Old Dec 25, 2012, 04:51 PM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
Originally Posted by nakelp86 View Post
I think that suppose to be one for horizontal stab, I used flat CF instead
Am I correct that this 4mm x 400mm CF Rod is to be installed in the tail???
There is no groove or hole I would have to cut a grove into the tail for this. I see that the horizontal stab/elevator is weak without some sort of spar.
Please advise how did you add to make the tail sturdy???
See pic...
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Dec 25, 2012, 04:59 PM
Enn0L is offline
Find More Posts by Enn0L
Joined Aug 2011
See pic...
I used a hobby knife to cut a "canal" for the spar and used some of the stocked glue to hold it inside. Also put a piece of tape over that to reinforce.
It's also written in Finwing site: http://www.finwinghobby.com/faq_view.aspx?id=22 (picture 5)
Name: Photo 18-12-12 13 58 55.jpg
Description:
Enn0L is offline Find More Posts by Enn0L
Old Dec 25, 2012, 05:30 PM
Joined Mar 2012
I am finding that the Turnigy Aerodrive SK3 - 3536-1200kv Brushless Outrunner Motor running on 4S LiPo and the stock 3 blade 9x5 prop produces a tremendous amount of thrust.
Are other Penguin users finding a hugh thrust from their setups?
Merry Christmas to all and to all a good fly!
Tom
Old Dec 25, 2012, 06:31 PM
nakelp86 is online now
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
See pic...
yep, there is no groove this is why its easier to instal flat CF rod.
Have no idea why they are supplying the round one, way over sized .
If you can get the flat one :
http://www.rcfoam.com/product_info.p...66a023578c4226
Cut the foam with exacto knife (not through the stab) and push the CF in on glue.
nakelp86 is online now Find More Posts by nakelp86
Old Dec 25, 2012, 07:26 PM
peter.braswell is offline
Find More Posts by peter.braswell
peter.braswell's Avatar
United States, VA, Chesterfield
Joined Apr 2008
See pic...
You are right . No grove. I think this was am afterthought. I used a straight edge and a soldering iron to melt a groove in the stab. Worked great.
Peter
peter.braswell is offline Find More Posts by peter.braswell
Old Dec 26, 2012, 04:40 PM
Tim Green is online now
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
See pic...
I cut off a bit of the leading edge, and put the rod there - pic attached.
Tim Green is online now Find More Posts by Tim Green
Old Dec 26, 2012, 05:18 PM
Nakelp
nakelp86's Avatar
Joined Sep 2004
this may work as a small brake and doesnt help much to make the stab stiffer
round CF would do better in front but still not good to make the stab stiff.
Old Dec 26, 2012, 05:48 PM
xxD-Manxx is offline
Find More Posts by xxD-Manxx
Go Fly Yourself...!!
xxD-Manxx's Avatar
United States, WA, Bonney Lake
GoPro mount..
Greetings kids..
I've been flying and FPVing my Penguin over the last month or so trying to decide how to incorporate the GoPro.
I was excited when the upgraded canopy came out thinking the GoPro would mount up there easy as pie. Truth is it probably would but I didn't like the idea of that much weight so high. Plus also noticed a significant amount of distortion through the thicker canopy (FPV tested with and without the canopy).
My solution (for now) was to cut out the canopy so my FPV camera doesn't have to look through it. And using a little heat from my covering gun to make a flat mounting spot for the GoPro lower than stock. (See Pics attached).
Hope to test it this week but wanted to share today's work with all y'all.
Hope someone finds this helpful.
D-Man
xxD-Manxx is offline Find More Posts by xxD-Manxx
Old Dec 26, 2012, 05:57 PM
Joined Mar 2012
Peter
The soldering iron method worked great!!! Thanks for the advise.
Tom
Old Dec 26, 2012, 06:11 PM
Ashtabula, OH USA
Joined May 1999
There's no extra drag, so I don't understand your statement about the small brake.
It was a round rod, BTW.
And it makes the stab plenty stiff - else I wouldn't have recommended it.
Old Dec 26, 2012, 07:38 PM
McCleary.11 is online now
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
Originally Posted by DFloth View Post
Greetings kids..
D-Man
I like what you are doing here. The upgrade canopy is not clear enough for my liking. You might want to add some bigger holes to the back of it though. Even with the ones you made, I think it will be a huge air brake.
Edit: I also just noticed the placement of your Vtx behind the canopy. I like it! Do you have a better pic of that?
McCleary.11 is online now Find More Posts by McCleary.11
Site Sponsor
Old Dec 26, 2012, 07:59 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
'huge air brake' is a massive understatement. I would bet the plane would not even ROG like that. The area of the air scoop would be like putting 5 Gopros on the front. And I have heard some folks say the GoPro cuts their flight times by up to half already.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Dec 26, 2012, 08:55 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I'd have to agree. That big open scoop is going to catch a lot of air. I was thinking of cutting my thicker canopy all the way around so all that was left is basically a plastic support to help support/hold the shape of the foam canopy base. Then I'd mount the GoPro to the forward section of foam. I'm not sure if I'll do that yet...really need to get back to work on the Penguin...but that's what I've been milling around in my head.
Vantasstic is offline Find More Posts by Vantasstic
Joined Mar 2006
Yes, after looking at it again, I would make some huge holes (like the size of your fist) in the back and just leave the sides and top center to support the Gopro.
Site Sponsor
Old Dec 26, 2012, 09:22 PM
Nakelp
nakelp86's Avatar
Joined Sep 2004
My bad , I thought it was a flat piece
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 06:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 02:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 05:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 10:09 PM
