Joined Oct 2012
Can you listed the dimension or part number of CF you used? |
This is what I used:
Carbon Fiber Strip: 4mm x 1mm, 1m Long http://www.readymaderc.com/store/ind...roducts_id=465 |
Here is the one its long but you will use the rest |
I'll post all construction pix on the other thread lets keep this for discussion and other technical stuf on the other thread before it all becomes big mess. :-)
here is the construction thread: http://www.rcgroups.com/forums/showt...7#post22977185 |
![]() I'll search for the "other thread" but just in case, would someone mind posting it. If I missed it, sorry. (Found it. FPVL, I presume) Best, Steven |
Wished there was a better pic. Guess it works. Thanks for the info. Gy the way you use a Ring on your GPS? |
Ferrite ring wont hurt anything and you want it as close to GPS as possible ( another reason to extend wires is to have at least 5 loops on ferrite) |
If you are using the stock ET equipment and haven't modified any of the plugs, that extension cable works just fine. The GPS unit already has a ring built into it, but adding another couldn't hurt.
| Thread Tools | |
| Discussion fmkit's ULink (review/discussion/etc) | CrashMeUp | Video Piloting (FPV/RPV) | 112 | Apr 07, 2013 05:34 PM |
| Discussion general engine discussion thread | cale10 | Engines | 273 | Nov 13, 2012 01:22 PM |
| Spektrum DX7 technology discussion (moved from review thread) | Chipwillis | Radios | 62 | Jan 17, 2007 04:07 PM |
| Heliup.com CNC CF Shogun/Zoom frame build thread/review | Hoverup | Mini Helis | 123 | Jun 18, 2005 09:09 PM |
