old Dec 31, 2012, 10:21 AM
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Blueprint, I'm using the RMRC pan/tilt on my penguin. I originally had it on my Radian pan/tilt pod and found that if I just made a new mount with that octagonal shape that it fits perfectly into under the canopy. Upgraded canopy, that is. It fit fine under the stock one but was a little close to the top even at the lowest screw holes. The upgraded canopy will allow to go higher to have less nose in view.
Description:
Description:
Description:
superevan is offline Find More Posts by superevan
Old Dec 31, 2012, 12:07 PM
imagebuff's Avatar
United States, TX, Tomball
Joined Jan 2011
Penguin Build Mods
I've finally completed the FPV mods to the Penguin so finally posting some photos. Most of the time I invested was around wiring and the removable FPV canopy. Almost every cable is customized and I used CAT 6 everywhere I could squeeze it in. After flying nothing but FPV wings I was very used to having easy access to the wiring and even the very generous room within the Penguin was a bit confining for working with a complete Eagletree system
I set out with a few goals:
- Full Pan / Tilt w/ head tracking for both the flight cam AND GoPro
- Nose not in view for either camera while facing forward
- Cleanest video possible - Use CAT 6 everywhere I can
- Minimize wiring rats nest
- Single cable connection to FPV canopy for easy removal for battery change, etc..
- Eagle Tree Pod - Be able to pull out the full Eagle Tree system with minimal effort for bench diag / test.
While I was mostly successful on these goals I couldn't put the entire ET system on a single pod because some of the sensors simply cannot be located near the eLogger and OSD. The barometer and airspeed sensors were built into the hollow part of the wing for proximity to the pitot tube installation and easy connect / disconnect w/ the wings. I haven't re-maidened with the added FPV gear yet. I am concerned about weight so we will have to see how it goes. Hope this gives someone some ideas
imagebuff is offline Find More Posts by imagebuff
Old Dec 31, 2012, 02:39 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by garrettt04s View Post
Im new at fpv and was wondering whats a good flight controller that has gps with hold and rth functions? Dont want to spend a fortune and want something easy to set up.
Are you looking for something for fixed wing or multirotor? When yhou say 'flight controller' most people think 'multirotor'. For fixed wing I use Dragon OSD with GPS. It has RTH, AutoPilot, Waypoint capability and provides all the needed flight info on your video screen.
Vantasstic is offline Find More Posts by Vantasstic
Old Dec 31, 2012, 03:09 PM
United States, PA, Tunkhannock
Joined Dec 2011
Fixed wing for the penguin
garrettt04s is offline Find More Posts by garrettt04s
Old Dec 31, 2012, 05:01 PM
cactus's Avatar
Durango Colorado
Joined Sep 2001
Attachment 5409918
Attachment 5409919
Attachment 5409920
That is a nice and clean adaption of that mount. Well done.
cactus is offline Find More Posts by cactus
Latest blog entry: FPV mQX
Old Dec 31, 2012, 05:08 PM
cactus's Avatar
Durango Colorado
Joined Sep 2001
I hope your re-maiden is successful. I too implemented shielded wire for my video system. I was concerned about using standard wiring all the way out to the wing tip. Since the payload capacity affords us some "slop" in how we equip it, I chose to separate the VTX, UHF antenna and the GPS and use good wiring to do it.
What paint did you use on the canopy foam? I noticed mine is rubbing off and starting to look crummy.
Old Dec 31, 2012, 05:12 PM
cactus's Avatar
Durango Colorado
Joined Sep 2001
Like Vantastic says, the DOSD is a great choice for the Penguin. There are some complaints about how the text looks, but rest assured it does the job. He is also very helpful on the DOSD thread if you have questions on setting it up.
Alternatively, if you just want basic GPS based information and do not need RTH, etc. I recommend looking at the SkyLark Tiny OSD.
Old Dec 31, 2012, 05:19 PM
Tom.in.Maryland's Avatar
Joined Mar 2012
First Airbrush Shot at Yellow Penguin
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Dec 31, 2012, 05:41 PM
cactus's Avatar
Durango Colorado
Joined Sep 2001
Tom, you can't call it a Penguin anymore. Maybe the Duck.... One thing is it will be easy to spot in the snow.
Old Dec 31, 2012, 05:45 PM
superevan's Avatar
Joined Aug 2007
Thanks Cactus, poor Radian looks headless now!
Old Dec 31, 2012, 07:29 PM
imagebuff's Avatar
Joined Jan 2011
I experimented with Plasti-Dip spray and it turned out to be perfect for foam as it is rubbery and plyable and really holds up to alot of handling. The original paint came off if I just looked at it funny.
Have you gotten yours up in the air yet w/ the FPV gear?
Old Dec 31, 2012, 07:41 PM
Rotary
blueprint's Avatar
Joined Sep 2007
thanks for posting that! i have the new canopy and planned on installing my Pan/Tilt system the way you had although i would like to keep my gopro2 below the pan/tilt rather than above it.
blueprint is offline Find More Posts by blueprint
Old Dec 31, 2012, 07:59 PM
Joined Jan 2007
Well, depending on the snow...
healthyfatboy is offline Find More Posts by healthyfatboy
Old Dec 31, 2012, 08:09 PM
United States, CA, Sacramento
Joined Feb 2012
Decided to take the penguin out again today since the wind was down around 2-4mph, lots better than yesterday's 17+mph. Today was the first day I was able to try the FY31AP+Hornet OSD and I am very happy with it. With all gains set to about 1'o-clock the penguin flew great. This is my first autopilot so I was kind of skeptical on my plane flying itself. I tested RTH, ABM, and ACM they all worked as advertised. I even got up to about 600 meters and was out around a half mile, shut off my tx and watched my bird fly home.
My video feed was rock solid with the 800mw 1.3ghz with the ibcrazy bluebeam set. My bird is sitting at 2.1kg and wants to fly forever!
Just wanted to thank everyone on RCG that has helped me build this LR bird.
Happy New Years!
swartzracing is offline Find More Posts by swartzracing
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp Video Piloting (FPV/RPV) 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
