Old Dec 19, 2012, 05:51 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Anybody here using stabilization such as the FY30? How did it perform?
blueprint is offline Find More Posts by blueprint
Old Dec 19, 2012, 05:54 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
Originally Posted by DFloth View Post
Hope someone finds this helpful.
D-Man
pretty cool, never thought of putting a folding prop on a pusher, great idea! i'm going to try this out
CrashAffinity is offline Find More Posts by CrashAffinity
Old Dec 19, 2012, 05:56 PM
Tim Green is online now
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Yes. And I prefer the Guardian, because it's got adjustable gain during flight and via pots, and consumes a lot less mah - the FY30A is spec'd as requiring min 3A from the BEC. And the FY30A only allows mode selection from the xmit, not gain.
As to differences in their algorithms, if any - I'm not expert enough to comment on that.
But it did work. 2 modes, same as Guardian.
Tim Green is online now Find More Posts by Tim Green
Old Dec 19, 2012, 07:34 PM
xxD-Manxx is offline
Find More Posts by xxD-Manxx
Go Fly Yourself...!!
xxD-Manxx's Avatar
United States, WA, Bonney Lake
Blueprint...
I'm using an EagleTree Guardian really smooths the plane out and is great for heading hold.
Rudder only flat turns are a blast!
D-Man
xxD-Manxx is offline Find More Posts by xxD-Manxx
Old Dec 19, 2012, 08:25 PM
fpvbasher is offline
Find More Posts by fpvbasher
Joined Sep 2012
thats what i like the most about stab., set the throttle and i can putt around the whole time gawking around.
ps stock guardian, with gain on a knob, usually only run at 3 or so
fpvbasher is offline Find More Posts by fpvbasher
Old Dec 19, 2012, 09:58 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
I am using the Guardian too, but have only logged one flight before the snow hit.
cactus is offline Find More Posts by cactus
Old Dec 19, 2012, 10:02 PM
Moelich73 is offline
Find More Posts by Moelich73
Bazinga!
Moelich73's Avatar
South Africa, KZN, Durban
Joined Feb 2007
I use the FY30 and it works great. I haven't noticed that it draws any significant current. My complete flight system including FPV gear draws less than 0.4A when motor is at idle, which is about the same than without the FY30.
Flights in windy conditions are much smoother, and I also use it for takeoff and landing. Makes you a bit of a lazy pilot though...
You can adjust the gains on the FY30.
Moelich73 is offline Find More Posts by Moelich73
Old Dec 20, 2012, 02:53 PM
Rogue.insight is offline
Find More Posts by Rogue.insight
United States, OH, Westlake
Joined Jun 2012
Has anyone used the ArdupilotMega yet? I see a lot of eagletree users. I've found that the APM is cheaper, unless I'm mistaken.
Rogue.insight is offline Find More Posts by Rogue.insight
Old Dec 20, 2012, 03:28 PM
Mcrock is offline
Find More Posts by Mcrock
Mcrock's Avatar
New Zealand, Waikato, Hamilton
Joined Aug 2012
I have seen a couple on here using it..
I personally am using Ruby and have some fantastic support.. Hopefully soon I will be able to drop the ImmersionRC OSD and use the Ruby solution when it becomes available.
Now you can purchase the Orange tx from Hobby King and use the satellite receivers from Orange which plug directly to Ruby Bind if you only require around 1500 metres range. or you can use a long range system. Or S_Bus reciever.
Mcrock is offline Find More Posts by Mcrock
Old Dec 20, 2012, 06:57 PM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
Where do you have the gain potentiometers set at - full counter clockwise is high gain clockwise is less gain - where are yours set at???
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Dec 20, 2012, 09:29 PM
Bazinga!
Moelich73's Avatar
Joined Feb 2007
I have aileron gain set at about 90% from center (almost full gain), and the elevator and rudder about 60% from center.
Keep in mind that center position is zero gain. From there, clockwise or counter clockwise gives you gain/corrections in different directions (depending on your setup you will have to choose which direction is the correct one for your plane).
I'm still playing with settings though so those numbers are not final.
Old Dec 20, 2012, 11:18 PM
wootenelli is offline
Find More Posts by wootenelli
Michael W.
wootenelli's Avatar
United States, TN, Cleveland
Joined Nov 2011
I am using the amp2.5 currently. only logged 2 flights, but it works amazingly well with the stock params.
wootenelli is offline Find More Posts by wootenelli
Old Dec 21, 2012, 07:14 AM
xxD-Manxx's Avatar
After shopping around for my first autopilot.... I just placed my order for a APM 2.5 yesterday.
At 230.00 for the autopilot and fully configurable OSD I couldn't find a better bargain.
The guardian is great for stability... but want the peace of mind of RTL.
D-Man
Old Dec 21, 2012, 08:40 AM
Joined Jun 2012
I too decided on APM after shopping around. I even have an APM 1 that I haven't used and it's been on my shelf for a year! I prefer the APM becasue all the hardware is in one place. I'll post a pic of my penguin setup soon. It made the whole thing really clean inside. I almost feel guilty that I haven't used up the space.
Also, RCTimer has the APM hardware for about $90! Quite a difference.
Old Dec 21, 2012, 09:11 AM
Joined Mar 2012
Thanks this is helpful info, do You know where the manual is available in english???
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
