Old Sep 23, 2012, 04:27 PM
nuki is offline
Find More Posts by nuki
nuki's Avatar
Spain, PV, San Sebastian
Joined May 2012
Thanks a lot sPikes777 and flypilot.
You have convinced me. I'm buying batteries 4S.
A question, 4S batteries, how many Cs? Is this enough?
Gens ace 5300mAh 14.8V 30C 4S1P Lipo Battery Pack
About de propeller for this frame and motors with 3,5 Kgrs (My ignorance is total about this):
- Graupner, APC or carbon fiber?
- 14" or 13"?
- Slow fly /electric?
- Any good web to buy your suggestion's propellers?
I wrote to foxtechfpv and they have answered me that the motors comes with long wire . He said me that I don't need any control system mounting plate and the above power distribution board will work
Thanks to all for your help
EDIT: I forgot to mention that I have 30A OPTO ESC DJI
nuki is offline Find More Posts by nuki
Old Sep 23, 2012, 04:49 PM
flypilot is offline
Find More Posts by flypilot
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Hehe, my intention was not to force you to buy 4s batteries I Use 25c batteries as that is more than enough for this application.
As for props, alot of props work great but I have had best success with the Graupner E props...only problem is that the are kinda difficult to source...
I bought mine here: http://www.electricwingman.com/prope...ktro-prop.aspx
Don't forget the spacers.
flypilot is offline Find More Posts by flypilot
Old Sep 23, 2012, 05:08 PM
nuki is offline
nuki's Avatar
Joined May 2012
Yes...but you are the third person that say me that the best option is to buy 4s baterries .
Ok with 25C
Ok. Thanks por the link. What's are the spacers?
¿You fly with 30A ESC DJI?
Thanks flypilot
Old Sep 23, 2012, 05:22 PM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
These: http://www.electricwingman.com/graup...r/8mm/6mm.aspx
I think that the axel is 6 mm, i don't remember...
Yes I am using the DJI 30 AMP esc's
Old Sep 23, 2012, 05:35 PM
nuki is offline
nuki's Avatar
Joined May 2012
Ok. I'll seen.
Old Sep 24, 2012, 03:05 AM
sPiKes777 is offline
Find More Posts by sPiKes777
Joined Jun 2012
Regarding the propellers, I have not tried the Graupner E-props, but I have a very good experience with carbon fiber. The ones I have on my Gaui 500X (10x4.5) touched the ground on two occasions, and they are still working perfect. They are much more resistant than the standard Gaui props.
sPiKes777 is offline Find More Posts by sPiKes777
Old Sep 24, 2012, 01:58 PM
trunet is offline
Find More Posts by trunet
Brazil, São Paulo, Sao Paulo
Joined Nov 2011
Attached my frame pictures. Test flight will be tonight.
It has:
- 2814-11 710kv sunnysky motors
- F-40A HobbyKing ESC w/ simmonk firmware
- immersionrc 5.8Ghz 600mW with cloverleaf antenna
- frsky 2.4Ghz RX
- crius aio pro with UBLOX LEA-6H gps
- xbee pro 50mw series 1 for telemetry
- 2 x 4S 5000mah batteries
- I'll use 13x4.5 propeller
trunet is offline Find More Posts by trunet
Old Sep 24, 2012, 03:38 PM
nuki is offline
nuki's Avatar
Joined May 2012
Trunet good assembly!
One question.
Where do you buy this plate?
It has:
- frsky 2.4Ghz RX
Old Sep 24, 2012, 03:42 PM
trunet is offline
Joined Nov 2011
I have a turnigy talon hexcopter from hobbyking. I took it from there.
the top plate is this one. On the bottom I made a sandwich with fh-h800 bottom plate, two solid copper wire as power distribution to ESCs and the talon bottom plate. down below talon bottom plate is the batteries.
Old Sep 24, 2012, 04:10 PM
nuki is offline
nuki's Avatar
Joined May 2012
Thanks trunet.
I think that I'll need to buy a similar plate...
May be this....
Turnigy Talon Carbon Fiber Main Frame Upper Plate (1pc/bag)
Old Sep 26, 2012, 01:31 PM
fotofly is offline
Find More Posts by fotofly
Joined Sep 2012
How was the test flight?
I am 90% decided on almost similar configuration as yours.
But i am worried about CRIUS aio pro, good price and good set of functions but i am unexperienced in configuring and programming so NAZA looks like a better choice for me as i need it for AP/V.
What do you think?
It has:
- frsky 2.4Ghz RX
fotofly is offline Find More Posts by fotofly
Old Sep 26, 2012, 01:39 PM
trunet is offline
Joined Nov 2011
What do you think?
The flight were extremely good. It's very stable and flies well with 10x4.5 and both 4S 5000mah battery. It hovers at about 50%.
I had a NAZA on a F450 frame and sold it. It's lot easier than Crius AIO Pro. I spent like 4 to 5 flights just tuning PIDs and Crius AIO Pro configurations. I'm using megapirateng and it'll be harder to tune than naza. I have the extended board so I earn GPS, waypoints, RTL, etc... spending less than half than NAZA.
But, if more people use it, we can share our PID settings that will make easier everybody's life.
Old Sep 26, 2012, 05:06 PM
nuki is offline
nuki's Avatar
Joined May 2012
Hi, flypilot:
One off topic
Whats the zippy battery to you use for FPV Transmitter?
ZIPPY Flightmax 800mAh 3S1P 20C
I did not really have any good way as of attaching the gimbal/landing gear to the frame and went for the zeal tape and zipties. I know, not the best way of doing it but it seems to work pretty good. And it is easy to seperate the two pieces. Had to make four holes in the frame to fit the zipties so that they were not in the way of the folding mechanism.
Next is testflight and tuning of flightcontroll.
Old Sep 26, 2012, 10:26 PM
clausjepsen is offline
Find More Posts by clausjepsen
Joined Mar 2012
Hi, yes very pleased, the hexa has been in constant AP use the last three months and not one issue...very happy.
Using, W-KM 5.12a and Gains are 200,200,200,70,70.
Using Graupner 14x8 E props on DJI 30A ESC's and 4s batteries.
This winter I will buy a big ship for photo and video and I have been looking at FH-H800. I am flying Naza on a 550, but for my new multi maybe I will buy the YS-X6 controller. Did you choose the WKM, if so, why, or did you already have one?
To get stable video I think I will buy a Hoverfly Gimbal Controller. Does anyone have experience with the gimbal output from the YS-X6.
clausjepsen is offline Find More Posts by clausjepsen
Old Sep 27, 2012, 03:30 AM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Originally Posted by nuki View Post
Hi, flypilot:
One off topic
Yes, that is the one
Sold FH-10Z Camera 10x zoom rc controlled - Foxtech FPV beep684 FPV Equipment (FS/W) 1 Jun 28, 2012 06:35 PM
Discussion FH-X46 new quadcopter and hexacopter controller from FOXTECH glassfox Multirotor Talk 730 Apr 30, 2012 07:14 AM
Sold Foxtech 5.8 GHz RX w/power and A/V cables keok FPV Equipment (FS/W) 4 Feb 28, 2012 01:37 PM
Wanted Looking 4 gear compatible w/ Foxtech "AIO" 2.4/5.8Ghz goggles Medicineman76 FPV Equipment (FS/W) 2 Feb 25, 2012 07:35 PM
Discussion Foxtech FH-25HD 550tvl day/night mrleenagle FPV Talk 8 Aug 13, 2010 09:36 PM
