Old Sep 12, 2012, 03:09 PM
flypilot is offline
Find More Posts by flypilot
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Yes, I believe hover amp is around 30 Amps.
flypilot is offline Find More Posts by flypilot
Old Sep 12, 2012, 03:30 PM
sPiKes777 is offline
Find More Posts by sPiKes777
Joined Jun 2012
Thanks a lot !
sPiKes777 is offline Find More Posts by sPiKes777
Old Sep 20, 2012, 12:17 PM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
A couple of pictures of my rig...as of today.
Installed ver. 5.14a today, calibrated and flew great.
Old Sep 21, 2012, 04:59 PM
Joined Jun 2012
Thank you for the very nice pictures !
I ordered a few days ago an FH-H800, with the new version of the DS02 gimbal (DS02 Plus):
http://www.foxtechfpv.com/ds02-gimba...era-p-657.html
The choice was not easy between the new version of the landing gear (carbon fiber, lower) and the previous version (aluminium). The carbon version is lighter, but the camera is closer to the ground (and dust).
I am now deciding which type of battery I should use. You mentioned that you use two 4S 5800 mAh batteries in parallel. How have you attached them to the frame ? Would you have a photo or two maybe ?
I am considering the following Hobbyking batteries:
ZIPPY Flightmax 8000mAh 4S1P 30C
ZIPPY Flightmax 5800mAh 4S1P 30C
Do you think it would be possible to use one 8000 mAh battery ? I suppose this may cause a load asymmetry. Or even two 8000 mAh batteries in parallel ? They are not very thick apparently.
Old Sep 22, 2012, 06:29 AM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
You can see how I mounted the batteries on the above pictures, they are mounted below the gimbal plate with two velcro straps.
Old Sep 22, 2012, 06:34 AM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
I think you could easily fly with one battery only, no problem..
Old Sep 22, 2012, 09:38 AM
Joined Jun 2012
Ah ok, I see them now: they are nicely integrated. Did the Velcro straps come with the Foxtech kit or did you purchase them separately ?
Also, you obtain 12 minutes flight with a 4S2P 11600 mAh battery setup. Extrapolating this figure would result in about 16 minutes using a 4S2P 16000 mAh combo, maybe a bit less Including the weight difference of the 8000 mAh vs 5800 mAh batteries (about 200 g each). From the Sunnysky motor specs:
http://www.foxtechfpv.com/sunnysky-2...tor-p-382.html
I think it should be possible to get a bit more, maybe 3-4 minutes, but of course, there is a safety margin...
Old Sep 22, 2012, 09:45 AM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Well I usally fly with these batteries for 10 min, that leaves about 25% left i the batteries for longivety.. I use the JR telemtry that has a MAH counter and flighttime varies with weather and amount of turbulence where I fly.
The straps are a couple of Align Battery straps.
Old Sep 22, 2012, 04:42 PM
nuki is offline
Find More Posts by nuki
nuki's Avatar
Spain, PV, San Sebastian
Joined May 2012
Hi:
I'm very interested in this frame with SunnySky 2814-11 700Kv motors. I have two LIPOs of 5000mAh 3S, and I don't know what is the best prop for this configuration.
Graupner 14x8 E props on DJI 30A ESC's and 4s batteries.
with 3S LIPOS, may be 12x6 or 13x6? Carbon fiber?
Any suggestions?
EDIT: Other thing, The picture of the SunnySky 2814-11 700Kv motor has short wire, and you say that they came with long wires. Do you have specifically requested?
EDIT 2: Any option to buy a controll system mounting plate? Can I buy this power distribution board for this frame?
nuki is offline Find More Posts by nuki
Old Sep 22, 2012, 04:46 PM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
It all depende on your all up weight...
But I personally think that you would not get the best setup on 3s with these motors, for 3s you would need Higher KV motors, say around 900kv maybe..
But you could always try out the 13x6 props and see how that works,
No, no special request for long wires, they came like that in the kit I bought.
Old Sep 22, 2012, 05:02 PM
nuki is offline
nuki's Avatar
Joined May 2012
Thanks flypilot for your fast reply.
And what about of my EDIT2?
About controll system mounting plate and power distribution board for this frame?
Thanks again
Old Sep 22, 2012, 05:06 PM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
No problem, glad to help... I don't know anything about that board but if it can take the load you are going to be running I don't see why you could not use it... I just use two good gauge wire my self and solder the ESC wires to that... I like to keep it simple
Thanks again
Old Sep 22, 2012, 05:10 PM
nuki is offline
nuki's Avatar
Joined May 2012
On the power distribution board specifications I can see this:
POWER Distributor For Multi-Rotor
For all tpye multi-rotor ,100A current max.
Old Sep 23, 2012, 03:32 PM
Joined Jun 2012
Hi:
Any suggestions?
On the web page of the FH-H800 at the Foxtech web site, it is mentioned that it can be equipped with 3S or 4S batteries. The motor specifications are also listed:
From this table, it should be possible to use a 3S battery without problem, but for a relatively low takeoff weight. For about 4 kg, it should be possible. The only problem is that the required current will be quite high, and it will put a relatively high demand on the ESCs.
Old Sep 23, 2012, 03:47 PM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Yes you are probably right, I am more of a fly and test kind of person and found that for my Hexa the 14x8 props work best,, but for your 3s might be just the ticket..I say go for it
Sold FH-10Z Camera 10x zoom rc controlled - Foxtech FPV beep684 FPV Equipment (FS/W) 1 Jun 28, 2012 06:35 PM
Discussion FH-X46 new quadcopter and hexacopter controller from FOXTECH glassfox Multirotor Talk 730 Apr 30, 2012 07:14 AM
Sold Foxtech 5.8 GHz RX w/power and A/V cables keok FPV Equipment (FS/W) 4 Feb 28, 2012 01:37 PM
Wanted Looking 4 gear compatible w/ Foxtech "AIO" 2.4/5.8Ghz goggles Medicineman76 FPV Equipment (FS/W) 2 Feb 25, 2012 07:35 PM
Discussion Foxtech FH-25HD 550tvl day/night mrleenagle FPV Talk 8 Aug 13, 2010 09:36 PM
