Old Jul 03, 2012, 09:27 PM
tsmith9000 is offline
Find More Posts by tsmith9000
Joined Apr 2006
Build Log
Sig Kadet
Hello all,
Started a Sig Kadet build. I haven't built in awhile. Thought I would butcher some balsa.
Downloaded the plans and printed on a plotter.
tsmith9000 is offline Find More Posts by tsmith9000
Old Jul 03, 2012, 10:07 PM
Joined Apr 2006
Got the fuse sides cut out and tommorrow I will add the 1/4 square stingers, the 1/4 by 1/2 inch stringers, and the 1/8 by 1/4 stringers.
I haven't figured out how to duplicate the other side with the stinger lines. Any suggestions?
Old Jul 04, 2012, 01:55 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Clamp the sides together then use a pin to mark the important points through from the marked out side, join them up on the other side with a pencil and ruler and you have the correct markings for one left and one right side.
Sundancer is offline Find More Posts by Sundancer
Old Jul 04, 2012, 02:40 AM
DeeBee1 is offline
Find More Posts by DeeBee1
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
Tape the plan to a window so you can see through it (in daytime!) and mark the stringer lines on the back of the plan. Then just mark them onto the balsa in the usual way from the back of the plan.
Good luck with the build
DeeBee1 is offline Find More Posts by DeeBee1
Old Jul 04, 2012, 05:51 AM
pd1 is online now
pd1
Find More Posts by pd1
pd1
United States, MA, Haverhill
Joined Jun 2006
I reversed the fuselage plan. Print this out and use this to trace the other side.
Paul
pd1 is online now Find More Posts by pd1
Old Jul 04, 2012, 07:48 AM
wim5150 is offline
Find More Posts by wim5150
illinois
Joined Jun 2001
tsmith, were did you download the plans ?
wim5150 is offline Find More Posts by wim5150
Old Jul 04, 2012, 09:37 AM
pd1 is online now
pd1
pd1
Joined Jun 2006
Plan available here:
http://www.outerzone.co.uk/plan_details.asp?ID=2950
Old Jul 05, 2012, 10:14 AM
Joined Apr 2006
Thanks for the help ya'll. What thickness are the plywood parts? 1/8th? Thats the next step I need to figure out. Anyone converted to electric?
Old Jul 05, 2012, 11:50 AM
pd1 is online now
pd1
pd1
Joined Jun 2006
My Kadet is electric powered. I just removed the glow engine and made a firewall extension and bolted an E Flite 25 to the front. My firewall is 1/4 thick. my motor extension is made from 1/8 birch ply pieces.
I added a hatch on the bottom to house the battery pack. Easier than removing the wing.
I stuck a bunch of LED lights on the plane and now it's a night flyer.
Paul
Old Jul 09, 2012, 11:06 AM
Joined Apr 2006
Almost completed one side. I am having difficulty finding pre-grooved bass wood for the main landing gear.
PD1 what is the wood block above the main landing gear block made out of?
Old Jul 09, 2012, 02:01 PM
pd1 is online now
pd1
pd1
Joined Jun 2006
I make landing gear blocks out of layers of 1/8 plywood. Birch plywood is the best. Lite ply in a pinch, just soak the edge of lite play with CA.
1/8 is easy to cut and I glue them together with Titebond and clamp until dry.
Epoxy will also work., but I think it is messier than Titebond.
If you need other information, I'll have to go look at the plane. My plane is over 30 years old.
Old Jul 30, 2012, 09:38 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Any updates?
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Aug 01, 2012, 11:31 PM
Joined Apr 2006
Hey Andy,
Sorry needed to fix my bandsaw. I cut the plywood parts out. Tried to upload pictures-but had trouble. Will post soon.
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
Sold Sig Kadet Seniorita :: Airframe Only :: LPU NoVA :: $25 N925WB Aircraft - Fuel - Airplanes (FS/W) 2 Jun 21, 2012 07:36 AM
Sold Sig Kadet Seniorita w/OS .26 Four Stroke :: LPU Nothern VA Only N925WB Aircraft - Fuel - Airplanes (FS/W) 3 Jun 19, 2012 06:58 AM
Sold Sig kadet warbirdguyn951 Aircraft - Fuel - Airplanes (FS/W) 2 Jun 14, 2012 05:48 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
