Old Feb 22, 2013, 09:17 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Yeah, i have had this same problem on several models, including the Skywalker and a RQ-11 Raven. I have never been 100% happy tuning it out, but the Penguin is a real pleasure to fly in a glide so far, so I aim to play with it until I am moderately happy. With any luck this weekend the weather will be nice and I can really get to the bottom of it all.
I am a very visual person, but always have problems contemplating thrust on a pusher. But in my mind, the motor is pushing the nose of the aircraft down, if you imagine the wings are a fulcrum in which the fuse can freely spin.
I understand your point about the wash on the stab, but dunno much more to do other than test it out and see I guess?
Derek_S is offline Find More Posts by Derek_S
Old Feb 22, 2013, 09:37 AM
Tim Green is offline
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Originally Posted by Derek_S View Post
Is anyone else using a substantial amount of down-thrust on their P? I put 3mm washers on the top of the motor mount. From the side, this amount of adjustment seemed to put the motor pretty close to parallel to the chord line. However, I found I still needed substantial nose-down trim for powered flight (glide was relatively ok). I have now added 2 more 3mm washers to the top, so around 6mm of space. The motor now clearly shows some down thrust when viewed from the side. I have not flown it this way yet. Just wondering if this is someone else's experience as well?
I use just the 3mm washers. All planes will increase lift with an increase in speed - you have to decide where you want your plane to fly level - while gliding, or under full power, or something in between. I always set mine up for gliding level - and just apply some down during full power, or not. You can also setup mixing, such that with application of throttle, some down elevator is dialed in.
Tim Green is offline Find More Posts by Tim Green
Old Feb 22, 2013, 09:47 AM
Tresark is offline
Find More Posts by Tresark
United States, AL, Greenville
Joined Jun 2012
I wonder if the developer of the airframe has the where's and why's of placement, or if they used the empirical approach with a dose of 'been there, done that'.
Tre
Tresark is offline Find More Posts by Tresark
Old Feb 22, 2013, 09:48 AM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Yes, normally the throttle is considered the "climb" control input and the elevator is considered the "speed" control input so to climb you would expect to increase throttle and to increase speed you would then apply down elevator " trim". In a model this trim control could be on knob or switch or mix that would add down elevator to trim to level cruise at a given cruise throttle setting.
u2builder is online now Find More Posts by u2builder
Old Feb 22, 2013, 10:18 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
That is a good point, and something I haven't considered. (But I will consider as I get her better tuned), but I can say with certainty I am not withing the allowable range of that function. I.e. I have FULL down trim right now, and at high power still need a little down elevator. Perhaps I still have some tweaking to do on CG too (at about 80mm now) as she still 'feels' nose heavy to me, and likes to "porpoise" a little.
Old Feb 22, 2013, 10:20 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Good idea. Or, I would for myself plan to use an active mix that increases elevator trim given a certain throttle %. I did this on my Estar and worked great once you get it right. My problem with a preset is I don't fly long distance really, so I usually am constantly changing my speed, altitude, and vector.
Anyone also using flaperons/spoilerons? I programmed them in on a slider, but haven't really had a good chance to try them. Gotta get normal flight locked in first. I was really afraid I would have trouble landing her in tight spaces, but with the FPV gear and under the hood, it isnt too bad as I can dip in and flare pretty hard for what I would consider 'perfect' landings (in my book).
Old Feb 22, 2013, 02:26 PM
xxD-Manxx is offline
Find More Posts by xxD-Manxx
Go Fly Yourself...!!
xxD-Manxx's Avatar
United States, WA, Bonney Lake
Hey Kids...
Here's RC Models Reviews, Finwing Penguin Review Part 2:
Review: FinWing Penguin FPV (part 2) (8 min 27 sec)
Enjoy..
D-Man
xxD-Manxx is offline Find More Posts by xxD-Manxx
Old Feb 22, 2013, 04:22 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Originally Posted by DFloth View Post
Hey Kids...
https://www.youtube.com/watch?v=M_tkj25_uIs
Enjoy..
D-Man
I really like his reviews. Honest and straight forward.
Mike Freas is offline Find More Posts by Mike Freas
Old Feb 22, 2013, 06:51 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Me too
"Brilliant!"
"Absolutely over the moon!"
mark_q is online now Find More Posts by mark_q
Old Feb 22, 2013, 07:55 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
He should try the original canopy. It is much more streamlined and weighs 4 oz!!!! less. I put mine on today. My FPV camera is "looking through it" but if it winds up looking as bad as the video I could do like Markq did and cut a hole in it. I am a couple of months out from flying it so I'll leave it for now.
Old Feb 22, 2013, 08:14 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
With my experience with pushers, the Penguin has it backwards on the the thrust line thingy. I've yet to build my Penguin, but was planning on putting washers on the BOTTOM of the motor mount not top.
Because the motor is behind the c/g. Tilting the motor down in back 'lifts' the tail, thus the nose tucks down under power. Adding more down tilt should just make the situation worse.
The best scenario is to have the motor's thrust line pass through the planes C/G intersection. Thrust line above the c/g, on a pusher, will cause nose down under power. Passing below the c/g ona pusher will cause nose up under power.
Look at the EZ Star, for example. Which way does the motor point? With the front of the motor lower than the rear of the motor. The Penguin is the exact opposite.
To test you can mount the motor without washers and fly. Then put washers to the bottom motor mounts and fly. Then move the washers to the upper motor mount and fly. Choose the position that felt best to you and fine tune the thrust line until power on and power off cause little/no pitch difference.
Vantasstic is online now Find More Posts by Vantasstic
Old Feb 22, 2013, 11:35 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Hey vantastic,
Derek_S currently has to use too much down elevator for level flight under power so you are describing exactly the same thing he has tried, to point the motor down because he wants to bring the tail up. It apparently hasn't worked very well.
Old Feb 23, 2013, 08:31 AM
BadBoyBubby is offline
Find More Posts by BadBoyBubby
BadBoyBubby's Avatar
Norway, Sor-Trondelag, Trondheim
Joined Apr 2010
My Penguin
Hi folks.
This is my FPV platform. Ready for the electronics. I have covered the wingtips, nose and leading edges with UltraCoat.
LRS: Orange RX
Video Transmitter: FatShark 5.8GHz 250mW
Video on ground: FatShark SD
OSD and Autopilot: RVOSD (RangeVideo OSD)
FPV Camera: Sony 600TVL Super HAD CCD II
Recording Camera: GoPro Hero 3 Black Edition
Future Equipment:
Lawmate 1.3GHz 1000mW (or more) video transmitter.
DragonLink or Thomas Sherrer LRS.
BadBoyBubby is offline Find More Posts by BadBoyBubby
Old Feb 23, 2013, 10:27 AM
TAREK.SAADE is offline
Find More Posts by TAREK.SAADE
TAREK.SAADE's Avatar
London-UK
Joined Sep 2007
PG ALLYPALLY 23 02 2013 (2 min 16 sec)
TAREK.SAADE is offline Find More Posts by TAREK.SAADE
Old Feb 23, 2013, 10:51 AM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
Originally Posted by BadBoyBubby View Post
Hi folks.
Future Equipment:
Love the color scheme! Very simple. What made you decide on the Lawmate 1000mw?
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
