Old Oct 13, 2012, 10:11 PM
Neewbie is offline
Find More Posts by Neewbie
Joined Oct 2012
I don't understand why there is no instruction in the manual on how to mount the 3 blade prop especially for an aircraft where the motor is facing aft and not fwd.
Correct me if I am wrong ....
Mount the prop with the GWS label facing the nose.
Or mounting of the prop does not matter just swap two legs of the motor to change rotation direction.
Neewbie is offline Find More Posts by Neewbie
Old Oct 13, 2012, 10:23 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
U dont need instruction just look at the blades.
Yes, lettering is facing nose of the plane, but you more likely will switch to two blade soon :-)
nakelp86 is offline Find More Posts by nakelp86
Old Oct 13, 2012, 11:31 PM
Neewbie is offline
Joined Oct 2012
When installing the carbon rod or in my case I opt for the flat carbon strip on the horiz stab, does it matter whether it goes near the leading edge or trailing edge.
Old Oct 13, 2012, 11:34 PM
Neewbie is offline
Joined Oct 2012
So what brand, size or part number of prop would I use if I decide to change it from a 3 blade to a 2 blade. Using the M2220 motor stock.
Old Oct 13, 2012, 11:35 PM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
No, it doesn't really matter. Just make sure it is long enough. I would also use tape or covering on the leading edge.
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Old Oct 14, 2012, 06:11 AM
fpvbasher is offline
Find More Posts by fpvbasher
Joined Sep 2012
APC 9x6 seems to be the concensus, about 2.50 direct from APC
fpvbasher is offline Find More Posts by fpvbasher
Old Oct 14, 2012, 08:48 AM
Tim Green is offline
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
I installed mine to the leading edge, after cutting out a small notch in the leading edge for it to sit in. Yes - my carbon fiber rod is the leading edge of my horizontal stabilizer. Seemed easier to do it that way.
Tim Green is offline Find More Posts by Tim Green
Old Oct 14, 2012, 09:19 AM
rbtgold is offline
Find More Posts by rbtgold
milwaukee wi usa
Joined Nov 2000
hello gang
im making slow but steady progress and mounting the flight camera is next on the list. my question is: does anyone have experience with your camera placed within the clear canopy? eyeballing through it sure seems your view would have a major case of distortion/glare. (i have yet to crank up the vid for a trial run).
thx much
rbt in mke!
rbtgold is offline Find More Posts by rbtgold
Old Oct 14, 2012, 09:55 AM
Joined Mar 2006
Originally Posted by rbtgold View Post
hello gang
thx much
rbt in mke!
Yep, my first 3 videos were all taken with the canopy on.
Site Sponsor
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Feb 2007
So, about the washers for the motor mount. Could it be that it needs to be on top if the prop turns one way but then put on bottom if their prop spins the other direction? I can't remember my physics anymore but maybe the direction of the torque changes depending on the spin of the prop?
healthyfatboy is offline Find More Posts by healthyfatboy
Old Oct 14, 2012, 10:01 AM
Joined Mar 2006
That's a good point. When changing props, I have had to switch the motor direction, but I didn't notice anything different in the air.
Site Sponsor
Old Oct 14, 2012, 11:10 AM
rsowder is offline
Find More Posts by rsowder
rsowder's Avatar
San Francisco
Joined May 2009
Penguin Maiden
I maidened mine this week. It flew great. No trim needed. I flew it FPV on the maiden flight. Took it out about 1.5 miles and tested the RTH. Worked perfect. I had the 3 blade prop on it and I think that made it a little underpowered. So, I'm going to try a 2 blade 9x6 APC tomorrow.
Now I just need to get some paint on it. Oh, and I did a couple mods. I replaced the spar screws with pins. Much quicker and easier to install the wings. And I replaced the canopy screws with magnets. Those screws were a pain to deal with.
Here a short video of the flight:
Penguin Maiden (2 min 45 sec)
rsowder is offline Find More Posts by rsowder
Old Oct 14, 2012, 12:43 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
http://youtube.com/watch?v=JeBm3bGZ2MM
Can you provide info on your FPV setup?
Mike Freas is offline Find More Posts by Mike Freas
Old Oct 14, 2012, 12:57 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
That looks like a very nice, uneventful flight! Is that shot from within the canopy or did you remove the clear plastic covering?
erkq is offline Find More Posts by erkq
Old Oct 14, 2012, 06:00 PM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
Yeah, for 2815 you have two thicker washers (little wooden circles )
Were are these washers suppost to be?
The only washer that I had found was in the sack, and placed at the back of the plane during assembly.
I have had the motor out and I have not seen any wooden washers there.
THX in advance.
Flybynight2 is offline Find More Posts by Flybynight2
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 06:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 02:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 05:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 10:09 PM
