Old Oct 04, 2012, 09:39 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Originally Posted by Hmerly View Post
Has anyone laminated the wings? Do you think it would add an aappreciable durability and strength?
I think wings are much stronger than Skywalker's I guess the tape on LE would do it.
nakelp86 is offline Find More Posts by nakelp86
Old Oct 04, 2012, 10:46 PM
Tony97 is offline
Find More Posts by Tony97
Tony97's Avatar
Joined May 2004
Description:
I put plane build on hold and worked on camera setup.
Tony97 is offline Find More Posts by Tony97
Old Oct 05, 2012, 12:18 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Does anybody know how to program the speed controller that came with the kit? I plugged my ESC in and think the throttle servo channel is reversed. Went into some kind if program mode. I think when I moved the stick forward and back couple times I accidentally programmed it.
Old Oct 05, 2012, 12:36 PM
rbtgold is online now
Find More Posts by rbtgold
milwaukee wi usa
Joined Nov 2000
http://www.finwinghobby.com/faq_view.aspx?id=23
rbtgold is online now Find More Posts by rbtgold
Old Oct 05, 2012, 02:55 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Thanks for the post on the speed controller.
I'm going to go with Tim's idea and put the pilot tube in the wing. Does anyone know where to get more tubing? I didn't see any on RMRC. I think the inside diameter is 1.5 mm. I think you could get away with 2. I was thinking to use retract pneumatic tubing. I tried five Hobby shop so far and cannot find any plus I think it would be much more expensive than cheap silicone tube.
Old Oct 05, 2012, 04:29 PM
CN I Dawg is offline
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
The sensor is based on static vs "ram" or dynamic air pressure, not flow. Therefore, it should be possible to use good old silicon nitro fuel tubing. Most hobby places carry this. I think 3DR and Sparkfun carry it as well.
Best
Steven
CN I Dawg is offline Find More Posts by CN I Dawg
Old Oct 05, 2012, 10:47 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Steven,
Thanks. I will try that option as well.
Originally Posted by CN I Dawg View Post
The sensor is based on static vs "ram" air pressure, not flow. Therefore, it should be possible to use good old silicon nitro fuel tubing. Most hobby places carry this. I think 3DR and Sparkfun carry it as well.
Best
Steven
Old Oct 05, 2012, 10:50 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Home Depot or Lowes have tubes too
Old Oct 06, 2012, 09:01 PM
CaliDave is offline
Find More Posts by CaliDave
CaliDave's Avatar
Bay Area
Joined Dec 2010
Here's a video showing the gear I've used and how I have it setup on my Penguin for those looking for some setup direction:
GSTV - "Penguin" - FPV Gear to Use (4 min 43 sec)
CaliDave is offline Find More Posts by CaliDave
Old Oct 09, 2012, 07:13 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
So to be clear, the horizontal and vertical stabilizers are held on with just the one machine screw? The only wood washers that I found were the motor shims. I used one of the thinner ones that I did not need for my motor type. I put lock-tite on the screw and tightened it down a fair amount until the wood washer was pushing into the foam a good amount. Does this sound like the way you guys built your kits?
Old Oct 09, 2012, 07:36 PM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
That sounds correct to me. However, I have modified mine so I can tighten it down a little more without it pulling through the bottom. Its just a piece of ply with a bolt hole in the center and then pushed to the middle. It gives it much wider area to push against. If you decide to to this, I'm sure you can make it look a little cleaner that I have. I was just looking for a quick fix.
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Old Oct 09, 2012, 10:18 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
NOOO, washer goes against the back plate (motor mount) not against the foam
Old Oct 10, 2012, 12:01 AM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Hmmm. I used a spare wood washer and put the 30mm screw through it then ran it up through toward the rudder, put lock-tite on it and tightened it down till the screw and wood washer sank a bit in the foam. Seems secure just odd that one screw holds the tail on. No glue?
Old Oct 10, 2012, 12:07 AM
Tony97 is offline
Tony97's Avatar
Joined May 2004
It's midnight. Got pretty far tonight. I think the plane is done basically. I installed the camera, pan & tilt, Eagletree system, Guardian, G-meter, and altimeter. Still thinking about how I will do pitot tube. I have pneumatic line on order. I may have enough silicone fuel tube to get it done.
I still need to wipe the Eagletree system clean from the old model it was on DBD start over I guess. Hate to do that as it took me a long time to figure out the system and set it up. RTH worked well on the old plane. Also, now using an old Futaba 9CAP to finally try out head tracking with my Dominators.
Anyone care to share Eagletree settings for this plane
Description:
Old Oct 10, 2012, 12:09 AM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Description:
I put the Guardian and G meter up top.
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
