I received my Penguin a few days ago, but didn't pull it out of the box until tonight. I must say I'm pretty impressed with what I see. I was expecting the horizontal stab would have a groove for the c/f tube stiffener....nope. It won't take much to add, but really thought it would of already been there. I look forward putting this together and getting it in the air.
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
United States, NC, Goldsboro
Joined Mar 2012
Haven't had chance to fly it again. I don't think its the motor. |
Falls Church, VA
Joined Jun 2009
It is moving, shaking even in the air. And after landing on grass it was teared from fuse with rudder finn together. Finally I glued it and put some of a piano wire (about 10cm) under tail. Now don't have any questions. |
milwaukee wi usa
Joined Nov 2000
since the servo/ linkage is mounted in the fuse....even a slight knock may move the horizontal resulting in an out of trim elevator. i just tack glued mine in a couple of places. if the horizontal ever needs to be removed, i can do so without creating a real mess. hope this helps. enjoy your new toy! rbt |
I wish I could be that confident in my R/C skills... Have you seen the Bixler tail attachment mods? Paul |
I can see how the stab could rotate some with the single screw retention method. Adding a second screw, either further forward of back, may reduce/eliminate that tendency. I can take a look at options later on. Really I probably would be just fine gluing it in place and not worry re-engineering anything. I need to clear off my hobby desk so I can start the build first though...
Falls Church, VA
Joined Jun 2009
You couldn't bind it strong enough, cause it is foam. A option is one only - to glue it. |
But, I used a washer and tightened it Very tight. Buried it at least ¼ inch into the foam forward of the other one. There is a Wood stiffener in the Vert Fin, I just used a wood screw that went up into that wood. ( 1 ½ inches long I think) |
| Thread Tools | |
| Discussion fmkit's ULink (review/discussion/etc) | CrashMeUp | Video Piloting (FPV/RPV) | 112 | Apr 07, 2013 05:34 PM |
| Discussion general engine discussion thread | cale10 | Engines | 273 | Nov 13, 2012 01:22 PM |
| Spektrum DX7 technology discussion (moved from review thread) | Chipwillis | Radios | 62 | Jan 17, 2007 04:07 PM |
| Heliup.com CNC CF Shogun/Zoom frame build thread/review | Hoverup | Mini Helis | 123 | Jun 18, 2005 09:09 PM |
