Old Sep 30, 2012, 02:21 PM
CN I Dawg is offline
Find More Posts by CN I Dawg
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
Originally Posted by nakelp86 View Post
Its too new to tell and whoever has it is busy building :-)
How does it fly? check the videos !!
Man, its only 9 pages and people are to lazy to read from the beginning LOL
Dude, I did read and watch. But didn't see all answered. Only someone who has flown both can give a proper flight comparison. Saw some claim only tail feathers need re-enforcement but will be fixed in future shipments. Come on give me a break
I was going to pull the trigger anyway BUT shipping costs are 1/3 of the plane cost I'll patiently wait for reviews.
CN I Dawg is offline Find More Posts by CN I Dawg
Old Sep 30, 2012, 02:23 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
LOL, Ask Dave he is the one who flew both.
As I said few who got it are working on it LOL
nakelp86 is offline Find More Posts by nakelp86
Old Sep 30, 2012, 02:53 PM
robstach is offline
Find More Posts by robstach
United States, PA, Bethlehem
Joined May 2012
Ok here is another question:
There is an "L" shaped bracket that bolts to the camera plate. You can see it in my picture above..... (on page 9)
robstach is offline Find More Posts by robstach
Old Sep 30, 2012, 03:17 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
yeah I figured that one after post LOL. if I use it there goes the pan servo LOL.
have to figure something out here.
Old Sep 30, 2012, 04:07 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Originally Posted by robstach View Post
Now that I look closer I'm sure that something is missing. The bracket would never reach the vertical wall without something inserted. See below:
Something MUST slide into this slot:
Easy enough to make but annoying ....
you sure the piece is not hiding in the bag?
Mine was glued in.
Old Sep 30, 2012, 04:24 PM
robstach is offline
Joined May 2012
Yeah - I checked. There are no glue marks inside of my canopy where that part would be installed. So - it was never installed at the factory to begin with.
The wooden discs are for the motor mount. Thickness depends on your motor. They show them twice in the manual.
The largest of the wooden discs goes under the tail with the screw to hold the vertical stabilizer...
Small self-tapping screws are for canopy sides...
Everything else - spares.
Old Sep 30, 2012, 04:32 PM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
Wow, this is moving fast!
The extra wood piece that you are referring to was not with my original Penguin either. I believe Tim had one on his, but I would not want to use it for a camera mount anyways. I was afraid that it would be prone to a lot of vibration since it has similar properties to a diving board.
Here is my solution for mounting a Pan/Tilt and Gopro in front:
http://www.rcgroups.com/forums/showp...8&postcount=88
Has anyone gotten theirs in the air yet?
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Old Sep 30, 2012, 04:34 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Yep I know the wooden discs, which still baffles me why the pusher would point upwards??!!
When Im ready I will just dry fit them there and try without them too.
If anything I would shim the bottom of the motor mount.
Another thought about the battery bay foam cover, I know it looks cool with these sexy curves but its a mayor pain to customize, Im thinking about cutting some foam from the fuse and make straight lines so I can build my cam pod.
Just loudly thinking here :-)
Old Sep 30, 2012, 04:36 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
easier solution would be getting some bracket under the diving board and put the FPV cam directly under the GoPro.
Just throwing some thoughts, come on guys do some brainstorming LOL
Old Sep 30, 2012, 04:56 PM
Joined Mar 2006
That would definetly help stop the vibrations you would have and also be stronger. Why not just glue a block of foam or balsa to the canopy, shape it for both cameras and then paint it to match?
Site Sponsor
Old Sep 30, 2012, 05:03 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Or Tim could make a sexy base plate from plastic following the fuse curves with UNLIMITED options to build on top of it :-))
The curves are done on EZ* II pod :-))
Old Sep 30, 2012, 05:04 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Yep, foam would do too
Im just brain storming for better solution :-)
Old Sep 30, 2012, 05:18 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Opted for flat CF piece on horizontal stub,instead of supplied round tube which is huge and not so stiff.
Drying now but seems to be stiff enough, I also run it longer pass the control surface right through horizontal stub dihedral (???)
The supplied tube is only as long as elevator which makes the tips VERY weak.
Discussion fmkit's ULink (review/discussion/etc) CrashMeUp FPV Talk 112 Apr 07, 2013 05:34 PM
Discussion general engine discussion thread cale10 Engines 273 Nov 13, 2012 01:22 PM
Spektrum DX7 technology discussion (moved from review thread) Chipwillis Radios 62 Jan 17, 2007 04:07 PM
Heliup.com CNC CF Shogun/Zoom frame build thread/review Hoverup Mini Helis 123 Jun 18, 2005 09:09 PM
